ADP-N1 Adapter Board Data Sheet
Adapter Board:ADP-N1 Data Sheet
**Discontinued Product,Replacement Part NO. ADP-N1-V2.0
**停产产品,替代型号ADP-N1-V2.0
1 Product Introduction(产品介绍)
ADP-N1 is a camera interposer module for NVIDIA Jetson AGX Xavier & TX2 DevKit.
ADP-N1是NVIDIA Jetson AGX Xavier和TX2开发套件的摄像头转接模块。
2 Product Picture(产品图片)
PART NUMBER / 型号 FRONT VIEW / 正面图片 BACK VIEW / 背面图片 FFC CABLE/FFC线缆 SKETCH MAP/示意图
ADP-N1
ADP-N1-T
ADP-N1-B
FFC28P-0.5MM-20CM-T
SKETCH MAP
ADP-N1 J1/J2/J3/J4/J5/J6 PINLIST
ADP-N1 J7 PINLIST
3 Adapter Board Pinlist(接口和引脚说明)
J8:Funcation Jumper(功能选择)
1 CAM_VSYNC Internal Connect with J7-86 through a level shifter(3.3V to 1.8V)
2 COM Internal pull up to 3.3V, Rpu=1.5KΩ
3 Ext Trigger In Internal Connect with J9-1
J9
1 Ext Trigger In Internal Connect with J8-3
3 NC
J8,J9,SW1 Functional specifications(J8,J9,SW1功能说明)
J8 Jumper Status(J8跳选状态) Remarks(说明)
Short connection J8-1 and J8-2
(短接J8的1、2引脚)
Select J7-86(CAM_VSYNC) as the trigger source,Only available Interconnect with TX2 platform
(与TX2/TX2平台主板互联时,此时选择的是J7-86(CAM_VSYNC)作为触发源)
Short connection J8-2 and J8-3
(短接J8的2、3引脚)
Select J9-1(Ext Trigger In) as the trigger source
(此时选择的是J9-1(Ext Trigger In)作为外触发源)
SW1 is used for testing to simulate an external trigger signal,Internal Connect with J9-3
(此时SW1模拟一个外触发信号,与J9-3引脚连接在一起)
J1 / J2 / J3 / J4 / J5 / J6
Pin NO. J1 J2 J3 J4 J5 J6
NAME Remarks NAME Remarks NAME Remarks NAME Remarks NAME Remarks NAME Remarks
1 GND GND GND GND GND GND
2 NC NC NC NC NC NC
3 NC NC NC NC NC NC
4 GND GND GND GND GND GND
5 NC NC NC NC NC NC
6 NC NC NC NC NC NC
7 GND GND GND GND GND GND
8 CSI_A_CLK_P CSI_B_CLK_P CSI_C_CLK_P CSI_D_CLK_P CSI_E_CLK_P CSI_F_CLK_P
9 CSI_A_CLK_N CSI_B_CLK_N CSI_C_CLK_N CSI_D_CLK_N CSI_E_CLK_N CSI_F_CLK_N
10 GND GND GND GND GND GND
11 CSI_A_D1_P CSI_B_D1_P CSI_C_D1_P CSI_D_D1_P CSI_E_D1_P CSI_F_D1_P
12 CSI_A_D1_N CSI_B_D1_N CSI_C_D1_N CSI_D_D1_N CSI_E_D1_N CSI_F_D1_N
13 GND GND GND GND GND GND
14 CSI_A_D0_P CSI_B_D0_P CSI_C_D0_P CSI_D_D0_P CSI_E_D0_P CSI_F_D0_P
15 CSI_A_D0_N CSI_B_D0_N CSI_C_D0_N CSI_D_D0_N CSI_E_D0_N CSI_F_D0_N
16 GND GND GND GND GND GND
17 NC NC NC NC NC NC
18 RESERVE NC RESERVE NC RESERVE NC RESERVE NC RESERVE NC RESERVE NC
19 GND GND GND GND GND GND
20 SCL0 3.3V Level SCL1 3.3V Level SCL2 3.3V Level SCL3 3.3V Level SCL4 3.3V Level SCL5 3.3V Level
21 SDA0 3.3V Level SDA1 3.3V Level SDA2 3.3V Level SDA3 3.3V Level SDA4 3.3V Level SDA5 3.3V Level
22 GND GND GND GND GND GND
23 Sync0 Sync0 Sync0 Sync0 Sync0 Sync0
24 Sync1 Sync1 Sync1 Sync1 Sync1 Sync1
25 VDD_3V3_SLP PWR OUT VDD_3V3_SLP PWR OUT VDD_3V3_SLP PWR OUT VDD_3V3_SLP PWR OUT VDD_3V3_SLP PWR OUT VDD_3V3_SLP PWR OUT
26 VDD_3V3_SLP PWR OUT VDD_3V3_SLP PWR OUT VDD_3V3_SLP PWR OUT VDD_3V3_SLP PWR OUT VDD_3V3_SLP PWR OUT VDD_3V3_SLP PWR OUT
27 VDD_3V3_SLP PWR OUT VDD_3V3_SLP PWR OUT VDD_3V3_SLP PWR OUT VDD_3V3_SLP PWR OUT VDD_3V3_SLP PWR OUT VDD_3V3_SLP PWR OUT
28 GND GND GND GND GND GND
J7
Pin NO. NAME Remarks Pin NO. NAME Remarks Pin NO. NAME Remarks Pin NO. NAME Remarks
1 CSI_A_D0_P 31 CSI_C_D1_P 61 NC 91 NC
2 CSI_B_D0_P 32 CSI_D_D1_P 62 NC 92 NC
3 CSI_A_D0_N 33 CSI_C_D1_N 63 NC 93 NC
4 CSI_B_D0_N 34 CSI_D_D1_N 64 NC 94 NC
5 GND 35 GND 65 NC 95 NC
6 GND 36 GND 66 NC 96 NC
7 CSI_A_CLK_P 37 CSI_E_D0_P 67 NC 97 NC
8 CSI_B_CLK_P 38 CSI_F_D0_P 68 NC 98 NC
9 CSI_A_CLK_N 39 CSI_E_D0_N 69 GND 99 GND
10 CSI_B_CLK_N 40 CSI_F_D0_N 70 GND 100 GND
11 GND 41 GND 71 NC 101 NC
12 GND 42 GND 72 NC 102 NC
13 CSI_A_D1_P 43 CSI_E_CLK_P 73 NC 103 NC
14 CSI_B_D1_P 44 CSI_F_CLK_P 74 NC 104 NC
15 CSI_A_D1_N 45 CSI_E_CLK_N 75 CAM_I2C_SCL 1.8V Level 105 NC
16 CSI_B_D1_N 46 CSI_F_CLK_N 76 NC 106 NC
17 GND 47 GND 77 CAM_I2C_SDA 1.8V Level 107 NC
18 GND 48 GND 78 NC 108 VDD_3V3_SLP PWR
19 CSI_C_D0_P 49 CSI_E_D1_P 79 GND 109 VDD_5V0_IO_SYS PWR
20 CSI_D_D0_P 50 CSI_F_D1_P 80 GND 110 VDD_3V3_SLP PWR
21 CSI_C_D0_N 51 CSI_E_D1_N 81 NC 111 NC
22 CSI_D_D0_N 52 CSI_F_D1_N 82 NC 112 NC
23 GND 53 GND 83 NC 113 NC
24 GND 54 GND 84 VDD_3V3_SLP PWR 114 NC
25 CSI_C_CLK_P 55 NC 85 NC 115 GND
26 CSI_D_CLK_P 56 NC 86 CAM_VSYNC RESERVE 116 GND
27 CSI_C_CLK_N 57 NC 87 NC 117 NC
28 CSI_D_CLK_N 58 NC 88 NC 118 VDD_5V0_IO_SYS PWR
29 GND 59 NC 89 NC 119 NC
30 GND 60 NC 90 NC 120 VDD_5V0_IO_SYS PWR
4 Adapter Board Dimension(板子尺寸)
ADP-N1 CAD / unit:mm
Download dwg file here
