CS-USB-IMX307
CS-USB-IMX307 Data Sheet
Introduction
CS-USB-IMX307 is a cost-effective USB camera. This module use the SONY STARVIS CMOS image sensor IMX307LQD-C,built-in ISP processing.
CS-USB-IMX307 TOP
CS-USB-IMX307 BOTTOM
Features
  • Built-in ISP processing
  • USB2.0 Interface,USB Video Class(UVC)
  • Data fromat : YUY2 / MJPG / H.264
  • Standard lens mount
  • IR-CUT circuit
Thechnical Detail
Technical Details
SENSOR
Pixels 2.07M pixels
Resolution 1920*1080 MAX
SNR1s Value 0.24lx
ISP
YUY2 Frame Rate 640*360@25fps / 30fps
MJPG Frame Rate 1920*1080@25fps / 30fps, 1280*720@50fps / 60fps, 640*360@25fps / 30fps
H.264 Frame Rate 1920*1080@25fps / 30fps, 1280*720@50fps / 60fps, 640*360@25fps / 30fps
Exposure Auto or Manual
White Balance Auto or Manual
Slow Shutter Coming Soon
Lens & IR-CUT
Interface
Connector MX1.25*4,USB2.0 Interface
Communication Interface USB2.0,UVC Protocol
General
Power Supply 5VDC
Power Consumption 5VDC,1.5W MAX
Interface & Pin list
CS-USB-IMX307 TOP PIC
J1:USB2.0 Interface
1 VBUS(5V)
2 D-
3 D+
J3:Power Input, Used during firmware upgrade
1 5VDC IN
2 NC
3 NC
J4:Day/Night External Trigger
1 IR LED ON,Low level active
3 RESERVE
J6:IRCUT Control
1 IRCUT1
2 IRCUT2
J7:Trigger IN,Strobe OUT ( RESERVE )
1 Trigger IN
3 Strobe OUT
Board Dimension
CS-USB-IMX307 CAD drawing / unit : mm
Download dwg file here
