Gx series camera appnotes 4 rpi
1 overview
1.1 Supported modules
series model state
GX系列 GX-MIPI-IMX662 Done
GX Camera to RaspberryPi 5
GX Camera to RaspberryPi 4
3.2 install the driver
  • For Raspberry Pi 5
3.3 Uninstall the driver
To use a driver for a different camera module model, the currently installed driver must be uninstalled first.
dmesg | grep gxcam
camera is: GX-MIPI-IMX662
And the /dev/video0 node exists, which proves that the camera is probed properly.
The usage method is:
$ source ./gx_probe.sh 10
Setenv HEIGHT = 1080
  • ./find_entity.sh
This is a Raspberry Pi 5.
After a reboot of the Raspberry Pi 5, the media node and video node assignments for the cameras may change.
  • media_setting_rpi5.sh
$ ./media_setting_rpi5.sh
Before proceeding with the subsequent operations, this script must be executed to complete the configuration of the parameters.
6 Real-time preview
6.1 veye_viewer
6.2 qv4l2
First, install qv4l2
Play gx camera using qv4l2 on RPI
7 Gstreamer Examples
7.1 Install GStreamer
7.2 Using GStreamer
8 yavta
8.1 Installing yavta
$ cd yavta;make
8.2 yavta routine
example
$ ./yavta -c1 -Fuyvy_1920X1080.yuv --skip 0 -f UYVY -s 1920x1080 /dev/video0
  • install opencv
  • To import camera data from a V4L2 device into OpenCV, we provide several sample programs.
10 v4l2-ctl Examples
10.1 Install v4l2-utils
10.2 v4l2-ctl routine
  • Capture a raw UYVY data image (in 1080p mode)
  • Capture 10 original UYVY data images (in 1080p mode)
        [0]: 'UYVY' (UYVY 4:2:2)
                Size: Discrete 1920x1080
        [1]: 'YUYV' (YUYV 4:2:2)
                   trigger_mode 0x00981a01 (int)    : min=0 max=4 step=1 default=0 value=0 flags=volatile, execute-on-write
Note: For Raspberry Pi 5, all the commands in this section that use v4l2-ctl configuration parameters need to add the -d parameter to specify the subdevice used for the configuration parameters.
10.4.1 Trigger mode
0: Streaming Mode
1: Ordinary Trigger Mode
4: Multi-camera Synchronization Mode
10.4.2 Trigger Source
0: Soft Trigger
1: Hard Trigger
10.5 Software trigger command
10.5.1 Set frame rate
10.6 Trigger mode
10.6.1 Soft Trigger Mode
10.6.1.1 Set Mode
10.6.1.2 Start acquisition
10.6.2 Hardware trigger mode
Here, using GPIO21 of the Raspberry Pi as the analog trigger source and with the rising edge as the trigger condition, is exemplified.
10.6.2.1 Set mode
10.6.2.2 Start acquisition
In other shell terminals, you can execute the following command multiple times to trigger it repeatedly.
$ python gpio_trigger.py
Note: Trigger script link.
10.7 Video Streaming mode
10.7.1 Set frame rate
10.7.3 Save image to file
  • UYVY
10.8 Synchronous Mode
10.8.1 Set synchronous mod
master camera:
slave camera:
10.8.3 Start taking pictures
gx_mipi_i2c.sh user guide
12.1 Initialization Stage
12.2 Operation Stage
Depending on the programming language used, customers can refer to the code samples and tools described earlier in this document.
12.3 Parameter Configuration
  • 2025-12-06
The first version
