ADP-Tfirefly
Adapter Board:ADP-Tfirefly DATA SHEET
转接板:ADP-Tfirefly数据手册
1 Introduction 产品介绍
ADP-Tfirefly是一款转接板,可将VEYE系列和CS系列符合15Pin接口转换为Firefly开源团队 ROC-RK3566-PC 30Pin Camera接口。
The ADP-Tfirefly is a adpter board that converts VEYE / CS Series camera module 15Pin interface to www.t-firefly.com ROC-RK3566-PC 30Pin Camera interface.
2 Product Picture 产品图片
| PART NUMBER / 型号 | FRONT VIEW / 正面图片 | BACK VIEW / 背面图片 | Adapter camera module / 适配摄像机模组 | Supported development boards / 支持的开发板 |
| ADP-Tfirefly | CS-MIPI-SC132 | ROC-RK3566-PC
ROC-RK3568-PC ROC-RK3588S-PC AIO-3568J AIO-3566JD4 ITX-3588J-8K ITX-3568Q |
3 Adapter Board Pinlist 引脚说明
| J1:UP contact,5cm FFC,connect with VEYE/CS camera module
J1:上接触,标配5厘米异面FFC,与VEYE/CS系列模组互联 | ||
| 2 | MIPI_L0_N | |
| 3 | MIPI_L0_P | |
| 5 | MIPI_L1_N | |
| 6 | MIPI_L1_P | |
| 8 | MIPI_CK_N | |
| 9 | MIPI_CK_P | |
| 11 | RESERVE | NC |
| 12 | RESERVE | NC |
| 13 | SCL | 3.3V |
| 14 | SDA | 3.3V |
| 15 | VCC | 3.3V POWER OUT |
| J2:Down contact,30Pin 20cm FFC,connect with Firefly 30Pin FPC connector
J2:下接触,标配30Pin 20cm同面FFC,与Firefly 30Pin 接口FPC座互联 | ||
| 1 | SDA | 1.8V |
| 2 | SCL | 1.8V |
| 3 | PDN_CAM | 1.8V |
| 4 | NC | |
| 5 | GND | |
| 6 | NC | |
| 7 | NC | |
| 8 | NC | |
| 9 | NC | |
| 11 | MIPI_L0_P | |
| 12 | MIPI_L0_N | |
| 13 | GND | |
| 14 | MIPI_L1_P | |
| 15 | MIPI_L1_N | |
| 16 | GND | |
| 17 | MIPI_CK_P | |
| 18 | MIPI_CK_N | |
| 19 | GND | |
| 20 | NC | |
| 21 | NC | |
| 22 | GND | |
| 23 | NC | |
| 24 | NC | |
| 25 | GND | |
| 26 | NC | |
| 27 | NC | |
| 28 | GND | |
| 29 | VCC5V | POWER IN, DC5V |
| 30 | VCC5V | POWER IN, DC5V |
