MV-MIPI-IMX265M Data Sheet
MV-MIPI-IMX265M is a 3.15M MONO industrial camera with MIPI interface.
MV-MIPI-IMX265M
  • 1/1.8'' 3.15M Pixel SONY IMX265LLR-C Pregius Global Shutter CMOS SENSOR
  • MIPI CSI-2 Interface
  • Mono-8、Mono-10,Mono-12 Data Format
  • Strobe synchronization
  • ROI
  • USER Output
MV-MIPI-IMX265M
3 Technical Detail
Technical Details
Sensor Type CMOS
Shutter Mode Global Shutter
Sensor SONY IMX265LLR-C Pregius
Color MONO
Image Size 1/1.8''
Unit Cell Size 3.45μm × 3.45μm
Resolution 2064(H) × 1544(V)
Max Frame Rate 2064×1544 @ 55fps
Shutter Mode AE,ME,AE Once
ADC Resolution 12 bit
Pixel Format Mono8,Mono10,Mono-12
ROI Support
Mirror Image Mirror and Flip
Electrical characteristics
Data Rate / lane:1.5Gbps
Power Supply 5VDC
Power Consumption 1W@ 5VDC
Structure
Lens Mount C-MOUNT01
Operating Conditions
Humidity Humidity 95% or less
Sensor Spectral Sensitivity
IMX265LLR-C
5 Interface & Pin list
MV-MIPI-IMX265M
MV-MIPI-IMX265M
Pin NO. NAME Remarks
2 VCC 5V
3 VCC 5V
4 VCC 5V
5 VCC 5V
6 GND
8 GND
9 MIPI_L0_N Lane 0 Negative
10 MIPI_L0_P Lane 0 Positive
11 GND
12 MIPI_L1_N Lane 1 Negative
13 MIPI_L1_P Lane 1 Positive
14 GND
15 MIPI_CK_N CLK Negative
16 MIPI_CK_P CLK Positive
17 GND
18 MIPI_L2_N Reserved
19 MIPI_L2_P Reserved
20 GND
21 MIPI_L3_N Reserved
22 MIPI_L3_P Reserved
23 GND
24 SCL I2C SCL, 3.3V Level
25 SDA I2C SDA, 3.3V Level
26 GPIO3 Reserved
30 GND
6 Board Dimension
Download 2D DXF file
7 PCBA 3D STP File
Download 3D STP file
