VEYE-MIPI-IMX385 Data Sheet
VEYE-MIPI-IMX385 DATA SHEET
VEYE-MIPI-IMX385 is a large Imaging size starlight video streaming module, using a compact design (38*38mm) to facilitate user integration, standard 15pin FPC user interface, easy access to embedded platforms such as raspberry pi and Nvidia.
VEYE-MIPI-IMX385
  • 1/2 inch 2 Mega sensor IMX385LQR-C by SONY
  • MIPI output: CSI-2
  • IR-CUT circuit
  • Framerate control
  • Also support 5V, 3.3V independent power supply
VEYE-MIPI-IMX385
3 Thechnical Detail
Technical Details
SENSOR
Sensor SONY IMX385LQR-C STARVIS
Pixels 2.07M pixels
Resolution 1920*1080
Image Size Diagonal 8.35 mm (Type 1/2)
Unit Cell Size 3.75um (H) * 3.75um(V)
Output Format RAW Bayer
Shutter Type Rolling Shutter
SNR1s Value 0.13lx
ISP
Exposure Auto or Manual
White Balance Auto or Manual
Slow Shutter Support
Image Enhancement BLC, DOL-WDR
Lens & IR-CUT
Lens YT1.0-5.1-1/1.8-8M
Lens Mount
Mounting Hole 2 screw holes with diameter of 2.2mm,21.6mm Center-to-Center Spacing
Interface
Video Data Interface MIPI:2 Data Lanes, CSI-2 YUV422-8bit Data Type, Bandwidth 1.188Gbps
MIPI CSI-2 DC Specifications
General
Operating Conditions
(Bare PCB)
Power Supply 3.3VDC or 5VDC
Power Consumption Usually: 1.3W
IR_CUT action switching moment: 1.7W
Dimension 38mm*38mm*11mm(not include lens and lens mount)
Sensor Spectral Sensitivity
IMX385LQR-C
IMX385LQR-C Spectral Sensitivity
5 Connector Pinlist
VEYE-MIPI-IMX385
VEYE-MIPI-IMX385
J3:CSI-2 Interface
Pin NO. NAME Remarks
2 MIPI_L0_N
3 MIPI_L0_P
5 MIPI_L1_N
6 MIPI_L1_P
8 MIPI_CK_N
9 MIPI_CK_P
11 RST Active Low,reset camera module
12 NC
13 SCL 3.3V level
14 SDA 3.3V level
15 VCC3V3 PWR IN
J2 : Day/Night External Trigger
3 NC
2 IRCUT2 +
2 IRCUT2 -
J6:5VDC INPUT
1 5VDC
J7:Auxiliary IIC
1 AUX_SCL
3 AUX_SDA
6 Board Dimension
CAD drawing unit : mm
下载dwg图纸
7 PCBA 3D STP File
download 3D STP file
