C-MOUNT03
1 Product Picture 产品图片
Product Picture 产品图片 Product Picture 产品图片 Camera Support 支持的相机
C-MOUNT03
C-MOUNT03
MV-MIPI-IMX178M
MV-MIPI-SC130M
MV-MIPI-IMX296M
MV-MIPI-IMX265M
MV-MIPI-IMX264M
RAW-MIPI-IMX462M
RAW-MIPI-SC535M
2 Attention 注意事项
2.1 Overview 概述
C-MOUNT03针对C-MOUNT01后截距进行了优化。
C-MOUNT03仅仅是一个C-MOUNT镜头固定座,为了适配MV系列和RAW系列摄像机,实际后焦法兰焦距略小于17.526mm,配合不同型号的摄像机模组,需要将镜头向远离传感器的方向调整。具体数值需要根据传感器的成像面高度决定。
C-MOUNT03 is optimized for the post-intercept of C-MOUNT01.
C-MOUNT03 is only a C-MOUNT lens mount. In order to fit the MV series and RAW series camera, the actual Flange BFL distance is less than 17.526mm. With different camera modules,
Not adjusted / 未调整 Adjusted / 向外调整
Da = Dc - ( H - Ds )
C-MOUNT03高度 / The Height of C-MOUNT03:H= 17.95mm
Parameter 参数表
Part NO. / 型号 Ds (mm) Da(mm)
MV-MIPI-IMX296M 0.92 0.496
MV-MIPI-IMX178M 0.92 0.496
MV-MIPI-IMX265M
0.92 0.496
MV-MIPI-IMX264M
0.92 0.496
MV-MIPI-IMX287M
0.92 0.496
RAW-MIPI-IMX462M
0.62 0.196
MV-MIPI-SC130M 0.6 0.176
MV-MIPI-GMAX4002M 0.85 0.426
RAW-MIPI-SC535M 1.825 1.401
3 Dimension 尺寸图
C-MOUNT03 Dimensional Drawing
4 2D 文件
Download 2D file here
5 3D 文件
Download 3D file here
