VEYE-MIPI-IMX327S DATA SHEET
The VEYE-MIPI-IMX327S is an updated version of the VEYE-MIPI-327(E). VEYE-MIPI-IMX327S features a compact single board design (38*38mm) for easy integration. The standard 15pin FPC user interface enables easy access to embedded platforms such as Raspberry Pi、Nvidia、NXP i.MX 8M.The function of automatic power switch is added,5V and 3.3V power supply can be automatically switched to 5V power supply, or you can freely choose 5V or 3.3V independent power supply.
- 1/2.8 inch 2 Mega STARVIS sensor IMX327LQR-C by SONY
- MIPI output: CSI-2
- Uncompressed UYVY / YUYV format, YUV422-8bit
- Standard lens mount
- IR-CUT circuit
- Framerate control
3 Thechnical Detail
Technical Details
SENSOR
Sensor
SONY IMX327LQR-C STARVIS
Pixels
2.07M pixels
Resolution
1920*1080
Image Size
Diagonal 6.46 mm (Type 1/2.8)
Unit Cell Size
2.9um (H)*2.9um(V)
Output Format
RAW Bayer
Shutter Type
Rolling Shutter
SNR1s Value
0.18lx
ISP
Frame Rate
1080p@25 / 1080p@30fps
Exposure
Auto or Manual
White Balance
Auto or Manual
Shutter
1/25(1/30)s to 1/50,000s
Slow Shutter
Support
Denoising
Image Setting
Brightness, Contrast, Sharpness, Saturation,Flip, Mirror
Image Enhancement
BLC, DOL-WDR, Defog
Day/Night Switch
Manual or IR-CUT filter with external trigger
Lens & IR-CUT
Lens
MTV12 / MTV16 / CS
Lens Mount
M12*P0.5 / M16*P0.5 / CS,IRCUT is optional
Mounting Hole
2 screw holes with diameter of 2.2mm,20mm Center-to-Center Spacing
Interface
Connector
15Pin 1.0mm pitch FPC, upper contact
Communication Interface
IIC, 3.3VDC
Video Data Interface
MIPI:2 Data Lanes, CSI-2
UYVY / YUYV format YUV422-8bit Data Type, Bandwidth 1.188Gbps
MIPI CSI-2 DC Specifications
IR-CUT Control
IR-CUT motor control, 3.3VDC
Day/Night External Trigger
3.3VDC to 12VDC compatibility
General
Operating Conditions
(Bare PCB)
Power Supply
3.3VDC or 5VDC
Power Consumption
Usually: 1.1W
IR_CUT action switching moment: 1.6W
Dimension
38mm*38mm*11mm(not include lens and lens mount)
Sensor
IMX327LQR-C
5 Connector Pinlist
J3:CSI-2 Interface
Pin NO.
NAME
Remarks
GND
MIPI_L0_N
MIPI_L0_P
GND
MIPI_L1_N
MIPI_L1_P
7
GND
8
MIPI_CK_N
9
MIPI_CK_P
10
GND
11
RST
NOT USE,Circuit disconnection
12
NC
13
SCL
3.3V level
14
SDA
3.3V level
15
VCC3V3
PWR IN
J2 : Day/Night External Trigger
Pin NO.
NAME
Remarks
Day&Night Signal In
INPUT,Active Low(Image to MONO),3.3VDC to 12VDC compatibility
GND
NC
J4 : IRCUT Control Functional specifications
MODE
Pin NO.
PIN NAME
Signal polarity
Image type
Filter position
Mode 1
IRCUT1
color
Infrared cutoff
IRCUT2
Mode 2
IRCUT1
mono
Full wavelength pass
IRCUT2
J6:5VDC INPUT
Pin NO.
NAME
Remarks
5VDC
GND
J7:Auxiliary IIC
Pin NO.
NAME
Remarks
AUX_SCL
GND
AUX_SDA
6 Board Dimension
download dwg file
7 PCBA 3D STP File
download 3D STP file
