MV Series MIPI Camera Register Map
1.1 Register Features
The module supports parameter configuration via i2c protocol. The default i2c slave address of the camera is 0x3b(7-bit slave addr) which can be modified.
1.3 Update timing
-: Read only at any time.
1.4 Raw series Support
It contains an MCU, which is used for sensor mode configuration and trigger timing generation.
N:Not support.
S:Support in normal mode.
2 Basic Parameters
| Address | Name | Description | Data Type | R/W | Update timing | script function | Raw series Support |
| 0x0000 | Manufacturer Name | String containing the self-describing name of the manufacturer. “VEYE” | ascii | RO | - | manufacturer | S |
| 0x0004 | Model Name | Product Model Code.
enum | RO | - | model | S |
| 0x0008 | Sensor Name | Sensor Model:
0x178 : IMX178LLJ 0x130 : SC130GS 0x265 : IMX265LLR 0x264 : IMX264LLR 0x296 : IMX296LLR 0x287 : IMX287LLR 0x132 : SC132GS 0x234 : AR0234CS 0x462 : IMX462LLR 0x535 : SC535HGS 0x4002 : GMAX4002-AVM |
enum | RO | - | S | |
| 0x000C | Serial Number | Unique product serial number | uint | RO | - | S | |
| 0x0010 | Device Version | Firmware version number. The high 16 bits are the Control version and the low 16 bits are the Logic version.
uint | RO | - | version | S |
| 0x0014 | Factory Param | All parameters restored to factory default values.
This operation will erase the system flash and rewrite it. Please ensure that the power is not interrupted during the operation. Additionally, it is recommended not to perform frequent factoryparam operations. |
bool | WO | A | factoryparam | S |
| 0x0018 | Param save to flash | Save all parameters to flash, and they will not be lost when power off.
This operation will erase the system flash and rewrite it. Please ensure that the power is not interrupted during the operation. Additionally, it is recommended not to perform frequent paramsave operations. |
bool | WO | A | paramsave | S |
| 0x001C | System reboot | Reboot the camera. | bool | WO | A | reboot | S |
| 0x0020 | Time stamp | Time after system startup in Milliseconds. | uint | RO | - | timestamp | S |
| 0x0024 | Error Code | System error code, each bit represents an error type.
uint | RO | - | errcode | S |
| 0x0028 | Format Cap | Capbility of data formats supported by the camera.
bit0: Mono8 bit1: Mono10 bit2: Mono12 bit3: Mono14 bit4: UYVY bit5: Temperature sensor |
uint | RO | - | fmtcap | S |
| 0x002C | ReadModeCap | Capbility of read mode supported by the camera.
bit0: Normal bit1: Binning bit2: Subsampling |
uint | RO | - | readmodecap | S |
| 0x0030 | TriggerMode Cap | Capbility of trigger mode supported by the camera.
bit0:Video streaming mode bit1:Normal trigger mode. bit2:Rolling shutter multi-frame trigger mode. bit3: Pulse trigger mode. |
| 0x0034 | LaneNumCap | The number of MIPI lanes supported by the camera .
The lower to higher bits correspond to the supported capabilities for 1 lane, 2 lanes, 3 lanes, and 4 lanes, respectively. For example, 0x2 indicates support for 2 lanes, and 0xA indicates support for both 2 lanes and 4 lanes. |
uint | RO | lanecap | S | |
| 0x0038-
0x0054 |
Camera name | String containing the self-describing name of the camera. | string | RO | NA | S | |
| 0x0058 | Temperature K | The sensor's temperature value, in Kelvin, is 100 times the current temperature. | uint | RO | temp | S |
3 Image Acquisition
| 0x0400 | Image Acquisition | Start/Stop acquisition
bool | WO | A | imgacq | S |
| 0x0404 | Trigger Mode | 0:Video streaming mode
enum | RW | S | trgmode | S |
| 0x0408 | Trigger Source | 0: Software trigger mode.
enum | RW | S | trgsrc | S |
| 0x040C | Trigger Number | The number of image frames output by one trigger signal in trigger mode. Range:[1.255] | uint | RW | S | trgnum | S |
| 0x0410 | Trigger Interval | Trigger interval in normal trigger mode, in microseconds. Range:[0.0xFFFFFF] | uint | RW | S | trginterval | S |
| 0x0414 | Trigger Software | Software trigger command, write 1 for one trigger. | bool | WO | A | trgone | S |
| 0x0418 | Trigger Count | Trigger count statistics.
| 0x041C | I2C ADDR | I2c address. Range[0x03,0x77]. | uint | RW | A | i2caddr | S |
| 0x0424 | MCU bypass mode | For RAW series ONLY! Once enabled, the mcu no longer controls the sensor and the user controls the sensor directly.
Automatic restart after change. |
bool | RW | A | mcubypass | S |
| 0x044C | Non discontinuous mode | Indicates whether the clock lan of the mipi signal is in continuous clock mode. 0 : discontinuous mode,1: continuous mode | bool | RO | A | clkmode | S |
| 0x0450 | Sensor Register Addr | Indirectly read the sensor register function. Write the address of the sensor register to be read to this register. | uint | WO | A | snsreg | S |
| 0x0454 | Sensor Register Value | Read the sensor register value. | uint | RO | A | snsreg | S |
| 0x0460 | Slave mode | Whether the sensor is operating in slave mode. Currently, only RAW-MIPI-IMX462M is supported. | bool | RW | S | slavemode | S |
| 0x0464 | Sensor Frame Count | The number of frames output by the sensor. Cyclic counting. | uint | RO | A | framecount | N |
| 0x0468 | Out Frame Count | The number of frames output by the camera module. Cyclic counting. | uint | RO | A | framecount | N |
| 0x046C | Min Trigger cycle | Minimum trigger signal period, in microseconds (µs), with 0 indicating an invalid value.
In pulse trigger mode, it represents the minimum interval between the end of the previous trigger level and the next trigger signal. |
uint | RO | A | trgcycle | S |
| 0x0470 | Max Trigger cycle | Maximum trigger signal period, in microseconds (µs), with 0 indicating an invalid value. (Valid in continuous trigger mode of SC535). | uint | RO | A | trgcycle | S |
4 Image Features
| 0x0800 | Test Image Selector | Switch between normal image or test image
0 : Normal image 1 : Test image 1 2 : Test image 2 |
uint | RW | A | testimg | S |
| 0x0804 | Pixel Format | 0 : Mono8
| 0x0808 | Sensor Width | The maximum width supported by the sensor | uint | RO | - | maxwh | S |
| 0x080C | Sensor Height | The maximum height supported by sensor | uint | RO | - | maxwh | S |
| 0x0810 | MaxFrame Rate | The maximum frame rate supported in the current mode.
The register value is 100 times the frame rate. |
uint | RO | - | maxfps | S |
| 0x0814 | Framerate | The current framerate.
uint | RW | S | fps | S |
| 0x0818 | ROI Width | ROI Width | uint | RW | S | roi | S |
| 0x081C | ROI Height | ROI Height
| 0x0820 | ROI Offset X | ROI Offset X | uint | RW | S | roi | S |
| 0x0824 | ROI Offset Y | ROI Offset Y | uint | RW | S | roi | S |
| 0x0828 | Image Direction | 0 : normal
enum | RW | A | imgdir | S |
| 0x0830 | Black Level | Black level | uint | RW | A | blacklevel | S |
| 0x0834 | BLC mode | Black level calibration modes:
uint | RW | A | blcmode | S |
| 0x0838 | Read Mode | Read mode:
0: Normal 1: Binning 2: Subsampling |
uint | RW | A | readmode | S |
| 0x083C | Lane Num | For modules that support lane number configuration, use this register to modify the lane number. | uint | RW | S | lanenum | S |
| 0x0840 | MIPI Datarate | The MIPI datarate for each lane, measured in Kbps. | uint | RO | - | mipidatarate | S |
| 0x0844 | Min Width | The minimum width supported by the camera. | uint | RO | A | minwh | S |
| 0x0848 | Min Height | The minimum height supported by the camera. | uint | RO | A | minwh | S |
| 0x084C | Min Frame Rate | The minimum framerate supported by the camera. The value is 10000 times the actual framerate. | uint | RO | A | minfps | S |
| 0x0850 | Framerate_EX | The extended register of the Framerate register, where the value is 10,000 times the actual frame rate. | uint | RW | S | fps_ex | S |
| 0x0854 | OSD_Mode | OSD mode bit definition:
0: Disabled 1: Crosshair enabled, overlays a crosshair at the center of the image for assisting with coordinate calibration. |
uint | RW | A | osdmode | N |
5 ISP
| 0x0C00 | ISP module ctrl | The ISP module controls, each bit represents an isp function.
uint | RW | A | gammaenable,
dpcenable, lutenable, |
N |
| 0x0C04 | Exposure Mode | Exposure Type
enum | RW | A | expmode | N |
| 0x0C08 | Target Brightness | Target brightness for automatic exposure. Range[0,255] | uint | RW | A | aatarget | N |
| 0x0C10 | ME Time | Manual exposure time,effective in ME mode. Range[16,1000000]. Note1.Unit: microseconds. | uint | RW | A | metime | S |
| 0x0C14 | AE MAX Time | Maximum exposure time in AE mode.Range[16,1000000]. Note1.Unit: microseconds. | uint | RW | A | aemaxtime | N |
| 0x0C18 | Exp Time | Current exposure time. Note1.Unit: microseconds. | uint | RO | - | exptime | S |
| 0x0C1C | Gain Mode | Gain Type
| 0x0C20 | Manual Gain | Manual gain, ,effective in MG mode. Note2. | uint | RW | A | mgain | S |
| 0x0C24 | AG Max Gain | Maximum value of auto gain. Note2. | uint | RW | A | agmaxgain | N |
| 0x0C28 | Cur Gain | Current Gain. Note2. | uint | RO | - | curgain | S |
| 0x0C2C | AAROIOffsetX | AAROI offset X. Note4. | uint | RW | A | aaroi | N |
| 0x0C30 | AAROIOffsetY | AAROI offset Y. Note4. | uint | RW | A | aaroi | N |
| 0x0C34 | AAROIWidth | AAROI Width. Range: [16,ROI Width] | uint | RW | A | aaroi | N |
| 0x0C38 | AAROIHeight | AAROI Height. Range: [16,ROI Height] | uint | RW | A | aaroi | N |
| 0x0C60 | Gamma | gamma. The value is 100 times the actual gamma. 80 means gamma is 0.8. | uint | RW | A | gamma | N |
| 0x0C74 | LUT Count | The length of the lut curve 1024 or 4096. | uint | RO | - | lut | N |
| 0x0C78 | LUT Start | lut curve start transmission. | bool | WO | A | lut | N |
| 0x0C7C | LUT Done | lut curve writing finished. | bool | WO | A | lut | N |
| 0x0C80 | AAROI enable | Whether to enable AAROI statistics function, not enable means full ROI statistics. | bool | RW | A | aaroienable | N |
| 0x0C8C | Max Exp Time | Maximum exposure time in the current mode
Unit: microseconds |
uint | RO | A | exptime_range | S |
| 0x0C90 | Min Exp Time | Minimum exposure time in the current mode
Unit: 0.1 microseconds |
6 IO Control
| 0x1000 | Trigger Delay | Trigger delay. Trigger delay. Effective in both soft trigger and hard trigger modes.
range: 0 to 1000000 (unit: microsecond) |
uint | RW | S | trgdelay | S |
| 0x1004 | Trigger Edge | 0: Rising edge
1: Falling edge |
uint | RW | S | trgedge | S |
| 0x1008 | Trigger Filter Enable | 0: No filtering
| 0x100c | Trigger Filter Width | Trigger signal filtering window width
| 0x1010 | Exposure Delay | Exposure delay, i.e. the time to turn on the Strobe signal in advance.
| 0x1014 | TriggerIN IO status | TriggerIN_IO pin status. | enum | RO | - | gpios_status | S |
| 0x1020 | GPIO1_OutSelect | 0: Strobe
1: UserOut |
| 0x1024 | GPIO1 UserOut | User-defined OUT_IO1 output signal. | enum | RW | A | outio1_usr | N |
| 0x1028 | GPIO1 Reverse | OUT_IO1 signal reversal. | bool | RW | A | outio1_rvs | N |
| 0x102C | GPIO1 OutStatus | OUT_IO1 pin status. | enum | RO | - | gpios_status | N |
| 0x1030 | GPIO2_OutSelect | 0: Strobe
1: UserOut 2: TriggerWait; trigger wait status. Indicate that the camera is not busy now, able to respond to the trigger signal. 3: XVS 4: XHS |
| 0x1034 | GPIO2 UserOut | User-defined OUT_IO2 output signal. | enum | RW | A | outio2_usr | N |
| 0x1038 | GPIO2 Reverse | OUT_IO2 signal reversal. | bool | RW | A | outio2_rvs | N |
| 0x103C | GPIO2 OutStatus | OUT_IO2 pin status. | enum | RO | - | gpios_status | N |
7 Special Block Area
0x1800-0x37FF : lut area.
