VEYE CS Camera source for Jetson
Nvidia Jetson platform VEYE camera driver source code compilation guide
This section is based on the official Kernel Customization section, so please refer to the official documentation for any lack of detail.
We use a host pc with Ubuntu installed and a Jetson board as our development environment.
- Jetpack 4.x
driver is compiled together with the linux kernel on the host pc. dtb is also compiled on the host pc.
- Jetpack5.x
The driver is compiled to modules, on the Jetson board. dtb compilation is done on the host pc.
- Jetpack4.2.2,L4T r32.2.1
- Jetpack4.3,L4T r32.3.1
- Jetpack4.4,L4T r32.4.3
- Jetpack4.4.1,L4T r32.4.4
- Jetpack4.5,L4T r32.5
- Jetpack4.5.1,L4T r32.5.1
- Jetpack4.6, L4T r32.6.1
- Jetpack4.6.1, L4T r32.7.1
- Jetpack4.6.2, L4T r32.7.2
- Jetpack4.6.3, L4T r32.7.3
- Jetpack5.0.1DP,L4T r34.1.1
- Jetpack5.0.2, L4T r35.1
- Jetpack5.1, L4T r35.2.1
- Jetpack5.1.1, L4T r35.3.1
- Jetpack5.1.2, L4T r35.4.1
- Jetpack5.1.3, L4T r35.5
It means L4t Verion is 32.4.3
2.1 Cross-compiling Toolchain
- Jetpack4.xPlease refer to this link to install toolchain on your Host PC.
- Jetpack5.x
- Jetpack4.2.2
- Jetpack4.3
- Jetpack4.4
- Jetpack4.4.1
- Jetpack4.5
- Jetpack4.5.1
- Jetpack4.5.1
- Jetpack4.6
- Jetpack4.6.1
- Jetpack4.6.2
- Jetpack5.0.1 DP
- Jetpack5.0.2
./source_sync.sh -t jetson_35.1
- Jetpack5.1
./source_sync.sh -t jetson_35.2.1
- Jetpack5.1.1
./source_sync.sh -t jetson_35.3.1
- Jetpack5.1.2
./source_sync.sh -t jetson_35.4.1
- Jetpack5.1.3
./source_sync.sh -t jetson_35.5
export LOCALVERSION=-tegra
export COMMON_DTS_PATH=$TEGRA_KERNEL_OUT/arch/arm64/boot/dts/
- Jetpack 4.x only
- Jetpack 5.x only
export CROSS_COMPILE_AARCH64_PATH=$HOME/l4t-gcc
export CROSS_COMPILE_AARCH64=$HOME/l4t-gcc/bin/aarch64-buildroot-linux-gnu-
export CROSS_COMPILE=$CROSS_COMPILE_AARCH64
export COMMON_DTS_PATH=$TEGRA_KERNEL_OUT/arch/arm64/boot/dts/nvidia
4 Build kernel
For Jetpack version 4.x and for using MV series cameras under Jetpack version 5.x, the kernel needs to be compiled.
This patch has two features:
cd $L4T_DIR/sources/kernel/
4.2.1 patch code
Modify the Kconfig and Makefile files under the $NVIDIA_PATH/drivers/media/i2c/
directory to add the corresponding camera driver compilation options.
4.2.3 build
4.3.1 build
./nvbuild.sh -o $TEGRA_KERNEL_OUT
nvbuild.sh
is only included in the kernel_src.tbz2
tar file that is part of public_sources.tbz2
. If the kernel sources were synced from the Git server, you need to manually copy nvbuild.sh
from the tar file.
4.4 Build completed
Install Image for Flashing:
- For Xavier and Orin,need sign the file
5 Build modules(Jetpack5.x)
For version later than Jetpack 5.x, can compile the driver directly as modules to get the ko file. It is recommended to compile the driver directly on Jetson Board.
cd $RELEASE_PACK_DIR/drivers_source/cam_drv_src/
make -f Makefile
6 Build DTS
Patch code first.
6.1 Nano
For <camera model>
6.2 TX2
For <camera model>
6.3 AGX Xavier
For <camera model>
6.4 NX
For <camera model>
6.5 Orin
cp $RELEASE_PACK_DIR/Orin/JetPack_<ver>_Linux_JETSON_ORIN_TARGETS/dts\ dtb/common/t23x/* -r $ORIN_DTS_PATH/
For <camera model>
cp $RELEASE_PACK_DIR/Orin/JetPack_<ver>_Linux_JETSON_ORIN_TARGETS/dts\ dtb/<camera model>/tegra234-p3737-camera-modules.dtsi $ORIN_DTS_PATH/concord/kernel-dts/cvb/
cp $RELEASE_PACK_DIR/Orin/JetPack_<ver>_Linux_JETSON_ORIN_TARGETS/dts\ dtb/<camera model>/tegra234-p3768-0000-a0.dtsi $ORIN_DTS_PATH/p3768/kernel-dts/cvb
6.6 build
- For Jetpack4.X
- For Jetpack5.X
cd $L4T_DIR/sources/kernel/kernel-5.10/
6.6.1 Nano
6.6.2 TX2
6.6.4 AGX XAVIER
6.6.5 XAVIER NX
6.6.6 AGX Orin
$COMMON_DTS_PATH/tegra234-p3701-0000-p3737-0000.dtb
6.6.7 Orin Nano
$COMMON_DTS_PATH/tegra234-p3767-0003-p3768-0000-a0.dtb
$COMMON_DTS_PATH/tegra234-p3767-0004-p3768-0000-a0.dtb
6.6.8 Orin NX
$COMMON_DTS_PATH/tegra234-p3767-0000-p3768-0000-a0.dtb
$COMMON_DTS_PATH/tegra234-p3767-0001-p3768-0000-a0.dtb
