Gx Series MIPI Camera Register Map
GX Series MIPI Camera Register Map
1.1 Register Features
1.3 Update timing
-: Read only at any time.
R: The valid value can be readat running state.
2 Basic Parameters
Address Name Description Data Type R/W Update timing script function
0x0000 Manufacturer Name String containing the self-describing name of the manufacturer. “VEYE” ascii RO - manufacturer
0x0662: GX-MIPI-IMX662
0x0664: GX-MIPI-IMX664
enum RO - model
0x662: IMX662-AAQR
0x664: IMX662-AAQR1
enum RO - sensorname
0x000C Serial Number factory number uint RO - serialno
For example, 0x01020304 means C version is 1.2 and L version is 3.4.
uint RO - version
0x0014 Factory Param All parameters restored to factory default values.
bool WO A factoryparam
0x0018 Param save to flash Save all parameters to flash, and they will not be lost when power off.
bool WO A paramsave
0x001C System reboot Reboot the camera. bool WO A reboot
0x0020 Time stamp Time after system startup in Milliseconds. uint RO - timestamp
0x0024 Error Code Reserved uint RO - errcode
0x0028 Format Cap The module supports the capability set of data formats. Each bit represents a data Format, similar to the definition of the Pixel Format register.
bit3: Mono14 (reserved)
bit5: RGB888
bit6: Temp (reserved)
bit7: YUYV
uint RO - fmtcap
bit0: Normal
bit1: binning mode
bit2: subsampling mode
uint RO - readmodecap
0x0030 WorkMode Cap Capbility of trigger mode supported by the camera.
bit0: Video streaming mode
bit1: Normal trigger mode.
bit4: Multi-camera synchronization mode
uint RO - workmodecap
uint RO - lanecap
0x0038-
0x0054
Camera name camera type string RO - cameramodel0-cameramodel7
0x0058 Temperature K The sensor's temperature value, in Kelvin, is 100 times the current temperature. uint RO - temp
0x005C VideoModeCap Product resolution mode capability.
Bit0: ROI model.
Bit1: Preset Mode mode
uint RO - videomodecap
0x0060 VideoModeNum The GX series uses the resolution mode scheme by default and does not use the ROI scheme. The number of supported image modes. Up to 8 types are supported. uint RO - videomodenum
0x0064 VidoeMode_WH1 In the first mode, the width is represented by the upper 16 bits and the height by the lower 16 bits. uint RO - videomodewh1
0x0068 VideoMode_Param1 The frame rate and read mode of the first pattern. The high 8 bits are reserved, the middle 8 bits define the read mode, and the low 16 bits represent the frame rate.
Read mode definition:
0: ordinary
1: binning
2: subsampling
uint RO - videomodeparam1
0x006C VidoeMode_WH2 The width and height of the second mode uint RO - videomodewh2
0x0070 VideoMode_Param2 The frame rate and reading method of the second mode. uint RO - videomodeparam2
0x0074 VidoeMode_WH3 The width and height of the third mode uint RO - videomodewh3
0x0078 VideoMode_Param3 The frame rate and reading method of the third mode. uint RO - videomodeparam3
0x007C VidoeMode_WH4 The width and height of the fourth mode uint RO - videomodewh4
0x0080 VideoMode_Param4 The frame rate and reading mode of the fourth pattern. uint RO - videomodeparam4
0x0084 VidoeMode_WH5 The width and height of the fifth mode uint RO - videomodewh5
0x0088 VideoMode_Param5 The frame rate and reading method of the fifth mode. uint RO - videomodeparam5
0x008C VidoeMode_WH6 The width and height of the sixth mode uint RO - videomodewh6
0x0090 VideoMode_Param6 The frame rate and reading method of the sixth mode. uint RO - videomodeparam6
0x0094 VidoeMode_WH7 The width and height of the seventh mode uint RO - videomodewh7
0x0098 VideoMode_Param7 The frame rate and reading method of the seventh mode. uint RO - videomodeparam7
0x009C VidoeMode_WH8 The width and height of the eighth mode uint RO - videomodewh8
0x00A0 VideoMode_Param8 The frame rate and reading method of the eighth mode. uint RO - videomodeparam8
3 Image Acquisition
bool WO A imgacq
0x0404 Work Mode 0: Video streaming mode
4: Multi-camera synchronization mode.
enum RW S workmode
0x0408 Trigger Source Get/Set Trigger Source:
enum RW S trgsrc
0x040C Trigger Number Trigger mode, the number of trigger frames in a single instance is represented by bit[7:0], which is valid within the legal range of 1 to 255. The default value is 1. uint RW S trgnum
0x0410 Trigger Interval Trigger interval in normal trigger mode, in microseconds. Range: [0.0xFFFFFF] uint RW S trginterval
0x0414 Trigger Software Software trigger command, write 1 for one trigger. bool WO S trgone
Write 1 to clear the count.
uint RW S trgcount
0x041C I2C ADDR I2c address. Range[0x03,0x77]. uint RW A i2caddr
0x044C Non discontinuous mode Indicates whether the clock lan of the mipi signal is in continuous clock mode.
0: discontinuous mode
1: continuous mode
bool RW - nondiscontinuousmode
0x0460 Slave mode It takes effect in the synchronous mode of the GX series.
In the synchronization mode, the role of the camera.
0: Main Mode
1: From Mode Slave
bool RW S slavemode
0x0464 Sensor Frame Count The number of frames output by the sensor. Cyclic counting. uint RO - framecount
0x0468 Out Frame Count The number of frames output by the camera module. Cyclic counting. uint RO - framecount
0x046C Min Trigger cycle Minimum trigger signal period, in microseconds (µs), with 0 indicating an invalid value. uint RO - trgcycle
0x0474 Day night mode 0: Color mode
1: Black and white mode
2: External Trigger Mode
int RW A daynightmode
0x0478 IRCUT dir ircut Direction reversal bool RW A ircutdir
0x047C day night
trigger pin polarity
The trigger pin polarity is reversed day and night. The default low level indicates night. When this value is set to 1, the high level indicates night. bool RW A pinpolarity
0x0480 IRCUT Timer Whether to enable the IRCUT periodic control; if enabled, perform IRCUT control according to the default cycle; if not enabled, only perform one control when the mode is switched. bool RW A ircuttimer
4 Image Features
0x0800 Test Image Selector GX Series
1: Vertical color stripes
uint RW A testimg
0x0804 Pixel Format Pixel format
0: Mono8
1: Mono10
2: Mono12
3: Mono14(reserved)
4: UYVY
5: RGB888
6: Temp(reserved)
7: YUYV
enum RW S pixelformat
0x0808 Sensor Width The maximum width supported by the sensor uint RO - maxwh
0x080C Sensor Height The maximum height supported by sensor uint RO - maxwh
uint RO - maxfps
0x0818 Current Width Current Width. uint RO - curwh
0x081C Current Height Current Height. uint RO - curwh
0x0828 Image Direction Image orientation:
0: normal
1: mirror
2: flip
3: flip&mirror
enum RW A imgdir
0x082C VideoMode For cameras that select width, height, and frame rate using the VideoMode mode, which mode to choose,The range is [0-7],The corresponding capability set is VideomodeCap. uint RW S videomode
0x0838 Read Mode Read mode:
0: Normal
1: 2*2Binning
2: Subsampling
uint RO - readmode
0x083C Lane Num Configuration of the number of Lans for outputting mipi signals.
2: 2lane default value
4: 4lane
uint RO - lanenum
0x0840 MIPI Datarate The MIPI datarate for each lane, measured in Kbps. uint RO - mipidatarate
0x0844 Min Width The minimum width supported by the camera. uint RO - minwh
0x0848 Min Height The minimum height supported by the camera. uint RO - minwh
0x084C Min Frame Rate The minimum framerate supported by the camera. The value is 10000 times the actual framerate. uint RO - minfps
0x0850 Framerate_EX The extended register of the Framerate register, where the value is 10,000 times the actual frame rate. uint RW S fps
5 ISP
0: Manual exposure
2: Automatic exposure
enum RW A expmode
0x0C08 Target Brightness Target brightness for automatic exposure. Range[0,255] uint RW A aetarget
0x0C0C AE Strategy Automatic exposure strategy:
0: Highlight priority mode (high light priority).
1: Shadow priority mode (low light priority), also known as backlight compensation mode (Backlight Compensation).
enum RW A aestrategy
0x0C10 ME Time Manual exposure time,effective in ME mode. Range[16,1000000]. Note1.Unit: microseconds. uint RW A metime
0x0C14 AE MAX Time Maximum exposure time in AE mode.Range[16,1000000]. Note1.Unit: microseconds. uint RW A aemaxtime
0x0C18 Exp Time Current exposure time. Note1.Unit: microseconds. uint RO R exptime
0x0C20 Manual Gain Manual gain, ,effective in MG mode. Note2. uint RW A mgain
0x0C24 AG Max Gain Maximum value of auto gain. Note2. uint RW A aemaxgain
0x0C28 Cur Gain Current Gain. Note2. uint RO R curgain
0x0C3C WB Mode White balance type:
0: Manual White Balance
2: Automatic White Balance
uint RW A wbmode
0x0C40 AWB Color temp min White balance minimum color temperature [1000,15000] (K) uint RW A awbcolortempmin
0x0C44 AWB Color temp max White balance maximum color temperature [1000,15000] (K) uint RW A awbcolortempmax
0x0C48 MWB Rgain Manual white balance R gain [0,4095] uint RW A mwbrgain
0x0C4C MWB Bgain Manual white balance B gain [0,4095] uint RW A mwbbgain
0x0C50 Color Temp Current color temperature (k) uint RO R colortemp
0x0C54 Cur Rgain Current white balance R gain [0, 4095] uint RO R currgain
0x0C58 Cur Bgain Current white balance B gain [0, 4095] uint RO R curbgain
0x0C5C AE Min Time Automatic minimum exposure time
Range: 16 to 1,000,000 (unit: microseconds)
uint RW A aemintime
0x0C94 Anti flicker enable Whether to enable the antiflicker function bool RW A antiflicker
0x0C98 Anti flicker Freq Anti-flicker frequency uint RW A antiflicker
0x0C9C WDR Option WDR Function Selection
0: Disable WDR
1: Digital Wide Dynamic Range (Digital WDR)
2: DOL WDR
3: Clear WDR
bool RW A wdrparam
0x0CA0 WDR strength WDR intensity [0 - 255] uint RW A wdrparam
0x0CA4 Sharppen strength Sharpening intensity [0 - 255] uint RW A sharppen
0x0CA8 2D denoise strength 2D noise reduction intensity [0 - 255] uint RW A denoise2d
0x0CAC 3D denoise strength 3D noise reduction intensity [0 - 255] uint RW A denoise3d
0x0CB0 Saturation Saturation [0 - 100] uint RW A saturation
0x0CB4 Contrast Contrast [0 - 100] uint RW A contrast
0x0CB8 Hue Hue [0 - 100] uint RW A hue
0x0CBC Slow Shutter Is the automatic frame reduction function enabled, It only takes effect in the automatic exposure mode + video stream mode. Corresponding to Aemode, is it in the fixed frame rate mode or the automatic frame reduction mode
Note5
bool RW A slowshutter
0x0CC0 Slow Shutter GainTh The gain threshold at which automatic frame rate reduction begins. Measured in 0.1 dB units. uint RW A slowshutter
0x0CC4 Lens Distortion Correction Lens distortion correction [0-255], abbreviated as LDC, 0 indicates off.
Note4
uint RW S ldc
0x0CCC Dehaze strength Defogging intensity [0-255] uint RW A dehaze
0x0CD0 Gamma Selection The GX series has preset gamma options, with different values representing different gamma settings:
1: Default gamma.
2: gamma_1.6
3: gamma_1.8
4: gamma_2.0
5: gamma_2.2
6: Style 1
7: Style 2
8: Style 3
9: Style 4
10: Style 5
11: Style 6
12: User-defined gamma (TODO)
uint RW A gamma_index
0x0CD4 DRC strength Digital wide dynamic range. Range [0-255], 0 indicates off. uint RW A drc
Note3: AE: Auto exposure; AG: Auto Gain; AA: AE.
Note4: The parameters of this function setting must be set before the camera captures images to be effective.
Note5: When using this function, the maximum exposure time needs to be used in conjunction, for example, aemaxtime= 1,000,000 (us), and then the slowshutter enable and frame rate reduction gain threshold should be set.
6 IO Control
0x1000 Trigger Delay Trigger delay. Trigger delay. Effective in both soft trigger and hard trigger modes.
uint RW S trgdelay
1: Falling edge
uint RW S trgedge
uint RW S trgexp_delay
0x1020 GPIO1_OutSelect [2:0]
000: Strobe
001: UserOut
010: TriggerWait, waiting for the trigger signal. The inverse state of the busy signal. (Supported by the GX series)
Others: Keep
uint RW A outio1_mode
0x1028 GPIO1 Reverse OUT_IO1 signal reversal. bool RW A outio1_rvs
7 Special Block Area
0x1800-0x37FF : lut area.
