VEYE CS Camera on Forlinx i.MX8 board
OKMX8MPQ-C board from Forlink embedded uses i.MX8M plus processor.
On the basis of Forlink 's official SDK(OKMX8MP-C_Linux5.4.70+Qt5.15.0 version), our camera module driver is added, and some application layer routines are provided.
| Series | Model | Status | Adaptor board |
| VEYE series | VEYE-MIPI-IMX327S | Done | ADP-Forlinx |
| VEYE series | VEYE-MIPI-IMX385 | Done | ADP-Forlinx |
| VEYE series | VEYE-MIPI-IMX462 | Done | ADP-Forlinx |
We use ADP-Forlinx to connnect the camera with OKMX8MPQ-C board.
The camera and ADP-Forlinx are connected using 1.0 mm pitch*15P FFC cable with opposite direction. The cable must be inserted with the silver contacts facing outside.
3 Upgrade OKMX8MPQ-C system
3.1 Overview
This section describes how to update the OKMX8MPQ-C system to support our camera module. To support our camera module, we need to update two parts of the system, Image and DTB.
The released files were compiled based on the image of OKMX8MP-C_Linux5.4.70+Qt5.15.0 version.
3.2 BSP package introduction
3.2.1 i.MX platform bsp
includes:
- driver source code
- i2c toolkits
- application demo
3.2.2 Folinx i.MX platform bsp
https://github.com/veyeimaging/forlinx_nxp_i.mx
includes:
- prebuild linux kernel:Image
- dts source code
3.3 Burn the Forlinx standard system
Refer to : OKMX8MPQ-C_Linux5.4.70+Qt5.15.0Manual_V1.2_20230406.pdf
Burn the standard system provided by Forlinx to the board.
The Image and dtb files of the OKMX8MPQ-C board are saved in the FAT partition of emmc. After the system is started, it is automatically mounted to the /run/media/mmcblk2p1/ directory.
On HOST PC:
git clone https://github.com/veyeimaging/forlinx_nxp_i.mx.git
Extract the kernel Image, and copy the Image and dtb files to the OKMX8MPQ-C board.
cp <your path>/Image /run/media/mmcblk2p1/
cp <your path>/OK8MP-C.dtb /run/media/mmcblk2p1/
Reboot OKMX8MPQ-C board.
4 Applications and Test
4.1 Check system status
- VEYE-MIPI-IMX327S,VEYE-MIPI-IMX462,VEYE-MIPI-IMX385
[ 2.806555] veyecam2m 1-003b: camera id is veyecam2m
[ 2.816868] veyecam2m 1-003b: sensor is IMX327
[ 2.821323] veyecam2m 1-003b: board type is ONE board
[ 2.826981] veyecam2m 1-003b: veyecam2m camera probed
[ 6.055710] mx8-img-md: Registered sensor subdevice: veyecam2m 1-003b (1)
[ 6.150181] mx8-img-md: created link [veyecam2m 1-003b] => [mxc-mipi-csi2.1]
It can be seen that the VEYE-MIPI-IMX327S camera has been identified on i2c-1.
Once the camera is correctly recognized, a device node named /dev/video0 will be generated.
- List the formats supported by the camera
v4l2-ctl --list-formats-ext -d /dev/video0
Type: Video Capture Multiplanar
[0]: 'RGBP' (16-bit RGB 5-6-5)
Size: Discrete 1920x1080
[1]: 'RGB3' (24-bit RGB 8-8-8)
[2]: 'BGR3' (24-bit BGR 8-8-8)
[3]: 'YUYV' (YUYV 4:2:2)
[4]: 'YUV4' (32-bit A/XYUV 8-8-8-8)
[5]: 'NV12' (Y/CbCr 4:2:0)
[6]: 'YM24' (Planar YUV 4:4:4 (N-C))
[7]: 'XR24' (32-bit BGRX 8-8-8-8)
[8]: 'AR24' (32-bit BGRA 8-8-8-8)
In fact, the camera only provides UYVY data format, and the ISI module in i.MX 8M Plus provides data format conversion function, so /dev/video0 has so many output formats.
5 Video Stream test
5.1 Preview (VEYE-MIPI-CAM@1080p mode)
gst-launch-1.0 v4l2src device=/dev/video0 ! video/x-raw, format=NV12, width=1920, height=1080,framerate=30/1 ! autovideosink -v
gst-launch-1.0 v4l2src device=/dev/video0 io-mode=4 ! video/x-raw, format=NV12, width=1920, height=1080,framerate=30/1 ! imxvideoconvert_g2d ! queue ! video/x-raw, format=RGB16, width=1920, height=1080 ! waylandsink
5.2 Snap a picture (VEYE-MIPI-CAM@1080p mode)
5.3 v4l2grab snap a picture(VEYE-MIPI-CAM@1080p mode)
5.4 I2C Control Toolkits Manual
Using -b option to identify which bus you want to use, please use -b 1 for OKMX8MPQ-C.
- VEYE series
6 Build the drivers from source
The following operations are done on Ubuntu Host PC.
6.1 Set up the Host PC environment
Refer to the official document OKMX8MPQ-C_Linux5.4.70+Qt5.15.0_manual_V1.2_20230406.pdf to deploy the development environment.
6.2 Build Forlinx version kernel
Compile the standard version according to the above document.
6.3 Patch code
- Driver source code
The source code path of the camera driver is: linux/drivers/media/i2c, places the source code of the camera driver in the corresponding directory.
Merge the Config and Makefile in the same path. Add the corresponding camera driver.
- dts file
Modify the Config and Makefile in the same path. Add the corresponding dts option.
6.4 Add compilation options
make menuconfig
Add the compilation options for the corresponding camera module driver, and the path is > Device Drivers > Multimedia support > I2C Encoders, decoders, sensors and other helper chips .
6.5 Build
Refer to the official documentation and compile to obtain Image and dtb output.
