CS-MIPI-X for Raspberry Pi
How to Use CS-MIPI-X Mipi Camera with Raspberry Pi
Introduction
CS-MIPI-307 is a is a special camera module which is compatible with RASPBERRY PI. It use SONY STARVIS sensor——IMX307 and has excellent ISP functions build-in.The output format is stanard UYVY stream. It is very easy to use it with RASPBERRY PI.Of course, she also has some subtle differences with the official version. She support 1080p@30,720p@60 resolution,and i2c cmd is different.
Theoretically,VEYE Camera Modules support all Raspberry Pi. For performance reasons, I recommend you use 3,3+,4 version. This article uses Raspberry Pi 4 as an example to explain how the CS-MIPI-307 camera module working with Raspberry Pi. It also explain the specials of RPI Computer Module and Zero using VEYE Camera Module.
Hardware Setup
Essentials You Need:
  • Camera Module Items : CS-MIPI-307,FFC,Dupont Wire,Lens.
Setup guide
  • Connect the VEYE Camera Module the CSI-2 port using FFC Cable(type B).
  • Connect Dupont Wire as shown below. CS-MIPI-307 need an addtional power.
  • Startup RaspberryPi.
connect CS-MIPI-IMX307 to Raspberry Pi 001
connect CS-MIPI-IMX307 to Raspberry Pi 002
connect CS-MIPI-IMX307 to Raspberry Pi 003
connect CS-MIPI-IMX307 to Raspberry Pi 004
connect CS-MIPI-IMX307 to Raspberry Pi 005
RaspberryPi System Setup and Configuration
Sofware Toolkits Install
Toolkits downloading
  • 1. Clone from github
Toolkits Overview
Software Tookits on github
Software toolkits contains threeparts. veye_raspcam is raspcam alike Video Stream Toolkits, D_mipi_rpi is D-SDK Video Stream Toolkits, i2c_cmd is Video Control Toolkits.
  • Both is Open Source.
Note: D-SDK do not support 720p@60 now! will upgrade soon!
Video Stream Toolkits Manual
Video format
veye type like Video Stream Toolkits support multiple video formats,such as 1080p@30fps,720p@60fps etc..
-md option indicat which format to use,default 0。
Please set the video format before using Video Stream Toolkits.
Video Formats
Value Video Format
0 1080p@30fps
1 720p@60fps
veye_raspcam: raspcam alike toolkits
  • veye_raspipreview
./veye_raspipreview -md 1 -t 20000 -p '0,0,1280,720'
Dispaly real-time video(720p@60) to HDMI output,preview window is 1280*720, last 20 seconds.
./veye_raspipreview -t -1
  • veye_raspivid
./veye_raspivid -md 1 -t 5000 -o ~/test.h264
Implement H.264 format encoding(720p@60) and record for 5 seconds,Record the stream data to file ~/test.h264.
  • veye_raspivid (direct tcp stream with netcat,gstreamer etc..)
RPI side
x.x.x.x is RPI IP address
PC side, using mplayer
mplayer for windows download
  • veye_raspividyuv
  • veye_raspiraw
  • veye_raspstillyuv
Capturing one image and save to /dev/shm directory(which is in DDR).1280*720 YUV420 I420 format.
  • veye_raspistill
Capturing one image and save to home directory.1280*720 JPG format.
veye_raspistill support preview,-n will not preview.
Video Control Toolkits Manual
Video Control Toolkits Manual : CS-MIPI-X i2c
