CS-MIPI-IMX307 version log
1 How to get version
2 Upgrade package download
CS Serials Camera Upgrade Images(Mediafire)
3 Version Log
  • CS-MIPI-IMX307_FV3.43_LV4.0_20231213.bin
    1. Fix Bug:sysreboot -p1 1can not take effect,use reboot.
    2. Fix Bug:restoring default values not being effective.
  • CS-MIPI-IMX307_FV3.42_LV4.0_20231114.bin
1. Add csi enable output enable function.
2. Improve the MIPI output signal, greatly improve the compatibility in agx Orin platform.
PS:Firmware version 3 or above cannot be upgraded to camera modules with FV version 2.
  • CS-MIPI-IMX307_FV2.39_LV3.4_20210427.bin
  1. fixbug: free running mode, little frame drops.
  • CS-MIPI-IMX307_FV2.38_LV3.4_20210326.bin
  1. Support YUV seq setting, add YUYV mode.
  2. Support i2c write protect function.
  • CS-MIPI-IMX307_FV2.36_LV3.3_20210303.bin
    1. FIX bug:720p and VGA mode, modify crop area to center.
  • CS-MIPI-IMX307_FV2.35_LV3.3_20201126.bin
    1. 307 support mini exposure time to 1 line.
    2. Support decimal frame rate to achieve the purpose of exposure time exceeding 1s.
    1. Optimize the sync mechanism by using only frame synchronization signals.
    2. Fpdlink mode synchronization is supported.
  1. Add the gain threshold in slow shutter mode.
  1. Fix bug: slave sensor image filcker in sync mode.
  1. FIX bug: A Black line on top @ 720p mode.
  1. support slow shutter mode.
  1. support continuous frame rate adjustable in freerunning mode.
  2. support pick mode,pick one frame in video stream.
  1. Improve Defect Pixel effection.
  1. Modify the definition of imagedir.
  2. support indirect reading of sensor register.
  1. Two special daynight modes have been added.
  1. support flip mirror setting.
  2. support ae param setting.
  1. Optimized sync mode,achieve the consistency of the output phase of the master and slave cameras mipi signal.
  1. fix bug: Possible duplicate frame problem.
  2. Modified sync mode to reduce latency.
  1. support CSC param: hue,contrast,saturation.
  2. support day/night mode setting via i2c cmd.
  3. support exposure state and white balance state read out.
  4. support manual exposure and manual white balance setting.
  1. support 640*480@130fps mode
  2. Reduce the delay.
  3. fix bug:No matter what the configuration parameters are, it always starts in 1920*1080 mode.
  1. support stream sync mode.
  2. support i2c address change and save.
  1. support antiflicker.
  2. Reduce 3D denoise strength.
