ADP-MYiR Adapter Board for MYiR-tech
Adapter Board:ADP-MYiR DATA SHEET
转接板:ADP-MYiR数据手册
1 Introduction 产品介绍
ADP-MYiR是一款转接板,可将VEYE系列和CS系列符合15Pin接口转换为米尔科技24Pin Camera接口。
The ADP-Myir is a adpter board that converts VEYE / CS Series camera module 15Pin interface to MYiR 24Pin Camera interface.
2 Product Picture 产品图片
| PART NUMBER / 型号 | FRONT VIEW / 正面图片 | BACK VIEW / 背面图片 | Adapter camera module / 适配摄像机模组 |
| ADP-MYiR | CS-MIPI-SC132 |
3 Adapter Board Pinlist 引脚说明
| J1:UP contact,5cm FFC,connect with VEYE/CS camera module
J1:上接触,标配5厘米异面FFC,与VEYE/CS系列模组互联 | ||
| 2 | MIPI_L0_N | |
| 3 | MIPI_L0_P | |
| 5 | MIPI_L1_N | |
| 6 | MIPI_L1_P | |
| 8 | MIPI_CK_N | |
| 9 | MIPI_CK_P | |
| 11 | RESERVE | NC |
| 12 | RESERVE | NC |
| 13 | SCL | 3.3V电平标准 |
| 14 | SDA | 3.3V电平标准 |
| 15 | VCC | 3.3V输出 |
| J2:Down contact,24Pin 20cm FFC,connect with MYiR 24Pin connector
J2:下接触,标配24Pin 20cm同面FFC,与米尔科技24Pin Camera互联 | ||
| 1 | MIPI_L0_N | |
| 2 | MIPI_L0_P | |
| 3 | GND | |
| 4 | MIPI_L1_N | |
| 5 | MIPI_L1_P | |
| 6 | GND | |
| 7 | MIPI_CK_N | |
| 8 | MIPI_CK_P | |
| 9 | GND | |
| 10 | NOT USE | |
| 11 | NOT USE | |
| 12 | GND | |
| 13 | NOT USE | |
| 14 | NOT USE | |
| 15 | GND | |
| 16 | NOT USE | |
| 17 | GND | |
| 18 | CAM_PWDN | REVERSE |
| 19 | NOT USE | |
| 20 | SCL | 1.8V电平标准 |
| 21 | SDA | 1.8V电平标准 |
| 22 | NOT USE | |
| 23 | NOT USE | |
| 24 | VCC5V | 5V输入 |
