CS-MIPI-X i2c
Contents
- 1 Introduction
- 2 RaspberryPi Only, Set IO config
- 3 cs_mipi_i2c.sh USAGE
- 3.1 devid
- 3.2 hdver
- 3.3 firmwarever
- 3.4 productmodel
- 3.5 camcap
- 3.6 videofmtcap
- 3.7 videofmt
- 3.8 ispcap
- 3.9 powerhz
- 3.10 i2caddr
- 3.11 paramsave
- 3.12 sysreset
- 3.13 streammode
- 3.14 daynightmode
- 3.15 hue
- 3.16 contrast
- 3.17 satu
- 3.18 expmode
- 3.19 aetarget
- 3.20 aetime
- 3.21 aeagc
- 3.22 metime
- 3.23 meagain
- 3.24 medgain
- 3.25 awbmode
- 3.26 mwbgain
- 3.27 mwbcolortemp
- 3.28 expostate
- 3.29 wbstate
- 3.30 imagedir
- 3.31 sreg
- 3.32 striggerone
- 3.33 triggeredge
- 3.34 tgdebncr
- 3.35 tgdly
- 3.36 pickmode
- 3.37 pickone
- 3.38 sysreboot
- 3.39 ledstrobe
- 3.40 expfrmmode
- 3.41 slowshuttergain
Running
2.1 camera_i2c_config USAGE
- for standard RPI, just run
- for RPI Computer Module
cameranum | description |
0 | CAM0 |
1 | CAM1 |
./cs_mipi_i2c.sh
daynightmode ,hue ,contrast , satu , expostate , wbstate ,expmode , aetarget, aetime,aeagc,metime ,meagain , medgain , awbmode , mwbcolortemp , mwbgain,imagedir,sreg,striggerone,triggeredge,autotgcnt,tgdebncr,tgdly,pickmode,discardfrm,pickone,mipistatus,sysreboot,sysreset,paramsave
3.1 devid
./cs_mipi_i2c.sh -r -f devid
0x02 | 2 lan mipi |
3.2 hdver
get hardware logic version
value | description |
0xXY | Version X.Y |
for example:
0x22 means V2.2
3.3 firmwarever
3.4 productmodel
get product model,for example:CS-MIPI-IMX307,CS-MIPI-SC132
3.5 camcap
./cs_mipi_i2c.sh -r -f camcap
get camera module capbility, each bit represents a function.
bit | description |
0 | sync stream mode |
1 | trigger mode |
2 | pick mode |
3.6 videofmtcap
get camera video format capbility, for example:
1920*1080 @max30fps
1280*720 @max60fps
3.7 videofmt
3.7.1 old version videofmt write
get and set current video format,for example:
1920*1080@10fps
1280*720@60fps
640*480@130fps
If camera support framerate continuously adjustable:
CS-MIPI-IMX307 framerate range: [1,maxframerate]
CS-MIPI-SC132framerate range: [2,maxframerate]
note:sync mode do not support framerate continuously adjustable.
3.7.2 new version videofmt write
Note: supported on CS-MIPI-IMX307 firmware > V2.35.
./cs_mipi_i2c.sh -w -f videofmt -p1 1920 -p2 1080 -p4 0.20
p4 parameter, which supports the decimal frame rate function and is used to support manual exposure mode for more than 1 second.
3.8 ispcap
./cs_mipi_i2c.sh -r -f ispcap
get camera isp capbility. Will add details later.
3.9 powerhz
50 | Power frequency is 50Hz |
60 | Power frequency is 60Hz |
- 50Hz framerate is 25、50、100;60Hz framerate is 30、60、120.
- camera support antiflicker, accroding to powerhz setting here.
3.10 i2caddr
3.11 paramsave
3.12 sysreset
The camera reset to the factory default parameters.
3.13 streammode
0 | free running |
1 | sync mode |
2 | Hardware Trigger |
3 | Software Trigger |
Read the current stream mode and master-slave mode
- free running mode
Set the current camera to free running mode
slave mode(sync stream mode)
0 | master |
1 | slave |
Set the current camera to sync mode, and set to master
Set the current camera to sync mode, and set to slave
sync mode :Camera module Stream Mode manual
In sync mode,do not support framerate continuously adjustable.
If powerhz is 60,support 1080p@30,720p@60,vga@130.
If powerhz is 50,support 1080p@25,720p@50,vga@130.
- Trigger mode
Set the current camera to hardware trigger mode
Set the current camera to software trigger mode
3.14 daynightmode
0x1 | Color Mode |
0x2 | Black&White Mode |
0x0 | Trigger Mode |
0x3 | IR-CUT day, Image Black&White mode |
0x4 | IR-CUT night, Image Color mode |
- Color Mode
- Black&White Mode
- Trigger Mode
Trigger pin : J4 pin1.
3.15 hue
./cs_mipi_i2c.sh -r -f hue
hue,range [0,100].
3.16 contrast
contrast,range [0,100].
3.17 satu
./cs_mipi_i2c.sh -r -f satu
saturation,range [0,100].
3.18 expmode
0 : auto exposure
1: manual exposure
3.19 aetarget
The target brightness in automatic exposure mode. Effective when expmode is auto.
range:[0,255]
3.20 aetime
./cs_mipi_i2c.sh -r -f aetime
the max exposure time in automatic exposure mode,unit: us。Effective when expmode is auto.
range:(100,1/framerate],if framerate is 30,then the range is (100,33333].
special value:0xFFFFFFFF=1/framerate, the camera will automatically adjust according to the working mode.
3.21 aeagc
./cs_mipi_i2c.sh -r -f aeagc
Maximum total system gain in automatic exposure mode,unit: dB. Effective when expmode is auto.
agc includes Again+Dgain+ISPGain.
X range: depending on sensor.
Y range: [0-9].
3.22 metime
./cs_mipi_i2c.sh -r -f metime
manual exposure time, us.
range:[0-1000000/framerate]
If you need ultra-long exposure, you need to adjust the framerate to match this parameter.
3.23 meagain
manual again,dB. Effective when expmode is manual.
Y range: [0-9].
3.24 medgain
manual dgain,dB. Effective when expmode is manual.
Y range: [0-9].
3.25 awbmode
0 : auto white balance
3.26 mwbgain
3.27 mwbcolortemp
manual white balance, color temperature mode, color tempture,range [1500,15000]
3.28 expostate
3.29 wbstate
3.30 imagedir
set image direction
0 | normal |
1 | flip |
2 | mirror |
3 | flip+mirror |
3.31 sreg
read the sensor register, indirect access.
for example: CS-MIPI-IMX307
3.32 striggerone
In Software Trigger Mode,Trigger an exposure and image output by writing a register.
note: Only CS-MIPI-SC132 support.
3.33 triggeredge
Edge attribute of trigger signal in Hardware Trigger mode.
0 | RisingEdge |
1 | FallingEdge |
note: Only CS-MIPI-SC132 Support.
3.34 tgdebncr
./cs_mipi_i2c.sh -w -f triggeredge -p1 enable -p2 [value]
In Hardware Trigger mode,the debouncer attribute of the trigger signal.
Any trigger signal that is less than value (us) will be ignored.
3.35 tgdly
./cs_mipi_i2c.sh -r -f tgdly
Trigger delay in Hardware Trigger mode (us).
3.36 pickmode
Pickmode is a special function, once turned on, sensor works normally, but the module will not output images, only receive pickone instructions, output one.
3.37 pickone
When pickmode is enable, output one image.
3.38 sysreboot
reboot the camera module
1 | Restart the main program |
2 | Fully reboot (6-8s) |
3.39 ledstrobe
Whether the LED synchronization signal is enabled.
If enabled, the Strobe IO pin outputs a high level when the sensor is exposed.
3.40 expfrmmode
./cs_mipi_i2c.sh -w -f expfrmmode -p1 [value]
0 | slow shutter mode |
1 | fix framerate mode(default) |
Effective in auto exposure mode.
The slow shutter mode is usually used to reduce picture noise in low-illumination scenes by automatic frame reduction.
It needs to be used with the aetime,slowshuttergain parameter.
Note: only supported on firmware version >= 2.32
./cs_mipi_i2c.sh -w -f slowshuttergain -p1 X -p2 Y
./cs_mipi_i2c.sh -r -f slowshuttergain
In slow shutter mode,the threshold of Gain be begin to drop frame, dB. Effective when expfrmmode is slow shutter mode.
Y range: [0-9].
