GX-MIPI-IMX664 Data Sheet
GX-MIPI-IMX664 Datasheet
The GX-MIPI-IMX664 camera module is a new generation product from VEYE IMAGING, featuring Sony’s STARVIS 2 sensor technology.
Equipped with a high-performance built-in ISP, this module offers highly controllable image parameters, multiple operating modes, and a rich set of features, supporting video output up to 2688*1520@30fps.
Its MIPI-CSI2 interface enables rapid integration into embedded (AI) systems, eliminating the need for complex ISP tuning.
Designed as a compact single-board module (38 mm × 38 mm), it uses a 22-pin FPC connector with 0.5 mm pitch, allowing easy connection to popular embedded (AI) platforms such as Raspberry Pi, NVIDIA Jetson series, and Rockchip RK3588.
GX-MIPI-IMX662
GX-MIPI-IMX662
2 Thechnical Detail
Thechnical Detail
Sensor
Sensor SONY IMX664-AAQR1-C STARVIS2
Pixels 4.08M pixel
Resolution 2688*1520
Image Size Diagonal 9.02 mm (Type 1/1.8)
Shutter Type Rolling Shutter
SNR1s Value 0.18
ISP
Frame Rate 1920*1080@60fps(max)
Exposure Auto or Manual
White Balance Auto or Manual
Shutter 1/fps to 1/50,000s
Framerate 0.065 - 60 fps
Slow Shutter Auto Slow Shutter control
ISP sharpening, 2D/3D noise reduction, anti-flicker, lens distortion correction,
defogging, gamma adjustment, and Dynamic Range Compression (DRC)
Work Mode
Work Mode Video streaming mode(Free Running), Normal Trigger Mode, Sync Mode
Trigger Source Hardware,Software
Trigger Paramters Trigger Polarity Control,Trigger Delay
Strobe Control Strobe Output Control,Strobe Delay
Lens & IR-CUT
Lens MTV12 / MTV16 / CS
Interface
Connector 22Pin 0.5mm pitch FPC, upper contact
I2C Compatible with 1.8V/3.3V DC
Video Data Interface MIPI CSI-2 Standard,2 Data Lane + 1 Clk Lane
UYVY / YUYV format YUV422-8bit Data Type, Bandwidth 1.188Gbps MIPI CSI-2 DC Specifications
General
Operating Conditions
(Bare PCB)
Operating guarantee temperature:-30℃~70℃, Humidity 95% or less, non-condensing
Power Supply 5V DC
Power Consumption TBD
Dimension 38mm*38mm*8.2mm(not include lens and lens mount)
3 Spectral Sensitivity Characteristics
Sensor Spectral Sensitivity
IMX664-AAQR-C
IMX664-AAQR-C Spectral Sensitivity
4 Connector Pinlist
GX-MIPI-IMX664
GX-MIPI-IMX664
J3:CSI-2 Interface
Pin NO. NAME Remarks
1 NC
2 SDA 1.8V / 3.3V Level
3 SCL 1.8V / 3.3V Level
5 NC
6 PWR_ENABLE Power Enable,3.3V,ACTIVE High
8 NC
9 NC
11 NC
12 NC
13 GND
14 MIPI_CK_P
15 MIPI_CK_N
16 GND
17 MIPI_L1_P
18 MIPI_L1_N
19 GND
20 MIPI_L0_P
21 MIPI_L0_N
22 GND
J2 : Day/Night External Trigger
3 NC
2 IRCUT2 +
2 IRCUT2 -
J6:5VDC INPUT
Pin NO. PIN NAME Remarks
1 5VDC
2 GND_P
J7:Trigger/Sync Pin
1 TRIGGER / VSYNC Normal trigger mode: trigger signal input;
Synchronous mode(Master): synchronization signal output;
Synchronous mode(Slave): synchronization signal input.
3 OUT1 Output signal : Strobe signal or TriggerWait signal.
5 Board Dimension
CAD结构图纸 单位:毫米
2D dxf file
6 PCBA 3D STP
3D STP file
