CS-LAMP-IR Data Sheet
The CS-LAMP-IR module is a light source for the camera module, which is started when the ambient light brightness is insufficient at night to provide necessary brightness for the camera and improve the imaging effect of the camera module.
The light source of the CS-LAMP-IR module is infrared light with a wavelength of about 850nm.The module has a built-in ambient illumination sensor.
When the ambient light reaches the specified illumination, the module automatically turns on the infrared light, and outputs a synchronization signals to the camera module to inform the camera module to switch day and night mode.
2 Technical Detail
Technical Detail
Remarks
Power Supply
DC5V
Power Consumption
550mW
Detection Wavelength
390nm~700nm
IR LED Wave Length
850nm
3 Interface & Pin list
J1、J4 、J5 pins are connected in parallel, please choose them according to the situation.
J1
Pin NO.
NAME
Remarks
DC 5V
PWR
GND
J2
Pin NO.
NAME
Remarks
NIGHT_O
OUTPUT, Active High
GND
NIGHT_O_n
OUTPUT, Active Low, Open-Collector
J4
Pin NO.
NAME
Remarks
DC 5V
PWR
GND
J5
Pin NO.
NAME
Remarks
DC 5V
PWR
GND
4 Board Dimension
CS-LAMP-IR CAD drawing / unit : mm
Download dwg file here
