Mv mipi i2c.sh user guide
Running
3 Download
Below is the list:
3.1 Nvidia Jetson:
3.2 Raspberry Pi:
3.3 RK35xx:
https://github.com/veyeimaging/rk35xx_firefly/tree/main/mv_tools_rockchip/i2c_tools
4 Prepare
cd mv_tools_rpi/sources/
./make.sh
cd ..
5 mv_mipi_i2c.sh USAGE
./mv_mipi_i2c.sh
    -r                       read
6 mv_mipi_i2c_new.sh USAGE
This script is a simplified version of mv_mipi_i2c.sh, in which -f -p1 -p2 -p3 -p4 is no longer needed.
$ ./mv_mipi_i2c_new.sh
Usage:  ./mv_mipi_i2c.sh [-r/w]  [function name] [param1] [param2 ] [param3] [param4] -b bus
    -r                       read
8 Functions list
8.1 Note
8.2 Basic Parameters
8.2.1 manufacturer
./mv_mipi_i2c.sh -r -f manufacturer -b your_i2c_bus_number
8.2.2 model
./mv_mipi_i2c.sh -r -f model -b your_i2c_bus_number
8.2.3 version
./mv_mipi_i2c.sh -r -f version -b your_i2c_bus_number
8.2.4 serialno
./mv_mipi_i2c.sh -r -f serialno -b your_i2c_bus_number
8.2.5 timestamp
./mv_mipi_i2c.sh -r -f timestamp -b your_i2c_bus_number
8.2.6 errcode
./mv_mipi_i2c.sh -r -f errcode -b your_i2c_bus_number
bit0: sensor error.
bit6: Authorization failure.
8.2.7 fmtcap
./mv_mipi_i2c.sh -r -f fmtcap -b your_i2c_bus_number
bit3: Mono14
8.2.8 trgmodecap
./mv_mipi_i2c.sh -r -f trgmodecap -b your_i2c_bus_number
bit0:Video streaming mode.
bit1:Normal trigger mode.
bit3: Pulse trigger mode.
8.2.9 factoryparam
./mv_mipi_i2c.sh -w -f factoryparam -b your_i2c_bus_number
8.2.10 paramsave
./mv_mipi_i2c.sh -w -f paramsave -b your_i2c_bus_number
8.2.11 reboot
./mv_mipi_i2c.sh -w -f reboot -b your_i2c_bus_number
Reboot the camera.
8.2.12 i2caddr
./mv_mipi_i2c.sh -w -f i2caddr -p1 [new] -b your_i2c_bus_number
./mv_mipi_i2c.sh -r -f i2caddr -b your_i2c_bus_number
8.2.13 slavemode
./mv_mipi_i2c.sh -w -f slavemode -p1 [0/1] -b your_i2c_bus_number
./mv_mipi_i2c.sh -r -f slavemode -b your_i2c_bus_number
8.2.14 mcubypass
./mv_mipi_i2c.sh -w -f mcubypass -p1 [0/1] -b your_i2c_bus_number
./mv_mipi_i2c.sh -r -f mcubypass -b your_i2c_bus_number
8.3 Image Acquisition
8.3.1 imgacq
./mv_mipi_i2c.sh -w -f imgacq -p1 [0/1] -b your_i2c_bus_number
Start/Stop acquisition
8.3.2 trgmode*
./mv_mipi_i2c.sh -w -f trgmode -p1 [0,2] -b your_i2c_bus_number
./mv_mipi_i2c.sh -r -f trgmode -b your_i2c_bus_number
value description
0 Video streaming mode
1 Normal trigger mode
3 Pulse trigger mode
8.3.3 trgsrc*
./mv_mipi_i2c.sh -w -f trgsrc -p1 [0,1] -b your_i2c_bus_number
./mv_mipi_i2c.sh -r -f trgsrc -b your_i2c_bus_number
value description
0 Software trigger
1 Hardware trigger
8.3.4 trgnum*
./mv_mipi_i2c.sh -w -f trgnum -p1 [1,255] -b your_i2c_bus_number
./mv_mipi_i2c.sh -r -f trgnum -b your_i2c_bus_number
8.3.5 trginterval*
./mv_mipi_i2c.sh -w -f trginterval -p1 [us] -b your_i2c_bus_number
./mv_mipi_i2c.sh -r -f trginterval -b your_i2c_bus_number
8.3.6 trgone
./mv_mipi_i2c.sh -w -f trgone -b your_i2c_bus_number
8.3.7 trgcount
./mv_mipi_i2c.sh -r -f trgcount -b your_i2c_bus_number
Trigger count statistics.
./mv_mipi_i2c.sh -w -f trgcountclr -b your_i2c_bus_number
Clear trigger count.
8.3.8 framecount
./mv_mipi_i2c.sh -r -f framecount -b your_i2c_bus_number
Frame count statistics.
8.4 IO Control
8.4.1 trgdelay*
./mv_mipi_i2c.sh -r -f trgdelay -b your_i2c_bus_number
./mv_mipi_i2c.sh -w -f trgdelay -p1 [us] -b your_i2c_bus_number
8.4.2 trgedge*
./mv_mipi_i2c.sh -r -f trgedge -b your_i2c_bus_number
./mv_mipi_i2c.sh -w -f trgedge -p1 [0,1] -b your_i2c_bus_number
value description
0 Rising edge
1 Falling edge
8.4.3 trgfilter_enable*
./mv_mipi_i2c.sh -r -f trgfilter_enable -b your_i2c_bus_number
./mv_mipi_i2c.sh -w -f trgfilter_enable -p1 [0,2] -b your_i2c_bus_number
value description
0 No filtering
8.4.4 trgfilter_time*
./mv_mipi_i2c.sh -r -f trgfilter_time -b your_i2c_bus_number
./mv_mipi_i2c.sh -w -f trgfilter_time -p1 [us] -b your_i2c_bus_number
8.4.5 trgexp_delay*
./mv_mipi_i2c.sh -r -f trgexp_delay -b your_i2c_bus_number
./mv_mipi_i2c.sh -w -f trgexp_delay -p1 [us] -b your_i2c_bus_number
8.4.6 gpios_status
./mv_mipi_i2c.sh -r -f gpios_status -b your_i2c_bus_number
8.4.7 outio1_mode
./mv_mipi_i2c.sh -r -f outio1_mode -b your_i2c_bus_number
./mv_mipi_i2c.sh -w -f outio1_mode -p1 [0,1] -b your_i2c_bus_number
value description
0 strobe
1 user out
strobe: High level active.
8.4.8 outio1_usr
./mv_mipi_i2c.sh -r -f outio1_usr -b your_i2c_bus_number
./mv_mipi_i2c.sh -w -f outio1_usr -p1 [0,1] -b your_i2c_bus_number
value description
0 low
1 high
8.4.9 outio1_rvs
./mv_mipi_i2c.sh -r -f outio1_rvs -b your_i2c_bus_number
./mv_mipi_i2c.sh -w -f outio1_rvs -p1 [0,1] -b your_i2c_bus_number
8.4.10 outio2_mode
./mv_mipi_i2c.sh -r -f outio2_mode -b your_i2c_bus_number
./mv_mipi_i2c.sh -w -f outio2_mode -p1 [0,5] -b your_i2c_bus_number
value description
0 strobe
1 user out
2 trigger wait
3 XVS
4 XHS
8.4.11 outio2_usr
./mv_mipi_i2c.sh -r -f outio2_usr -b your_i2c_bus_number
./mv_mipi_i2c.sh -w -f outio2_usr -p1 [0,1] -b your_i2c_bus_number
value description
0 low
1 high
8.4.12 outio2_rvs
./mv_mipi_i2c.sh -r -f outio2_rvs -b your_i2c_bus_number
./mv_mipi_i2c.sh -w -f outio2_rvs -p1 [0,1] -b your_i2c_bus_number
8.5 Image Features
8.5.1 maxwh
./mv_mipi_i2c.sh -r -f maxwh -b your_i2c_bus_number
8.5.2 maxfps
./mv_mipi_i2c.sh -r -f maxfps -b your_i2c_bus_number
8.5.3 fps*
./mv_mipi_i2c.sh -w -f fps -p1 [framerate] -b your_i2c_bus_number
./mv_mipi_i2c.sh -r -f fps -b your_i2c_bus_number
Range:(0,maxfps].
8.5.4 roi*
./mv_mipi_i2c.sh -w -f roi -p1 [x] -p2 [y] -p3 [width] -p4 [height] -b your_i2c_bus_number
./mv_mipi_i2c.sh -r -f roi -b your_i2c_bus_number
Parameter requirements:
[width] must be 8-aligned;
8.5.5 imgdir
./mv_mipi_i2c.sh -w -f imgdir -p1 [0,3] -b your_i2c_bus_number
./mv_mipi_i2c.sh -r -f imgdir -b your_i2c_bus_number
value description
0 normal
1 mirror
2 flip
3 flip&mirror
8.5.6 pixelformat
./mv_mipi_i2c.sh -w -f pixelformat -p1 [0,2] -b your_i2c_bus_number
./mv_mipi_i2c.sh -r -f pixelformat -b your_i2c_bus_number
value description
0 Mono8
1 Mono10
2 Mono12
4 UYVY
8.5.7 blacklevel
./mv_mipi_i2c.sh -w -f blacklevel -p1 [blacklevel] -b your_i2c_bus_number
./mv_mipi_i2c.sh -r -f blacklevel -b your_i2c_bus_number
8.5.8 blcmode
./mv_mipi_i2c.sh -w -f blcmode -p1 [0/1] -b your_i2c_bus_number
./mv_mipi_i2c.sh -r -f blcmode -b your_i2c_bus_number
8.5.9 testimg
./mv_mipi_i2c.sh -w -f testimg -p1 [0,2] -b your_i2c_bus_number
./mv_mipi_i2c.sh -r -f testimg -b your_i2c_bus_number
value description
0 Normal image
1 Test image 1
2 Test image 2
8.5.10 lanenum*
./mv_mipi_i2c.sh -w -f lanenum -p1 [2/4] -b your_i2c_bus_number
./mv_mipi_i2c.sh -r -f lanenum -b your_i2c_bus_number
8.5.11 mipidatarate
./mv_mipi_i2c.sh -r -f mipidatarate -b your_i2c_bus_number
8.6 ISP
8.6.1 Special Note
8.6.2 gamma
./mv_mipi_i2c.sh -r -f gamma -b your_i2c_bus_number
./mv_mipi_i2c.sh -w -f gamma -p1 [gamma] -b your_i2c_bus_number
8.6.3 gammaenable
./mv_mipi_i2c.sh -r -f gammaenable -b your_i2c_bus_number
./mv_mipi_i2c.sh -w -f gammaenable -p1 [0,1] -b your_i2c_bus_number
8.6.4 dpcenable
./mv_mipi_i2c.sh -r -f dpcenable -b your_i2c_bus_number
./mv_mipi_i2c.sh -w -f dpcenable -p1 [0,1] -b your_i2c_bus_number
8.6.5 lutenable
./mv_mipi_i2c.sh -r -f lutenable -b your_i2c_bus_number
./mv_mipi_i2c.sh -w -f lutenable -p1 [0,1] -b your_i2c_bus_number
8.6.6 lut
./mv_mipi_i2c.sh -r -f lut -p1 [lutfilename] -b your_i2c_bus_number
./mv_mipi_i2c.sh -w -f lut -p1 [lutfilename] -b your_i2c_bus_number
8.6.7 expmode
./mv_mipi_i2c.sh -r -f expmode -b your_i2c_bus_number
./mv_mipi_i2c.sh -w -f expmode -p1 [0,2] -b your_i2c_bus_number
value description
0 ME: manual exposure
1 AE once: auto exposure once
8.6.8 metime
./mv_mipi_i2c.sh -w -f metime -p1 [us] -b your_i2c_bus_number
./mv_mipi_i2c.sh -r -f metime -b your_i2c_bus_number
8.6.9 gainmode
./mv_mipi_i2c.sh -r -f gainmode -b your_i2c_bus_number
./mv_mipi_i2c.sh -w -f gainmode -p1 [0,3] -b your_i2c_bus_number
value description
0 MG: manual gain
1 AG once: auto gain once
2 AG: auto gain continuous
8.6.10 mgain
./mv_mipi_i2c.sh -w -f mgain -p1 [gain] -b your_i2c_bus_number
./mv_mipi_i2c.sh -r -f mgain -b your_i2c_bus_number
8.6.11 aatarget
./mv_mipi_i2c.sh -r -f aatarget -b your_i2c_bus_number
./mv_mipi_i2c.sh -w -f aatarget -p1 [1,255] -b your_i2c_bus_number
8.6.12 aemaxtime
./mv_mipi_i2c.sh -r -f aemaxtime -b your_i2c_bus_number
./mv_mipi_i2c.sh -w -f aemaxtime -p1 [16,1000000/fps] -b your_i2c_bus_number
8.6.13 agmaxgain
./mv_mipi_i2c.sh -r -f agmaxgain -b your_i2c_bus_number
./mv_mipi_i2c.sh -w -f agmaxgain -p1 [0,maxgain] -b your_i2c_bus_number
8.6.14 exptime
./mv_mipi_i2c.sh -r -f exptime -b your_i2c_bus_number
8.6.15 curgain
./mv_mipi_i2c.sh -r -f curgain -b your_i2c_bus_number
8.6.16 aaroienable
./mv_mipi_i2c.sh -w -f aaroienable -p1 [0,1] -b your_i2c_bus_number
./mv_mipi_i2c.sh -r -f aaroienable -b your_i2c_bus_number
8.6.17 aaroi
./mv_mipi_i2c.sh -w -f aaroi -p1 [x] -p2 [y] -p3 [width] -p4 [height] -b your_i2c_bus_number
./mv_mipi_i2c.sh -r -f aaroi -b your_i2c_bus_number
8.6.18 aeag_run_once_save
./mv_mipi_i2c.sh -w -f aeag_run_once_save -b your_i2c_bus_number
  2. Run AE once and AG once.
  3. Wait 5 seconds.
8.6.19 snsreg
./mv_mipi_i2c.sh -r -f snsreg -p1 [sensor reg addr] -b your_i2c_bus_number
8.7 Notes
9.1 Manual Exposure Mode:
 ./mv_mipi_i2c.sh -w -f expmode -p1 0 -b your_i2c_bus_number
./mv_mipi_i2c.sh -w -f gainmode -p1 0 -b your_i2c_bus_number
./mv_mipi_i2c.sh -w -f metime -p1 exptime_you_want_to_set_us -b your_i2c_bus_number
./mv_mipi_i2c.sh -w -f mgain -p1 gain_you_want_to_set_dB -b your_i2c_bus_number
./mv_mipi_i2c.sh -w -f expmode -p1 2 -b your_i2c_bus_number
./mv_mipi_i2c.sh -w -f gainmode -p1 2 -b your_i2c_bus_number
./mv_mipi_i2c.sh -w -f aatarget -p1 brightness_target -b your_i2c_bus_number
9.3 Normal Trigger Mode:
   ./mv_mipi_i2c.sh -w -f imgacq -p1 0 -b your_i2c_bus_number
./mv_mipi_i2c.sh -w -f trgmode -p1 1 -b your_i2c_bus_number
./mv_mipi_i2c.sh -w -f trgsrc -p1 1 -b your_i2c_bus_number
./mv_mipi_i2c.sh -w -f trgnum -p1 1 -b your_i2c_bus_number
 ./mv_mipi_i2c.sh -w -f imgacq -p1 1 -b your_i2c_bus_number
