MV-MIPI-IMX296M Data Sheet
MV-MIPI-IMX296M is a 1.55M MONO industrial camera with MIPI interface.
- 1/2.9'' 1.55M Pixel SONY IMX296LLR-C Pregius Global Shutter CMOS SENSOR
- MIPI CSI-2 Interface
- Mono-8、Mono-10 Data Format
- Video streaming mode(Free Running), Normal Trigger Mode, Pulse Trigger Mode
- Strobe synchronization
- ROI
- USER Output
3 Technical Detail
| Technical Details | |
| Sensor Type | CMOS |
| Shutter Mode | Global Shutter |
| Sensor | SONY IMX296LLR-C Pregius |
| Color | MONO |
| Image Size | 1/2.9'' |
| Unit Cell Size | 3.45μm × 3.45μm |
| Resolution | 1456(H) × 1088(V) |
| Max Frame Rate | 1456×1088 @ 60.3fps |
| Gain | 0 dB to 24 dB: Analog Gain (0.1 dB step)
| ADC Resolution | 10 bit |
| Pixel Format | Mono8,Mono10,UYVY 8bit |
| ROI | Support |
| Working Mode | Video streaming mode(Free Running), Normal Trigger Mode, Pulse Trigger Mode |
| Trigger Source | Hardware,Software |
Data Rate / lane:1.485Gbps |
| Power Supply | 5VDC |
| Power Consumption | 0.95W@ 5V DC |
| Structure | |
| Lens Mount | C-MOUNT03,S-MOUNT01 |
| Operating Conditions | |
| IMX296LLR-C |
5 Interface & Pin list
| J3: CSI-2 Interface,Up Contact | ||
| Pin NO. | NAME | Remarks |
| 2 | VCC | 5V |
| 3 | VCC | 5V |
| 4 | VCC | 5V |
| 5 | VCC | 5V |
| 6 | GND | |
| 7 | ENABLE | Power Enable,3.3V,ACTIVE High |
| 8 | GND | |
| 11 | GND | |
| 14 | GND | |
| 17 | GND | |
| 18 | MIPI_L2_N | Reserved |
| 19 | MIPI_L2_P | Reserved |
| 20 | GND | |
| 21 | MIPI_L3_N | Reserved |
| 22 | MIPI_L3_P | Reserved |
| 23 | GND | |
| 26 | GPIO3 | Reserved |
| 27 | OUT_2 | Multi-function Port 2,3.3V level |
| 28 | OUT_1 | Multi-function Port 1,3.3V level |
| 29 | TriggerIN | Hardware Trigger in,3.3V level |
| 30 | GND | |
6 Board Dimension
7 PCBA 3D STP File
