MV Camera on Firfly Boards
This article takes Firefly's ROC-RK3566-PC,ROC-RK3576-PCand ROC-RK3588S-PC board as an example to introduce how to connect MV and RAW series cameras to the RK3566/3K3568 ,RK3576 and RK3588S/RK3588 system.
MV series MV-MIPI-SC130M Done
In addition, the driver for the V-by-One HS connection mode has been finished on the Ubuntu system.
2.1 Connection of new ADP-MV2
2.1.1 Connection of MV series camera and ADP-MV2
ADP-MV2 to MV-MIPI-X
2.1.2 Connection of RAW-MIPI-SC132M and ADP-MV2
The two are connected using 1.0 mm pitch*15P FFC cable with opposite-side contacts. The cable must be inserted with the silver contacts facing outside.
ADP-MV2 to RAW-MIPI-SC132M
2.1.3 Connection of other RAW series camera and ADP-MV2
ADP-MV2 to RAW series camera
2.1.4 Connection with Main board using ADP-MV2
The two are connected using 0.5mm pitch * 30P FFC coaxial wires, paying attention to the direction of the contact surfaces, silver contacts facing outside on the ADP-MV2 and facing inside on the RK board.
RK to ADP-MV2 and MV cam
2.2 V-by-One-HS-KIT Camera Connection Diagram
VBYONE connection with rk3588
includes:
  • driver source code
  • i2c toolkits
  • application demo
For the ROC-RK3566-PC,ROC-RK3576-PC and ROC-RK3588S-PC, we have provided an image of the release system.
Download the latest Ubuntu imge from https://github.com/veyeimaging/rk35xx_firefly/releases/ .
Refer to the Firefly documentation ROC-RK3588S-PC ROC-RK3566-PC ROC-RK3576-PC to burn in a standard system.
5 Check system status
On the ROC-RK3588S-PC, the camera is mounted on i2c-7, with an i2c address of 0x3b.
On the ROC-RK3566-PC and ROC-RK3576-PC, the camera is mounted on i2c-4.
You should see:
7 References
  • ROC-RK3566-PC Manual
  • ROC-RK3588S-PC Manual
  • ROC-RK3576-PC Manual
  • Firefly Linux User Guide
8 Document History
  • 2025-12-26
Add a chapter on application development guidelines
  • 2025-04-14
Add support for RK3576.
  • 2025-03-23
  • 2024-07-09
  • 2024-04-17
Support RK3566.
  • 2024-03-10
Add pictures and descriptions of hardware connections for the new version of ADP-MV2.
  • 2023-08-30
  • 2023-07-31
  • 2023-04-12
