VEYE CS Camera on Radxa Boards
How to use VEYE series cameras on Radxa's RK35XX board
VEYE series cameras are the video streaming mode MIPI cameras we designed. This article takes Radxa's ZERO 3W board as an example to introduce how to connect VEYE series cameras to RK3566/RK3568/RK3588 system.
We provide drivers for Linux.
In addition, the driver for the Fpdlink connection mode has been finished on the Linux system.
Radxa ZERO 3W provides a 22-pin connector compatible with Raspberry Pi, allowing our camera to be installed on its motherboard without the need for an adapter board.
2.1 Connection of Camera and Radxa ZERO 3W Board
Both use a 15-to-22-pin FFC cable for connection, ensuring that the silver contact surface faces outward.
VEYE camera connect to Radxa ZERO 3W
includes:
  • driver source code
  • i2c toolkits
  • application demo
In addition, a compiled linux kernel installation package is provided in the releases.
4 Upgrade Radxa Debain system
4.1 Overview
On the RK35xx board,
Download the latest rk356x_Radxa_ubuntu.tar.gz from https://github.com/veyeimaging/rk35xx_Radxa/releases/ .
cd rk356x_radxa_zero3w/released_images/cam2m
sudo dpkg -i linux-headers-5.10.160-36-rk356x_5.10.160-36_arm64_cam2m.deb
sudo dpkg -i linux-image-5.10.160-36-rk356x_5.10.160-36_arm64_cam2m.deb
5 Check system status
  • VEYE-MIPI-XXX
sudo dmesg | grep veye
veyecam2m 2-003b:  camera id is veyecam2m
veyecam2m 2-003b: sensor is IMX327
For Radxa Zero 3W, the camera is connected to i2c-2.
6 Application examples
6.1 v4l2-ctl
6.1.1 Install v4l2-utils
6.1.2 List the data formats supported by the camera
6.1.3 Snap YUV picture
For RK3566, also:
You can use software like YUV Player or Vooya to play the images.
6.1.4 Check frame rate
6.2 yavta
6.3 gstreamer
6.4 Import to OpenCV
First install OpenCV:
  • RK356x
  • VEYE series
9 References
  • Radxa Zero 3W Manual
  • BSP toolkit
10 Document History
  • 2024-04-24
