MV-MIPI-IMX287M Version Log
1 How to get version
MV-MIPI-IMX287M has two version number, Using shell script ,get version.
L version is logic version,C version is controller version.
2 Upgrade package download
Camera Upgrade Images(Mediafire)
3 Version Log
  • MV-MIPI-IMX287M_C1.28_L1.33_upgrade_20230327.bin
  1. First release version.
  • MV-MIPI-IMX287M_C1.34_L2.02_upgrade_20231024.bin
  1. Increased the image processing speed of the ISP module, resulting in an enhanced maximum frame rate.
  2. Removed the UYVY data type.
  3. D-PHY reset only triggers a power-on reset once, ensuring that each lane is in the LP11 state, which is beneficial for the initialization of the MIPI-RX end, such as Zynq.
  • MV-MIPI-IMX287M_C1.41_L2.06_upgrade_20240605.bin
  1. In stream mode, the strobe signal is also output.
  2. Realize precise strobe signal output with very short exposure time.
  • MV-MIPI-IMX287M_C1.43_L2.07_upgrade_20240910.bin
  1. Add Pulse trigger mode.
  2. Add frame count function.
