MV-MIPI-GMAX4002M Data Sheet
MV-MIPI-GMAX4002M is a 2.45M Pixel MONO industrial camera with MIPI interface.
MV-MIPI-GMAX4002M
  • 1/1.7'' 2.45M Pixel Gpixel GMAX4002 Global Shutter CMOS SENSOR
  • MIPI CSI-2 Interface
  • Mono-8、Mono-10,Mono-12 Data Format
  • Support 2x2 Binning mode
  • Video streaming mode(Free Running), Normal Trigger Mode, Pulse Trigger Mode
  • Strobe synchronization
  • ROI
  • USER Output
MV-MIPI-GMAX4002M
3 Technical Detail
Technical Details
Sensor Type CMOS
Shutter Mode Global Shutter
Sensor Gpixel GMAX4002-AVM
Color MONO
Image Size 1/1.7''
Unit Cell Size 4μm × 4μm
Resolution 2048(H)× 1200(V)
Max Frame Rate Normal mode:
4lane@8bit mode:2048 x 1200 @213fps
2x2 Binning mode:
4lane@8bit mode:1024 x 600 @412fps
4lane@10bit mode:1024 x 600 @351fps
4lane@12bit mode:1024 x 600 @299fps
2lane@8bit mode:1024 x 600 @218fps
2lane@10bit mode:1024 x 600 @187fps
2lane@12bit mode:1024 x 600 @158fps
Gain Analog Gain:0 dB to 11.6 dB Digital Gain: 6 dB to 23.8 dB
Shutter Mode AE,ME,AE Once
ISP 8bit GAMMA,User Lookup Table
ADC Resolution 10/12 bit
Pixel Format Mono8,Mono10,Mono-12
ROI Support
Mirror Image Mirror and Flip
Working Mode Video streaming mode(Free Running), Normal Trigger Mode, Pulse Trigger Mode
Trigger Source Hardware,Software
Electrical characteristics
Data Interface CSI-2 : 2/4 Data Lanes
Data Rate / lane:1.5Gbps
Power Supply 5VDC
Power Consumption TODO
Structure
Lens Mount C-MOUNT03S-MOUNT01
Operating Conditions
Humidity Humidity 95% or less
Sensor Spectral Sensitivity
GMAX4002-AVM
5 Interface & Pin list
MV-MIPI-GMAX4002M
MV-MIPI-GMAX4002M
Pin NO. NAME Remarks
2 VCC 5V
3 VCC 5V
4 VCC 5V
5 VCC 5V
6 GND
8 GND
9 MIPI_L0_N Lane 0 Negative
10 MIPI_L0_P Lane 0 Positive
11 GND
12 MIPI_L1_N Lane 1 Negative
13 MIPI_L1_P Lane 1 Positive
14 GND
15 MIPI_CK_N CLK Negative
16 MIPI_CK_P CLK Positive
17 GND
18 MIPI_L2_N Lane 2 Negative
19 MIPI_L2_P Lane 2 Positive
20 GND
21 MIPI_L3_N Lane 2 Negative
22 MIPI_L3_P Lane 2 Positive
23 GND
24 SCL I2C SCL, 3.3V Level
25 SDA I2C SDA, 3.3V Level
26 GPIO3 Reserved
27 OUT_2 Multi-function Port 2,3.3V level
28 OUT_1 Multi-function Port 1,3.3V level
29 TriggerIN Hardware Trigger in,3.3V level
30 GND
6 Board Dimension
7 PCBA 2D DXF File
Download 2D DXF file
8 PCBA 3D STP File
Download 3D STP file
