VEYE CS Camera on AVNET Maaxboard
The MIPI-CSI2 interface of Maaxboard is the same as that of Raspberry pi. VEYE-MIPI-327S, CS-MIPI-IMX307, CS-MIPI-SC132 can be directly connected to use without using the adapter board.
On the basis of Maaxboard official SDK, our camera module driver is added, and some application layer routines are provided.
1 Camera module list
CS series CS-MIPI-IMX307 Done
CS series CS-MIPI-SC132 Done
Maaxboard connection overview
MaaxBoard connection details
3 Upgrade Maaxboard system
3.1 Overview
This section describes how to update the Maaxboard system to support our camera module. To support our camera module, we need to update two parts of the system, Image and DTB.
3.2 BSP package introduction
3.2.1 i.MX platform bsp
includes:
  • driver source code
  • i2c toolkits
  • application demo
3.2.2 Maaxboard i.MX platform bsp
includes:
  • prebuild linux kernel:Image
  • dts source code
3.3 Burn the Maaxboard standard system
Maaxboard supports Linux Debain, Linux Yocto, and Android systems. Under the Linux system, Image and dtb are the same, we use the Debain system as an example.
Refer to the MaaXBoard-Linux-Debian-UserManual-V1.3-EN.pdf or MaaXBoard_Mini-Linux-Debian-UserManual-V1.1-CN.pdf documentation and burn the standard system.
The Image and dtb files of the Maaxboard board are saved in the FAT partition of TF card. After the system is started, it is automatically mounted to the /boot/ directory.
On HOST PC:
Extract kernel Image, and put Image and em-sbc-imx8m- [camname] .dtb into the FAT partition of the TF card.
Modify the value of fdt_file in the uEnv.txt file to specify the camera model.
Then insert the TF card into the Maaxboard board and power it up again.
4 Applications and Test
4.1 Check system status
  • VEYE-MIPI-IMX327S
camera veye327_mipi is found
Registered sensor subdevice: veye327_mipi 0-003b
  • CS-MIPI-IMX307
dmesg | grep csimx307
camera csimx307_mipi is found
Registered sensor subdevice: csimx307_mipi 0-003b
  • CS-MIPI-SC132
camera cssc132_mipi is found
The cameras of the MIPI-CSI2 interface is identified and mounted to i2-0.
4.2 List the modes supported by the camera
v4l2-ctl --list-formats-ext -d /dev/video<0/1>
4.3 Video Stream test
  • Preview (VEYE-MIPI-IMX327S,CS-MIPI-IMX307 @1080p mode)
gst-launch-1.0 v4l2src device=/dev/video0 ! 'video/x-raw,width=1920,height=1080,framerate=(fraction)30/1' ! waylandsink
  • Frame rate display VEYE-MIPI-IMX327S,CS-MIPI-IMX307 @1080p mode)
gst-launch-1.0 v4l2src device=/dev/video0 ! 'video/x-raw,width=1920,height=1080,framerate=(fraction)30/1' ! fpsdisplaysink video-sink=fakesink -v
  • Preview (CS-MIPI-IMX307 @1080p mode 10fps)
gst-launch-1.0 v4l2src device=/dev/video0 ! 'video/x-raw,width=1920,height=1080,framerate=(fraction)10/1' ! waylandsink
  • Preview (CS-MIPI-IMX307 @720p mode 60fps)
gst-launch-1.0 v4l2src device=/dev/video0 ! 'video/x-raw,width=1280,height=720,framerate=(fraction)60/1' ! waylandsink
  • Preview (CS-MIPI-SC132 @1280*1080 mode 45fps)
gst-launch-1.0 v4l2src device=/dev/video0 ! 'video/x-raw,width=1280,height=1080,framerate=(fraction)45/1' ! waylandsink
  • Preview (CS-MIPI-SC132 @1080*1280 mode 45fps)
gst-launch-1.0 v4l2src device=/dev/video0 ! 'video/x-raw,width=1080,height=1280,framerate=(fraction)45/1' ! waylandsink
  • Snap a picture (VEYE-MIPI-327S,CS-MIPI-IMX307 @1080p mode)
gst-launch-1.0 v4l2src num-buffers=1 device=/dev/video0 ! 'video/x-raw, width=1920,height=1080' ! jpegenc ! filesink location=test_image.jpg
  • Snap a picture (CS-MIPI-IMX307 @720p mode)
gst-launch-1.0 v4l2src num-buffers=1 device=/dev/video0 ! 'video/x-raw, width=1280,height=720' ! jpegenc ! filesink location=720p.jpg
  • Snap a picture (CS-MIPI-SC132 @1280*1080 mode)
gst-launch-1.0 v4l2src num-buffers=1 device=/dev/video0 ! 'video/x-raw, width=1280,height=1080' ! jpegenc ! filesink location=test_image.jpg
  • v4l2grab snap a picture(VEYE-MIPI-327S,CS-MIPI-IMX307 @1080p mode)
4.4 Video Control Toolkits Manual
  • VEYE series
  • CS series
The following operations are done on ubuntu Host PC.
5.1 Compile the standard version
Refer to the official document MaaXBoard-Linux-Development_Guide-V1.1-EN.pdf.
5.1.1 Set up the Host PC environment
export PATH=$PATH:[REPLACE with your path]/toolchain/gcc-linaro-7.3.1-2018.05-x86_64_aarch64-linux-gnu/bin/
  • Maaxboard
make bcm2711_defconfig
make -j4
5.2 patch code
  • Driver source code
The source code path of the camera driver is: linux/drivers/media/platform/mxc/capture, places the source code of the camera driver in the corresponding directory.
Modify the Config and Makefile in the same path. Add the corresponding camera driver.
  • dts file
Modify the Config and Makefile in the same path. Add the corresponding dts option.
5.3 Add compilation options
make menuconfig
Add the compilation options for the corresponding camera module driver, and the path is Device Drivers > Multimedia support > V4L platform devices > MXC Camera/V4L2 PRP Features support.
5.4 Build
make Image dtbs -j4
6 References
Maaxboard embest-tech official site :https://www.avnet.com/wps/portal/us/products/new-product-introductions/npi/avnet-maaxboard/
Maaxboard :http://Avnet.com/MAAXBOARD
