RAW-MIPI-SC535M Version Log
1 How to get version
RAW-MIPI-SC535M has one version number, Using shell script ,get version.
C version is the camera version.
2 Upgrade package download
CS Serials Camera Upgrade Images(Mediafire)
3 Version Log
- RAW-MIPI-SC535M_C1.22_20250725_upgrade.bin
- Fix bug: In ROI mode, the X-direction zero coordinate starts from the right side. Changed to start from the left side.
- RAW-MIPI-SC535M_C1.20_20250628_upgrade.bin
- Fix bug: Issue with incorrect trigger edge configuration.
- Modified the paramsave logic to only erase/write flash when the parameters have been modified. This helps minimize flash erase/write operations.
- RAW-MIPI-SC535M_C1.19_20250528_upgrade.bin
- Adjust the parameter details in raw8 mode to ensure the correctness of maximum resolution output.
- RAW-MIPI-SC535M_C1.15_20250107_upgrade.bin
- Support for enhanced external trigger mode similar to the MV series products, supporting settings for trigger delay, trigger frame count, and trigger interval, as well as a prompt for the minimum trigger cycle.
- RAW-MIPI-SC535M_C1.10_20241117_upgrade.bin
- Adjust Max fps to 84 for 4lane@raw8.
- RAW-MIPI-SC535M_C1.09_20240828_upgrade.bin
- Add support for Continuous Trigger Mode.
- RAW-MIPI-SC535M_C1.08_20240515_upgrade.bin
- First release version.
