Gx mipi i2c.sh user guide
2 Download
Below is the list:
3 Prepare
cd gx_i2c_tools/sources/
make
cd ..
4 Runtime Environment Verification​
Before executing the main logic, retrieve the camera version information and verify that a reasonable value is returned.
A valid response indicates that the camera is accessible and the script runtime environment is properly set up.
5 gx_mipi_i2c.sh USAGE
$ ./gx_mipi_i2c.sh
    -r                       read
6 i2c bus number on different board
7 Common Questions Regarding Scripts
8 Functions list
8.1 Note
8.2 Basic Parameters
8.2.1 manufacturer
8.2.2 model
8.2.3 sensorname
8.2.4 version
8.2.5 serialno
8.2.6 timestamp
8.2.7 errcode
reserved
8.2.8 fmtcap
bit3: Mono14 (reserved)
bit5: RGB888
bit7: YUYV
8.2.9 readmodecap
bit0: Normal
bit1: binning mode
bit2: subsampling mode
8.2.10 workmodecap
bit0: Video streaming mode
bit1: Normal trigger mode.
bit3: Pulse trigger mode.
8.2.11 lanecap
8.2.13 temp
Get the temp is 25K
8.2.14 videomodecap
Get the videomodecap is 2
value description
bit0 ROI mode
bit1 VideoMode mode
8.2.15 videomodenum
Get the videomodenum 1
value description
0 ordinary
1 binning
2 subsampling
8.2.18 factoryparam
8.2.19 paramsave
8.2.20 reboot
Reboot the camera.
8.3 Image Acquisition
8.3.1 imgacq
Start/Stop acquisition
8.3.2 workmode
value description
0 Video streaming mode
1 Normal trigger mode
8.3.3 trgsrc
value description
0 Software trigger
1 Hardware trigger
8.3.4 trgnum
8.3.5 trginterval
8.3.6 trgone
8.3.7 trgcount
Trigger count statistics.
Clear trigger count.
8.3.8 i2caddr
8.3.9 nondiscontinuousmode
0: discontinuous mode
1: continuous mode
8.3.10 slavemode
Whether the sensor is operating in slave mode. In slave mode, the camera relies on external signals to provide XVS.
8.3.11 framecount
Sensor_Frame_Count:
Out_Frame_Count:
8.3.12 triggercyclemin
Get the Minimum trigger signal period, in microseconds (µs), with 0 indicating an invalid value.
8.3.13 daynightmode
daynightmode type
value description
0 Color mode
1 Black and white mode
2 External trigger mode
8.3.14 ircutdir
8.3.15 pinpolarity
8.3.16 ircuttimer
8.4 Image Properties
8.4.1 testimg
value description
0 Common image
1 Vertical color stripes
8.4.2 pixelformat
value description
0 Mono8
1 Mono10
2 Mono12
3 Mono14 (reserved)
4 UYVY
5 RGB888
6 Temp (reserved)
7 YUYV
8.4.3 maxwh
8.4.4 minwh
8.4.5 maxfps
8.4.6 minfps
8.4.7 curwh
8.4.8 imgdir
Image orientation:
value description
0 normal
1 mirror
2 flip
3 flip&mirror
8.4.9 videomode
8.4.10 readmode
image model:
value description
0 normal mode
1 2x2binning mode
2 subsampling mode
8.4.11 lanenum
value description
2 2lane
4 4lane
8.4.12 mipidatarate
8.4.13 fps
Range:(0,maxfps].
8.5 Image Processing
8.5.1 expmode
Exposure type
value description
0 manual exposure
2 auto exposure
8.5.2 aetarget
8.5.3 aestrategy
Automatic exposure strategy
value description
8.5.4 metime
Unit: microseconds.
8.5.5 aemaxtime
./gx_mipi_i2c.sh -w aemaxtime [param] -b your_i2c_bus_number
Maximum exposure time in auto exposure mode.
param: Since this parameter is used for automatic frame rate reduction, no range limit is set here.
8.5.6 exptime
Unit: microseconds.
8.5.7 curgain
8.5.8 mgain
8.5.9 aemaxgain
8.5.10 wbmode
wbmode type
value description
0 manual white balance
2 auto white balance
8.5.11 awbcolortempmin
8.5.12 awbcolortempmax
8.5.13 mwbbgain
8.5.14 mwbrgain
8.5.15 colortemp
Current color temperature (k)
8.5.16 currgain
8.5.17 curbgain
8.5.18 aemintime
./gx_mipi_i2c.sh -w aemintime [param] -b your_i2c_bus_number
Minimum exposure time in auto exposure mode.
8.5.19 gamma_index
1: Default gamma.
2: gamma_1.6
3: gamma_1.8
4: gamma_2.0
5: gamma_2.2
6: Style 1
7: Style 2
8: Style 3
9: Style 4
10: Style 5
11: Style 6
12: User-defined gamma (TODO)
8.5.20 antiflicker
param2:
Anti-flicker frequency.
8.5.21 wdrparam
param2:WDR intensity [0-255]
8.5.22 sharppen
Sharpening intensity [0-255]
8.5.23 denoise2d
./gx_mipi_i2c.sh -r denoise2d -b your_i2c_bus_number
./gx_mipi_i2c.sh -w denoise2d [0,255] -b your_i2c_bus_number
8.5.24 denoise3d
./gx_mipi_i2c.sh -r denoise3d -b your_i2c_bus_number
./gx_mipi_i2c.sh -w denoise3d [0,255] -b your_i2c_bus_number
8.5.25 saturation
Saturation [0-100]
8.5.26 contrast
contrast [0-100]
8.5.27 hue
hue [0-100]
8.5.28 slowshutter
./gx_mipi_i2c.sh -w slowshutter [0/1] [20] -b your_i2c_bus_number
Parameter 2: Sets the gain threshold at which frame rate reduction starts in automatic frame rate reduction mode. The unit is 0.1 dB.
In low-light environments, this results in lower noise, but the frame rate will be reduced.
8.5.29 ldc
8.5.30 dehaze
8.5.31 drc
8.5.32 snsreg
./gx_mipi_i2c.sh -r snsreg [sensor reg addr] -b your_i2c_bus_number
8.6 IO Control
8.6.1 trgdelay
8.6.2 trgedge
value description
0 Rising edge
1 Falling edge
8.6.3 trgexp_delay
8.6.4 outio1_rvs
9 Notes
10.1 Stream mode:
10.2 Trigger mode:
10.3 Sync mode:
