MV-MIPI-SC130M Version Log
1 How to get version
MV-MIPI-SC130M has two version number, Using shell script ,get version.
L version is logic version,C version is controller version.
2 Upgrade package download
CS Serials Camera Upgrade Images(Mediafire)
3 Version Log
  • MV-MIPI-SC130M_C1.35_L2.01_upgrade_20230925.bin
  1. Modify the operation logic of the ROI area and the Imgdir to first perform ROI sampling and then flipping. Adjust the corresponding DPC accordingly.
  • MV-MIPI-SC130M_C1.32_L2.00_upgrade_20230606.bin
  1. Increase the ISP bandwidth, which can achieve 1280x1024 @ 214fps in RAW8 format.
  2. Refine the DPC function.
  3. To achieve higher bandwidth, remove UYVY format.
  • MV-MIPI-SC130M_C1.26_L1.32_upgrade_20230208.bin
  1. Improve signal integrity of MIPI CSI-2.
  2. Improved AE and AG algorithms.
  • MV-MIPI-SC130M_C1.19_L1.30_upgrade.bin
  1. Change MIPI CSI-2 signal to clock discontinues mode.
  • MV-MIPI-SC130M_C1.15_L1.20_upgrade.bin
  1. Adjust the working mode of sensor to make the whole image processing process more stable.
  2. Support reading sensor register.
Note that L1.20 version cannot be upgraded by users from L1.10 version.
  • MV-MIPI-SC130M_C1.10_L1.10_upgrade.bin
  1. First release version.
