MV-MIPI-IMX287M Data Sheet
MV-MIPI-IMX287M is a 0.4M MONO industrial camera with MIPI interface.
- 1/2.9'' 0.4M Pixel SONY IMX287LLR-C Pregius Global Shutter CMOS SENSOR
- MIPI CSI-2 Interface
- Mono-8、Mono-10,Mono-12 Data Format
- Video streaming mode(Free Running),Trigger mode
- Strobe synchronization
- ROI
- USER Output
3 Technical Detail
Technical Details | |
Sensor Type | CMOS |
Shutter Mode | Global Shutter |
Sensor | SONY IMX287LLR-C Pregius |
Color | MONO |
Image Size | 1/2.9'' |
Unit Cell Size | 6.9μm × 6.9μm |
Resolution | 720(H) × 544(V) |
Max Frame Rate | 720×544 @ 530fps RAW8
Gain | 0 dB to 24 dB: Analog Gain (0.1 dB step)
Exposure Time | ≤ 1/(max frame rate) |
Shutter Mode | AE,ME,AE Once |
ISP | Bad Pixel Correction,8bit GAMMA,User Lookup Table |
ADC Resolution | 8,10,12 bit |
Pixel Format | Mono8,Mono10,Mono-12,UYVY 8bit |
ROI | Support, Min.Area :264x4 |
Mirror Image | Mirror and Flip |
Working Mode | Hardware Trigger,Software Trigger,Video streaming mode(Free Running) |
Trigger Mode | Trigger Filtering,Trigger Delay,Trigger Polarity Control |
Strobe Mode | Strobe Output Control,Strobe Delay,Strobe Polarity Control |
Electrical characteristics | |
Data Interface | CSI-2 : 2 Data Lanes
Data Rate / lane:1.5Gbps |
Communication Interface | I2C 3.3V |
Digital IO | Non-isolation IO:1 Trigger in,2 Multi-function output,3.3V Level |
Power Supply | 5VDC |
Power Consumption | 1W@ 5VDC |
Structure | |
Size | Length * width * height = 29*29*11mm |
Lens Mount | C-MOUNT01 |
Operating Conditions | |
Temperature | Operating temperature:-30℃~ 60℃ |
Humidity | Humidity 95% or less |
IMX287LLR-C |
5 Interface & Pin list
J3: CSI-2 Interface,Up Contact | ||
Pin NO. | NAME | Remarks |
1 | GND | |
2 | VCC | 5V |
3 | VCC | 5V |
4 | VCC | 5V |
5 | VCC | 5V |
6 | GND | |
7 | ENABLE | Power Enable,3.3V,ACTIVE High |
8 | GND | |
9 | MIPI_L0_N | Lane 0 Negative |
10 | MIPI_L0_P | Lane 0 Positive |
11 | GND | |
12 | MIPI_L1_N | Lane 1 Negative |
13 | MIPI_L1_P | Lane 1 Positive |
14 | GND | |
15 | MIPI_CK_N | CLK Negative |
16 | MIPI_CK_P | CLK Positive |
17 | GND | |
18 | MIPI_L2_N | Reserved |
19 | MIPI_L2_P | Reserved |
20 | GND | |
21 | MIPI_L3_N | Reserved |
22 | MIPI_L3_P | Reserved |
23 | GND | |
24 | SCL | I2C SCL, 3.3V Level |
25 | SDA | I2C SDA, 3.3V Level |
26 | GPIO3 | Reserved |
27 | OUT_IO2 | Multi-function Port 2,3.3V level |
28 | OUT_IO1 | Multi-function Port 1,3.3V level |
29 | TriggerIN_IO | Hardware Trigger in,3.3V level |
30 | GND |
