ADP-TWG
Adapter Board:ADP-TWG DATA SHEET
转接板:ADP-TWG数据手册
1 Introduction 产品介绍
ADP-TWG是一款转接板,可将VEYE系列和CS系列符合15Pin接口转换为其他平台摄像机接口,支持Google Coral Dev Board 24Pin、Toradex 24Pin、WandBoard 33Pin。
The ADP-TWG is a adpter board that converts VEYE / CS Series camera module 15Pin interface to other platform interface,such as Google Coral Dev Board 24Pin、Toradex 24Pin(TBD)、WandBoard 33Pin(TBD).
2 Product Picture 产品图片
PART NUMBER / 型号 FRONT VIEW / 正面图片 BACK VIEW / 背面图片 Adapter camera module / 适配摄像机模组
ADP-MYiR
ADP-TWG
ADP-TWG
CS-MIPI-SC132
CS-MIPI-IMX307
VEYE-MIPI-IMX385
VEYE-MIPI-IMX462
VEYE-MIPI-IMX327S
BOTTOM VIEW
TOP VIEW
3 Adapter Board Pinlist 引脚说明
J1:UP contact,5cm FFC,connect with VEYE/CS camera module
J1:上接触,标配5厘米异面FFC,与VEYE/CS系列模组互联
Pin NO. 引脚号 NAME 名称 Remarks 说明
2 MIPI_L0_N
3 MIPI_L0_P
5 MIPI_L1_N
6 MIPI_L1_P
8 MIPI_CK_N
9 MIPI_CK_P
11 RESERVE NC
12 RESERVE NC
13 SCL 3.3V level 电平标准
14 SDA 3.3V level 电平标准
15 VCC3V3 3.3V OUT 输出
J2:Down contact,24Pin 20cm FFC,connect withToradex 24Pin connector
J2:下接触,标配24Pin 20cm同面FFC,与韬睿24Pin Camera互联
1 NOT USE
2 NOT USE
3 NOT USE
4 VCC5V 5V IN 输入
5 NOT USE
6 NOT USE
8 NOT USE
9 NOT USE
10 NOT USE
11 SDA 3.3V level 电平标准
12 SCL 3.3V level 电平标准
13 NOT USE
14 NOT USE
15 GND
16 MIPI_CK_P
17 MIPI_CK_N
18 GND
19 MIPI_L1_P
20 MIPI_L1_N
21 GND
22 MIPI_L0_P
23 MIPI_L0_N
24 GND
TBD
J3:Down contact,33Pin 20cm FFC,connect with WandBoard 33Pin connector
J3:下接触,标配33Pin 20cm同面FFC,与WandBoard 33Pin Camera互联
1 MIPI_CK_P
2 MIPI_CK_N
3 GND
4 MIPI_L0_P 5V IN 输入
5 MIPI_L0_N
6 GND
7 MIPI_L1_P
8 MIPI_L1_N
9 GND
10 NOT USE
11 NOT USE
12 GND
13 NOT USE
14 NOT USE
15 GND
16 NOT USE
17 NOT USE
18 GND
19 NOT USE
20 NOT USE
21 GND
22 NOT USE
23 NOT USE
24 GND
25 SCL 3.3V level 电平标准
26 SDA 3.3V level 电平标准
27 NOT USE
28 NOT USE
29 NOT USE
30 NOT USE
31 NOT USE
32 VCC5V 5V IN 输入
33 VCC5V 5V IN 输入
J4:Down contact,24Pin 20cm FFC,connect with Google Coral 24Pin connector
J4:下接触,标配24Pin 20cm同面FFC,与Google Coral Dev Board 24Pin Camera互联
2 MIPI_L0_N
3 MIPI_L0_P
5 MIPI_CK_N
6 MIPI_CK_P
8 MIPI_L1_N
9 MIPI_L1_P
11 NOT USE
12 NOT USE
13 GND
14 NOT USE
15 NOT USE
16 GND
17 NOT USE
18 NOT USE
19 GND
20 SCL 3.3V level 电平标准
21 SDA 3.3V level 电平标准
22 NOT USE
23 NOT USE
24 3V3 Connect with jumper 与跳线jumper互联
4 Schematic 原理图
下载原理图
Download schematic file
5 Adapter Board Dimension 尺寸图
ADP-TWG CAD / unit:mm
Download dwg file here
6 PCBA 3D STP File
download 3D STP file
