ADP-MV1 Adapter Board Data Sheet/zh
Adapter Board:ADP-MV1 DATA SHEET
转接板:ADP-MV1数据手册
1 Introduction 产品介绍
The ADP-MV1 board function is connector interface conversion, user IO, power IO,IIC etc,signal lead out.
The ADP-MV1 converts FPC 30pin interface of MV-MIPI-XXX camera to 15pin interface,Compatible with raspberry Pi or Nvidia CSI-2 interface.
The ADP-MV1 converts the power IO, trigger input and user IO pins in the FPC30 interface of the MV-MIPI-XXX series cameras into 2.54 pins and MX1.25 connectors for easy testing and integration.
ADP-MV1板的功能是将连接器接插件方式转换,用户IO、电源IO、IIC等信号引出。
ADP-MV1板将 MV-MIPI-XXX系列工业相机的FPC30接口转换为FPC15接口,兼容树莓派或者英伟达的CSI-2接口。
ADP-MV1板将 MV-MIPI-XXX系列工业相机的FPC30接口中的电源,触发输入,用户输出等引脚,转换为2.54插针和MX1.25连接器,易于测试、集成。
2 Product Picture 产品图片
PART NUMBER / 型号 | FRONT VIEW / 正面图片 | BACK VIEW / 背面图片 | Product Picture / 产品图片 | Camera Support / 适配摄像机模组 |
ADP-MV1 | ![]() ADP-MV1 & MV-MIPI-IMX178M |
MV-MIPI-IMX178M |
3 Board Pinlist 引脚说明
J1: CSI-2 Interface,Compatible with raspberry Pi or Nvidia CSI-2 interface
J1:CSI-2接口,兼容树莓派或者英伟达CSI-2接口 | ||
Pin NO. 引脚号 | NAME 名称 | Remarks 说明 |
1 | GND | |
2 | MIPI_L0_N | |
3 | MIPI_L0_P | |
4 | GND | |
5 | MIPI_L1_N | |
6 | MIPI_L1_P | |
7 | GND | |
8 | MIPI_CK_N | |
9 | MIPI_CK_P | |
10 | GND | |
11 | ENABLE | Camera Power Enable |
12 | NC | |
13 | SCL | 3.3V Level |
14 | SDA | 3.3V Level |
15 | NC | NC |
J2:Connect to MV-MIPI-XXX Industry Camera J3
J2: 连接MV-MIPI-XXX系列工业相机 J3 | ||
1 | GND | |
2 | VCC | 5V |
3 | VCC | 5V |
4 | VCC | 5V |
5 | VCC | 5V |
6 | GND | |
7 | ENABLE | Camera Power Enable |
8 | GND | |
9 | MIPI_L0_N | Lane 0 Negative |
10 | MIPI_L0_P | Lane 0 Positive |
11 | GND | |
12 | MIPI_L1_N | Lane 1 Negative |
13 | MIPI_L1_P | Lane 1 Positive |
14 | GND | |
15 | MIPI_CK_N | CLK Negative |
16 | MIPI_CK_P | CLK Positive |
17 | GND | |
18 | MIPI_L2_N | Reserved 预留 |
19 | MIPI_L2_P | Reserved 预留 |
20 | GND | |
21 | MIPI_L3_N | Reserved 预留 |
22 | MIPI_L3_P | Reserved 预留 |
23 | GND | |
24 | SCL_MV | I2C SCL, 3.3V Level |
25 | SDA_MV | I2C SDA, 3.3V Level |
26 | GPIO3 | Reserved 预留 |
27 | USER IO2 | Multi-function Port 2,3.3V level;可配置输出2,3.3V电平标准 |
28 | USER IO1 | Multi-function Port 1,3.3V level;可配置输出1,3.3V电平标准 |
29 | TRIGGER_I | Hardware Trigger in,3.3V level;硬件触发输入,3.3V电平标准 |
30 | GND |
J3:Auxiliary Expansion Port 1
J3:辅助扩展口1 | |||||
Pin NO. 引脚号 | NAME 名称 | Remarks 说明 | Pin NO. 引脚号 | NAME 名称 | Remarks 说明 |
1 | VCC | 板内连接到 J2-2 | 2 | GND | |
3 | TRIGGER_I | 板内连接到 J2-29 | 4 | GND | |
5 | USER IO1 | 板内连接到 J2-28 | 6 | GND | |
7 | USER IO2 | 板内连接到 J2-27 | 8 | GND | |
9 | GPIO3 | 板内连接到 J2-26 | 10 | GND | |
11 | SDA_MV | 板内连接到 J2-25 | 12 | SCL_MV | 板内连接到 J2-24 |
13 | SDA_USER | 板内连接到 J1-14 | 14 | SCL_USER | 板内连接到 J1-13 |
注:
使用 J1-I2C :短接11-13,同时短接12-14。 使用 其它 I2C :断开11-13,断开12-14;SDA信号连接J3-11,SCL信号连接J3-12。 | |||||
Links 相关链接:
mv_mipi_i2c.sh user guide:IO Control en |
J4:Auxiliary Expansion Port 2
J4:辅助扩展口2 | ||
2 | GND | |
4 | USER IO1 | 板内连接到 J2-28 |
5 | USER IO2 | 板内连接到 J2-27 |
6 | GPIO3 | 板内连接到 J2-26 |
7 | GND | |
8 | SDA_MV | 板内连接到 J2-25 |
9 | SCL_MV | 板内连接到 J2-24 |
10 | GND | |
Links 相关链接:
