V-by-One-HS-RX
V-by-One-HS-RX Data Sheet (V-by-One-HS-RX数据手册)
1 Product Picture(产品图片)
| PART NUMBER / 型号 | FRONT VIEW / 正面图片 | BACK VIEW / 背面图片 |
| V-by-One-HS-RX |
2 Thechnical Detail (技术规格)
| Thechnical Detail (技术规格) | |
| V-by-One-HS-RX deserializer 解串化 | |
| IC PART NO. 器件型号 | THCV242A-P |
| Function 功能 | V-by-One HS to MIPI CSI-2 conversion |
| Input Compatibility 输入兼容 | V-by-One HS standard version1.5 |
| Output Compatibility 输出兼容 | MIPI CSI-2 |
| Interface 接口 | |
| MIPI OUTPUT | MIPI CSI-2,Supports up to 1.5Gbps/lane,Supports 2 or 4 lanes |
| MIPI OUTPUT Connector | FFC socket(J7 / J9 / J11) |
| V-by-One HS INPUT | V-by-One HS,Supports up to 4.0Gbps(effective rate 3.2Gbps),Supports 1 or 2 lanes |
| V-by-One HS INPUT Connector | FAKRA Z Compatibility ( J12 RX1 / J13 RX0) |
| GPIO | 2 output,1 input |
| Communication Interface | Sub link |
| General 通用 | |
| Operating Conditions
(Bare PCB) |
Operating guarantee temperature:-20℃~85℃, Humidity 95% or less, non-condensing |
| POC DC Power OUTPUT | DC 9V (Only J13 RX0 is powered by POC) |
| DC POWER INPUT | DC12V (J1 / J2) |
| Dimension | 75mm*40mm |
3 Board Pinlist(接口和引脚说明)
| J1:12V PWR IN(12V电源输入) | ||
| 1 | 12VIN | |
| J2: 12V PWR IN(12V电源输入) | |
| Connector(接插件) | Interface Definition(接口定义) |
| DC JACK | |
| J4 | ||
| 1 | GPIO0 | 3.3V Level,Connect to THCV242 GPIO0 |
| 3 | EXTSYNC | RVS,3.3V Level,Connect to THCV242 EXTSYNC |
| J5 | ||
| 1 | GPIO2 | 3.3V Level,Connect to THCV242 GPIO2 |
| 3 | GPIO3 | 3.3V Level,Connect to THCV242 GPIO3 |
| J13(RX0):V-by-One HS & POC interface(POC接口) | |
| FAKRA Z | |
| J12(RX1) :V-by-One HS interface | |
| FAKRA Z | |
| J7 : 4 lane MIPI OUTPUT | ||
| 1 | NC | NC |
| 2 | SDA | 3.3V Level |
| 3 | SCL | 3.3V Level |
| 5 | NC | |
| 6 | NC | |
| 8 | MIPI_L3_P | |
| 9 | MIPI_L3_N | |
| 11 | MIPI_L2_P | |
| 12 | MIPI_L2_N | |
| 13 | GND | |
| 14 | MIPI_CK_P | |
| 15 | MIPI_CK_N | |
| 16 | GND | |
| 17 | MIPI_L1_P | |
| 18 | MIPI_L1_N | |
| 19 | GND | |
| 20 | MIPI_L0_P | |
| 21 | MIPI_L0_N | |
| 22 | GND | |
| J9:2 lane MIPI OUTPUT | ||
| Pin NO. | NAME | Remarks |
| 2 | MIPI_L0_N | |
| 3 | MIPI_L0_P | |
| 5 | MIPI_L1_N | |
| 6 | MIPI_L1_P | |
| 8 | MIPI_CK_N | |
| 9 | MIPI_CK_P | |
| 11 | NC | NC |
| 12 | NC | NC |
| 13 | SCL | 3.3V level |
| 14 | SDA | 3.3V level |
| 15 | NC | NC |
| J11 : 4 lane MIPI OUTPUT | ||
| 2 | NC | NC |
| 3 | NC | NC |
| 4 | NC | NC |
| 5 | NC | NC |
| 6 | GND | |
| 7 | NC | NC |
| 8 | GND | 3.3V LEVEL |
| 9 | MIPI_L0_N | 3.3V LEVEL |
| 10 | MIPI_L0_P | |
| 11 | GND | 3.3V Level |
| 12 | MIPI_L1_N | 3.3V Level |
| 13 | MIPI_L1_P | |
| 14 | GND | |
| 15 | MIPI_CK_N | |
| 16 | MIPI_CK_P | |
| 17 | GND | |
| 18 | MIPI_L2_N | |
| 19 | MIPI_L2_P | |
| 20 | GND | |
| 21 | MIPI_L3_N | |
| 22 | MIPI_L3_P | |
| 23 | GND | |
| 24 | SCL | |
| 25 | SDA | |
| 26 | NC | |
| 27 | NC | NC |
| 28 | NC | NC |
| 29 | NC | NC |
| 30 | GND | |
