User talk:Bluewhale
1.1 Register Features
1.3 Update timing
-: Read only at any time.
1.4 Raw series Support
It contains an MCU, which is used for sensor mode configuration and trigger timing generation.
N:Not support.
S:Support in normal mode.
2 Basic Parameters
0x178 : MV-MIPI-IMX178M
0x130 : MV-MIPI-SC130M
0x265 : MV-MIPI-IMX265M
0x264 : MV-MIPI-IMX264M
0x296 : MV-MIPI-IMX296M
0x287 : MV-MIPI-IMX287M
0x4002 : MV-MIPI-GMAX4002M
0x8132 : RAW-MIPI-SC132M
0x8234 : RAW-MIPI-AR0234M
0x8462 : RAW-MIPI-IMX462M
0x8535 : RAW-MIPI-SC535M
enum RO - model S
0x178 : IMX178LLJ
0x130 : SC130GS
0x265 : IMX265LLR
0x264 : IMX264LLR
0x296 : IMX296LLR
0x287 : IMX287LLR
0x132 : SC132GS
0x234 : AR0234CS
0x462 : IMX462LLR
0x535 : SC535HGS
0x4002 : GMAX4002-AVM
enum RO - S
0x000C Serial Number Unique product serial number uint RO - S
uint RO - version S
0x0014 Factory Param All parameters restored to factory default values.
bool WO A factoryparam S
0x0018 Param save to flash Save all parameters to flash, and they will not be lost when power off.
bool WO A paramsave S
bit0: sensor error.
bit6: Authorization failure.
uint RO - errcode S
bit3: Mono14
bit5: Temperature sensor
uint RO - fmtcap S
bit0: Normal
bit1: Binning
bit2: Subsampling
uint RO - readmodecap S
bit0:Video streaming mode
bit1:Normal trigger mode.
bit3: Pulse trigger mode.
uint RO - trgmodecap S
uint RO lanecap S
0x0038-
0x0054
3 Image Acquisition
bool WO A imgacq S
enum RW S trgmode S
enum RW S trgsrc S
Write 1 to clear the count.
uint RW A trgcount S
bool RW A mcubypass S
uint RO A trgcycle S
4 Image Features
0 : Normal image
1 : Test image 1
2 : Test image 2
uint RW A testimg S
0x0804 Pixel Format 0 : Mono8
1 : Mono10
2 : Mono12
3 : Mono14(reserved)
4 : UYVY
enum RW S pixelformat S
uint RO - maxfps S
uint RW S fps S
0x081C ROI Height ROI Height
uint RW S roi S
1 : mirror
2 : flip
3 : flip&mirror
enum RW A imgdir S
uint RW A blcmode S
0x0838 Read Mode Read mode:
0: Normal
1: Binning
2: Subsampling
uint RW A readmode S
0: Disabled
uint RW A osdmode N
5 ISP
bit0: Exposure Statistics
bit1: reserved
bit2: WB Statistics
bit3: Focus Statistics
bit4: DPC
bit5: gamma
bit6: denoise
bit7: sharpen
bit8: LUT
others: reserved
uint RW A gammaenable,
dpcenable,
lutenable,
N
0: Manual exposure
2: Automatic exposure
enum RW A expmode N
0x0C10 ME Time Manual exposure time,effective in ME mode. Range[16,1000000]. Note1.Unit: microseconds. uint RW A metime S
0x0C14 AE MAX Time Maximum exposure time in AE mode.Range[16,1000000]. Note1.Unit: microseconds. uint RW A aemaxtime N
0x0C18 Exp Time Current exposure time. Note1.Unit: microseconds. uint RO - exptime S
0x0C1C Gain Mode Gain Type
0: Manual gain
1: Run automatic gain once
2: Automatic gain
enum RW A gainmode N
0x0C80 AAROI enable Whether to enable AAROI statistics function, not enable means full ROI statistics. bool RW A aaroienable N
Unit: microseconds
uint RO A exptime_range S
Unit: 0.1 microseconds
6 IO Control
0x1000 Trigger Delay Trigger delay. Trigger delay. Effective in both soft trigger and hard trigger modes.
uint RW S trgdelay S
1: Falling edge
uint RW S trgedge S
uint RW S trgfilter_enable N
uint RW S trgfilter_time N
uint RW S trgexp_delay N
0x1014 TriggerIN IO status TriggerIN_IO pin status. enum RO - gpios_status S
1: UserOut
uint RW A outio1_mode N
0x1024 GPIO1 UserOut User-defined OUT_IO1 output signal. enum RW A outio1_usr N
0x1028 GPIO1 Reverse OUT_IO1 signal reversal. bool RW A outio1_rvs N
0x102C GPIO1 OutStatus OUT_IO1 pin status. enum RO - gpios_status N
1: UserOut
Indicate that the camera is not busy now, able to respond to the trigger signal.
3: XVS
4: XHS
uint RW A outio2_mode N
0x1034 GPIO2 UserOut User-defined OUT_IO2 output signal. enum RW A outio2_usr N
0x1038 GPIO2 Reverse OUT_IO2 signal reversal. bool RW A outio2_rvs N
0x103C GPIO2 OutStatus OUT_IO2 pin status. enum RO - gpios_status N
7 Special Block Area
0x1800-0x37FF : lut area.
