GX Camera Application Development Guide
This document applies to scenarios where the camera hardware is correctly connected, the driver is properly installed, and the GX series camera has been successfully recognized.
- Query the device information of the connected GX series camera
2.1 probe_camera_info-rk.sh
Example usage:
$ ./probe_camera_info-rk.sh
cat auto_camera_index.json
"media_node": "/dev/media0",
"video_node": "/dev/video0",
"i2c_bus": "7"
| media_entity_name | Media entity name | Describes the device, e.g., "m00_b_gxcam 7-003b"
2.2 gx_probe.sh
The gx_probe.sh script can configure environment variables with key information for a specific camera, including the I²C bus number, camera model, resolution (width and height), and frame rate. This simplifies subsequent use of media-ctl for format configuration.
The usage method is:
$ source ./gx_probe.sh <i2c_bus>
Example:
$ source ./gx_probe.sh 7
Setenv HEIGHT = 1080
echo $CAMERAMODEL
By using the media-ctl command, the current topology structure can be clearly displayed.
media-ctl -p -d /dev/media0
3.1.1 Link relationship
3.1.2 gx camera entity information
pad0: Source
crop:(0,0)/1920x1080]
It can be seen that:
- The complete name of this Entity is: m00_b_gxcam 7-003b. (On the ROC-RK3566-PC, the name of this Entity is m00_b_gxcam 4-003b).
- It is a V4L2 subdev (Sub-Device) sensor.
- The corresponding node is /dev/v4l-subdev2. The application (such as v4l2-ctl) can open it and make configurations.
- Its output format is [UYVY8_2X8/1920x1080@10000/600000 field:none], where UYVY8_2X8 is a shortened form of an mbus-code. The supported mbus-codes will be listed in the next section.
- The current resolution is 1920x1080.
- The current frame interval is 10000/600000, which means the frame rate is 60.
The GX series cameras utilize the UYVY data format capability. For details, please refer to the data manuals of each model of the cameras.
| UYVY | UYVY8_2X8 | UYVY |
"m00_b_gxcam 7-003b"specifies the full entity name of the camera.UYVY8_2X8is the mbus-code."$WIDTH"x"$HEIGHT"indicates the resolution.1/"$FPS"specifies the frame rate.
For example, for the GX-MIPI-IMX662, after substituting the variables, the command becomes:
media-ctl -d /dev/media0 --set-v4l2 '"m00_b_gxcam 7-003b":0[fmt:UYVY8_2X8/1920x1080@1/60 field:none]'
This command allows you to configure the data format, resolution, and frame rate in a single step. Individual parameters can also be modified separately if needed.
Note: The node names in media-ctl can be adjusted according to the information in the JSON file generated by the probe script to configure different cameras.
4 veye_viewer
5 yavta
5.1 Installing Yavta
$ cd yavta;make
5.2 Saving Images to a File
./yavta -c1 -Fuyvy-${WIDTH}x${HEIGHT}.yuv --skip 0 -f UYVY -s ${WIDTH}x${HEIGHT} /dev/video0
-c1specifies capturing 1 frame.-Fsets the output filename.--skip 0disables frame skipping.-f UYVYspecifies the pixel format.-s ${WIDTH}x${HEIGHT}sets the capture resolution.
/dev/video0is the video device node.
Install OpenCV for Python:
$ python3 ./v4l2_opencv_show2.py --width 1920 --height 1080 --fps 60 --i2c 7
7 GStreamer Examples
8 v4l2-ctl Examples
8.1 install v4l2-utils
8.2 Configure parameters using v4l2-ctl
All the above functions can be implemented using gx_mipi_i2c.sh.
8.2.1 Trigger Mode
4:Multi-camera synchronization mode.
8.2.2 Trigger Source
8.2.3 Software trigger command
8.2.4 Set frame rate
8.3 Video Streaming mode
8.3.1 Set data format, resolution, frame rate
8.3.2 Frame rate statistics
Or:
./yavta -c1000 --skip 0 -f UYVY -s ${WIDTH}x${HEIGHT} /dev/video0
8.3.3 Save image to file
- UYVY
8.4 Trigger mode
8.4.1 Set data format, resolution, frame rate
8.4.2 Software trigger mode
8.4.2.1 Set mode
8.4.2.2 Start acquisition
8.4.2.3 Perform soft trigger operation
8.4.3 Hardware trigger mode
8.4.3.1 Set mode
The gx_mipi_i2c.sh script can be used to set rich trigger parameters.
8.4.3.2 Start acquisition
8.4.3.3 Perform hardware trigger operation
8.5 Synchronous Mode
The following nodes and sub-devices should be selected according to the actual hardware configuration.
8.5.1 Set data format, resolution, frame rate
8.5.2 Set synchronous mode
v4l2-ctl -d /dev/v4l-subdev2 --set-ctrl trigger_mode=4
8.5.3 Set the camera as the master or slave.
master camera:
slave camera:
8.5.4 Start taking pictures
10 Recommendations for Customer Integration and Development
10.1 Initialization Phase
Do not use gx_mipi_i2c.sh to directly modify camera registers, as direct register changes will not be synchronized with the Rockchip Linux driver layers.
10.2 Operation Phase
Depending on the programming language used, customers can refer to the tools and examples provided earlier in this document.
10.3 Parameter Configuration
GX series cameras offer rich and flexible parameter options, which are mainly configured via the gx_mipi_i2c.sh script. For detailed instructions, refer to the register documentation and the gx_mipi_i2c.sh manual.
The gx_mipi_i2c.sh script includes a paramsave function that saves all configured parameters to the camera’s flash memory. However, frequent invocation of this function in programs is not recommended.
11 References
- ROC-RK3566-PC Manual
- ROC-RK3588S-PC Manual
- ROC-RK3576-PC Manual
- Firefly Linux User Guide
12 Document History
2025-12-20
- Adjusted document structure and added several new sections.
2025-11-28
