CS-MIPI-IMX307 STARVIS Module
Contents
- Built-in ISP processing
- CSI-2 Interface
- Standard lens mount
- IR-CUT circuit
3 Technical Detail
Technical Details | |
SENSOR | |
Sensor | SONY IMX307LQD-C STARVIS |
Pixels | 2.07M pixels |
Resolution | 1920*1080 |
Output Format | Bayer |
Shutter Type | Rolling Shutter |
SNR1s Value | 0.24lx |
ISP | |
Frame Rate | 1920*1080@max25fps / 30fps,
Frame Rate Adjustment | Framerate Continuously Adjustable |
Exposure | Auto or Manual |
Shutter | 1/25(1/30)s to 1/20,000s |
Slow Shutter | Support |
Image Setting | Brightness, Contrast, Sharpness, Gamma, Saturation,Flip, Mirror |
Image Enhancement | BLC, Digtal WDR(TO DO..), Defog |
Video Stream Synchronization | Support Multi-camera Module Video Stream Synchronization |
Other Functions | Pick Mode:Pick Picture from Video Stream |
Lens & IR-CUT | |
Lens | MTV12 / MTV16 / CS |
Lens Mount | M12*P0.5 / M16*P0.5 / CS,IRCUT is optional |
Interface | |
Connector | 15PIN FPC, Compatible with Raspberry PI,JETSON NANO |
Video Data Interface | CSI-2 : 2 Data Lanes, CSI-2 YUV422-8bit Data Type, Datarate=594Mbps/lane |
Day/Night External Trigger | 3.3VDC to 5VDC compatibility |
General | |
Operating Conditions
(Bare PCB) |
Power Supply | 5VDC / 3.3VDC optional |
Power Consumption | 1.4W |
Dimension | 38mm*38mm*12mm(not include lens and lens mount) |
IMX307LQD-C |
5 Interface & Pin list
J1 : Firmware Update | ||
Pin NO. | NAME | Remarks |
1 | VBUS(5V) | Connect the USB upgrade cable & USB disk |
2 | D- | |
3 | D+ | |
4 | GND |
J3 : Power Input | ||
1 | VCC5V | use by default. How to use 3.3V power supply |
2 | GND |
J4 : Day/Night External Trigger | ||
1 | IR LED ON | INPUT,Low level active(Image to MONO),3.3VDC to 12VDC compatibility |
2 | GND | |
3 | RESERVE | NC |
J6 : IRCUT Control | ||
1 | IRCUT1 | |
2 | IRCUT2 |
J6 IRCUT Control Functional specifications | ||||
MODE | pin | Signal polarity | Image type | Filter position |
Mode 1 | IRCUT1 | + | color | Infrared cutoff |
IRCUT2 | - | |||
Mode 2 | IRCUT1 | - | mono | Full wavelength pass |
IRCUT2 | + |
J7 : Multi-function GPIO | ||
1 | GPIO0 | Can Be Configured As Video Stream Synchronization Signal |
2 | GND | |
3 | GPIO1 | Can Be Configured As Video Stream Synchronization Signal |
J8 : CSI-2 Interface | ||
1 | GND | |
2 | MIPI_L0_N | |
3 | MIPI_L0_P | |
4 | GND | |
5 | MIPI_L1_N | |
6 | MIPI_L1_P | |
7 | GND | |
8 | MIPI_CK_N | |
9 | MIPI_CK_P | |
10 | GND | |
11 | NC | |
12 | NC | |
13 | SCL | 3.3V Level |
14 | SDA | 3.3V Level |
15 | VCC3V3 | NC by default,How to use 3.3V power supply |
