V-by-One-HS-TX
V-by-One-HS-TX Data Sheet (V-by-One-HS-TX数据手册)
1 Product Picture(产品图片)
PART NUMBER / 型号 FRONT VIEW / 正面图片 BACK VIEW / 背面图片
V-by-One-HS-TX
2 Thechnical Detail (技术规格)
V-by-One-HS-TX serializer 串化
IC PART NO. 器件型号 THCV241A-P
Function 功能 MIPI CSI-2 to V-by-One HS conversion
Input Compatibility 输入兼容 MIPI CSI-2
Output Compatibility 输出兼容 V-by-One HS standard version1.5
Interface 接口
MIPI INPUT MIPI CSI-2,Supports up to 1.5Gbps/lane,Supports 2 or 4 lanes
MIPI INPUT Connector FFC socket(J1 / J2)
V-by-One HS OUTPUT V-by-One HS,Supports up to 4.0Gbps(effective rate 3.2Gbps),Supports 1 or 2 lanes
V-by-One HS OUTPUT Connector FAKRA Z Compatibility ( J3 / J6)
GPIO 2 output,1 input
Communication Interface Sub link
General 通用
Operating Conditions
(Bare PCB)
Operating guarantee temperature:-20℃~85℃, Humidity 95% or less, non-condensing
POC DC Power Input DC 9-15V (Only J2 is powered by POC)
Dimension 29mm*37mm
V-by-One-HS-TX pin list
V-by-One-HS-TX Pin List
3 Board Pinlist(接口和引脚说明)
J4
1 GPIO0 3.3V Level,Connect to THCV241 GPIO0
3 NC
J5
1 GPIO2 3.3V Level,Connect to THCV241 GPIO2
3 GPIO3 3.3V Level,Connect to THCV241 GPIO3
J3(TX0)V-by-One HS & POC interface(POC接口)
Connector(接插件) Interface Definition(接口定义)
FAKRA Z
+:V-by-One HS & POC signal -:GND
J5(TX1)V-by-One HS interface
FAKRA Z
+:V-by-One HS -:GND
J1 : Connect to RAW Series Camera
1 VCC3V3 3.3V PWR IN
2 SDA 3.3V Level
3 SCL 3.3V Level
5 NC
6 ENABLE Connect to THCV241 GPIO1 with Pull up Resistance
8 MIPI_L3_P
9 MIPI_L3_N
11 MIPI_L2_P
12 MIPI_L2_N
13 GND
14 MIPI_CK_P
15 MIPI_CK_N
16 GND
17 MIPI_L1_P
18 MIPI_L1_N
19 GND
20 MIPI_L0_P
21 MIPI_L0_N
22 GND
J2 : Connect to MV Series Camera
2 VCC5V 5V PWR IN
3 VCC5V 5V PWR IN
4 VCC5V 5V PWR IN
5 VCC5V 5V PWR IN
6 GND
7 ENABLE Connect to THCV241 GPIO1 with Pull up Resistance
8 GND 3.3V LEVEL
9 MIPI_L0_N 3.3V LEVEL
10 MIPI_L0_P
11 GND 3.3V Level
12 MIPI_L1_N 3.3V Level
13 MIPI_L1_P
14 GND
15 MIPI_CK_N
16 MIPI_CK_P
17 GND
18 MIPI_L2_N
19 MIPI_L2_P
20 GND
21 MIPI_L3_N
22 MIPI_L3_P
23 GND
24 SCL
25 SDA
26 NC
27 GPIO3 Connect to THCV241 GPIO3
28 GPIO2 Connect to THCV241 GPIO2
29 GPIO0 Connect to THCV241 GPIO0
30 GND
4 Board Dimension(板子尺寸)
V-by-One-HS-TX CAD / unit:mm
Download CAD file here
5 PCBA 3D STP File
Download 3D STP file
