MV Camera Application Development Guide on Rochchip
This document applies to scenarios where the camera hardware is correctly connected, the driver is properly installed, and the MV/RAW series camera has been successfully recognized.
- Query the device information of the connected MV/RAW series camera
2.1 probe_camera_info-rk.sh
Example usage:
$ ./probe_camera_info-rk.sh
cat auto_camera_index.json
"media_node": "/dev/media0",
"video_node": "/dev/video0",
"i2c_bus": "7"
| media_entity_name | Media entity name | Describes the device, e.g., "m00_b_mvcam 7-003b"
| i2c_bus | I²C bus | Indicates the I²C bus to which the device is connected | Used as the underlying communication channel for camera parameter configuration, e.g., by the mv_mipi_i2c.sh script
2.2 mv_probe.sh
The mv_probe.sh script can configure environment variables with key information for a specific camera, including the I²C bus number, camera model, resolution (width and height), and frame rate. This simplifies subsequent use of media-ctl for format configuration.
The usage method is:
$ source ./mv_probe.sh <i2c_bus>
Example:
$ source ./mv_probe.sh 7
Found veye_mvcam camera on i2c-7.
Setenv I2C_BUS = 7
Setenv CAMERAMODEL = MV-MIPI-AR0234M
Setenv HEIGHT = 1200
echo $CAMERAMODEL
Important Notes:
- This script requires the
Example:
export WIDTH=1920
export HEIGHT=1200
export FPS=30
By using the media-ctl command, the current topology structure can be clearly displayed.
media-ctl -p -d /dev/media0
3.1.1 Link relationship
3.1.2 mv camera entity information
Take MV-MIPI-IMX296M as an example:
pad0: Source
[fmt:Y8_1X8/1920x1200@100/6000 field:none
crop.bounds:(0,0)/1920x1200
crop:(0,0)/1920x1200]
It can be seen that:
- The complete name of this Entity is:
m00_b_mvcam 7-003b. - It is a V4L2 subdev (Sub-Device) sensor.
- The corresponding node is /dev/v4l-subdev2. The application (such as
v4l2-ctl) can open it and make configurations. - Its output format is [
fmt:Y8_1X8/1920x1200@100/6000 field:none], whereY8_1X8is a shortened form of an mbus-code. The supported mbus-codes will be listed in the next section. - The current resolution is
1920x1200. - The current frame interval is
100/6000, which means the frame rate is 60.
The MV/RAW series cameras utilize the data format capability. For details, please refer to the data manuals of each model of the cameras.
| RAW8 | Y8_1X8 | GREY |
| RAW10 | Y10_1X10 | 'Y10 ' |
| RAW12 | Y12_1X12 | 'Y12 ' |
| UYVY | UYVY8_2X8 | UYVY |
"m00_b_mvcam 7-003b"specifies the full entity name of the camera.Y8_1X8is the mbus-code."$WIDTH"x"$HEIGHT"indicates the resolution.1/"$FPS"specifies the frame rate.
For example, for MV-MIPI-AR0234M, the command after variable replacement would be:
media-ctl -d /dev/media0 --set-v4l2 '"m00_b_mvcam 7-003b":0[fmt:Y8_1X8/1920x1200@1/60 field:none]'
4 Raw data format
4.1 Noncompact RAW
4.2 Compact RAW
4.3 Line stride
8bit depth,line_stride=1536
4.4 Format convert tool
4.5 Raw data image player
5 veye_viewer
6 yavta
6.1 Installing Yavta
$ cd yavta;make
6.2 Saving Images to a File
7 Importing Camera Data into OpenCV
Install OpenCV for Python:
$ python3 ./v4l2dev_2_opencv_show_grey.py --width 1456 --height 1088 --fps 60 --i2c 6
8 GStreamer Examples
Several GStreamer example pipelines are provided to implement camera preview functionality.
9 v4l2-ctl Examples
9.1 install v4l2-utils
9.2.1 Trigger Mode
2:Fast continuous triggering mode.
9.2.2 Trigger Source
9.2.3 Software trigger command
9.2.4 Set frame rate
9.2.5 Set the starting position of the ROI
9.3 Video Streaming mode
9.3.1 Set data format, resolution, frame rate
9.3.2 Frame rate statistics
Or:
9.3.3 Save image to file
- raw8
- raw10
- raw12
9.4 Trigger mode
9.4.1 Set data format, resolution, frame rate
9.4.2 Software trigger mode
9.4.2.1 Set mode
9.4.2.2 Start acquisition
9.4.3 Hardware trigger mode
9.4.3.1 Set mode
9.4.3.2 Start acquisition
9.4.3.3 Perform hardware trigger operation
11 Recommendations for Customer Integration and Development
11.1 Initialization Phase
Do not use mv_mipi_i2c.sh to directly modify camera registers, as direct register changes will not be synchronized with the Rockchip Linux driver layers.
11.2 Operation Phase
Depending on the programming language used, customers can refer to the tools and examples provided earlier in this document.
11.3 Parameter Configuration
MV/RAW series cameras offer rich and flexible parameter options, which are mainly configured via the mv_mipi_i2c.sh script. For detailed instructions, refer to the register documentation and the mv_mipi_i2c.sh manual.
The mv_mipi_i2c.sh script includes a paramsave function that saves all configured parameters to the camera’s flash memory. However, frequent invocation of this function in programs is not recommended.
12 Document History
- 2025-12-25
