RAW-MIPI-SC132M Data Sheet
RAW-MIPI-SC132M is a 1.3 million MONO industrial camera with MIPI interface.
- 1/4'' 1.3M Pixel SmartGS® SC132GS CMOS Sensor
- MIPI CSI-2 Interface
- Mono-8、Mono-10 Data Format
- Video streaming mode,Trigger mode
- Support trigger delay, trigger count function
- Strobe synchronization
- ROI
- Support Sensor Direct Access mode
3 Technical Detail
Technical Details
Sensor Type
CMOS
Shutter Mode
Global Shutter
Sensor
SmartGS® SC132GS
Color
MONO
Image Size
1/4''
Unit Cell Size
2.7μm × 2.7μm
Resolution
1080(H) × 1280(V)
Max Frame Rate
1080 × 1280@120fps
Gain
0-40dB,0.1dB step
Exposure Time
≤ 1/(max frame rate)
Shutter Mode
Manual Exposure,Manual Gain
ADC Resolution
10 bit
Pixel Format
Mono8,Mono10
ROI
Support
Mirror Image
Mirror and Flip
Working Mode
Hardware Trigger,Software Trigger,Video streaming mode
Trigger Mode
Trigger Delay,Trigger Polarity Control
Strobe Mode
Strobe Output
Electrical characteristics
Data Interface
CSI-2 : 2 Data Lanes
Data Rate / lane:1.188Gbps
Communication Interface
I2C 3.3V
Digital IO
Non-isolation IO:1 Trigger in,2 Strobe output,3.3V Level
Power Supply
3.3V DC
Power Consumption
TBD
Structure
Size
Length * width * height = 29*29*11mm
Lens Mount
C-MOUNT01 or M12 holder
Operating Conditions
Temperature
Operating temperature:-30℃~ 60℃
Humidity
Humidity 95% or less
Sensor
SC132GS-M
5 Interface & Pin list
J1 : CSI-2 Interface
Pin NO.
NAME
Remarks
GND
MIPI_L0_N
MIPI_L0_P
GND
MIPI_L1_N
MIPI_L1_P
7
GND
8
MIPI_CK_N
9
MIPI_CK_P
10
GND
11
ENABLE
Camera Power Enable
12
NC
13
SCL
3.3V Level
14
SDA
3.3V Level
15
VCC3V3
J2 : GPIO
Pin NO.
NAME
Remarks
Trigger In
3.3V level
GND
Strobe Out
3.3V level
6 Board Dimension
Download 2D DXF file
7 PCBA 3D STP File
Download 3D STP file
