C-MOUNT01
1 Product Picture 产品图片
| Product Picture 产品图片 | Product Picture 产品图片 | Camera Support 支持的相机 |
| MV-MIPI-IMX178M |
2 Attention 注意事项
2.1 Overview 概述
C-MOUNT01仅仅是一个C-MOUNT镜头固定座,为了适配MV系列和RAW系列摄像机,实际后焦法兰焦距略小于17.526mm,配合不同型号的摄像机模组,需要将镜头向远离传感器的方向调整。具体数值需要根据传感器的成像面高度决定。
C-MOUNT01 is only a C-MOUNT lens mount. In order to fit the MV series and RAW series camera, the actual Flange BFL distance is less than 17.526mm. With different camera modules,
| Not adjusted / 未调整 | Adjusted / 向外调整 |
Da = Dc - ( H - Ds )
C-MOUNT01高度 / The Height of C-MOUNT01:H= 18mm
| Part NO. / 型号 | Ds (mm) | Da(mm) |
| MV-MIPI-IMX296M | 0.92 | 0.446 |
| MV-MIPI-IMX178M | 0.92 | 0.446 |
| 0.92 | 0.446 | |
| 0.92 | 0.446 | |
| 0.92 | 0.446 | |
| 0.62 | 0.146 | |
| MV-MIPI-SC130M | 0.6 | 0.126 |
3 Dimension 尺寸图
