ADP-MV2-V10 Adapter Board Data Sheet/zh
Adapter Board:ADP-MV2 DATA SHEET
转接板:ADP-MV2数据手册
1 Introduction 产品介绍
ADP-MV2是一款转接板,可将MV系列和RAW系列FFC接口转换为Firefly开源团队 ROC-RK35xx-PC 30Pin Camera接口。
ADP-MV2 is an adapter board that can convert the FFC interfaces of MV series and RAW series cameras to the Firefly open source team ROC-RK35xx-PC 30-pin camera interface.
2 Product Picture 产品图片
PART NUMBER / 型号 FRONT VIEW / 正面图片 BACK VIEW / 背面图片 Camera Support / 适配摄像机模组
ADP-MV2
ADP-MV2
ADP-MV2
MV-MIPI-IMX178M
MV-MIPI-SC130M
MV-MIPI-IMX287M
MV-MIPI-IMX296M
MV-MIPI-IMX265M
MV-MIPI-IMX264M
RAW-MIPI-SC132M
ADP-MV1-T J1/J3/J4 PINLIST
ADP-MV2 J1/J3/J4 PINLIST
ADP-MV2 J2/J5 PINLIST
3 Board Pinlist 引脚说明
J1:Down contact,30Pin 20cm FFC,connect with Firefly 30Pin FPC connector
J1:下接触,标配30Pin 20cm同面FFC,与Firefly 30Pin 接口FPC座互联
Pin NO. 引脚号 NAME 名称 Remarks 说明
1 SDA 1.8V
2 SCL 1.8V
3 PDN_CAM 1.8V
4 NC
5 GND
6 NC
7 NC
8 NC
9 NC
11 MIPI_L0_P
12 MIPI_L0_N
13 GND
14 MIPI_L1_P
15 MIPI_L1_N
16 GND
17 MIPI_CK_P
18 MIPI_CK_N
19 GND
20 NC
21 NC
22 GND
23 NC
24 NC
25 GND
26 NC
27 NC
28 GND
29 VCC5V POWER IN, DC5V
30 VCC5V POWER IN, DC5V
J3:Auxiliary Expansion Port 1
J3:辅助扩展口1
Pin NO. 引脚号 NAME 名称 Remarks 说明 Pin NO. 引脚号 NAME 名称 Remarks 说明
1 VCC5V 板内连接到 J2-2 2 GND
3 TRIGGER_I 板内连接到 J2-29 4 GND
5 USER IO1 板内连接到 J2-28 6 GND
7 USER IO2 板内连接到 J2-27 8 GND
9 GPIO3 板内连接到 J2-26 10 GND
Links 相关链接:
mv_mipi_i2c.sh user guide:IO Control en
MV Series MIPI Camera Register Map:IO Control en 中文
J4:Auxiliary Expansion Port 2
J4:辅助扩展口2
1 VCC5V 板内连接到 J2-2
4 USER IO1 板内连接到 J2-28
5 USER IO2 板内连接到 J2-27
6 GPIO3 板内连接到 J2-26
8 NC
9 NC
Links 相关链接:
J2:Up Contact, Connect to MV-MIPI-XXX Industry Camera J3
J2: 上接触,连接MV-MIPI-XXX系列工业相机 J3
2 VCC 5V
3 VCC 5V
4 VCC 5V
5 VCC 5V
6 GND
7 ENABLE Camera Power Enable
8 GND
9 MIPI_L0_N Lane 0 Negative
10 MIPI_L0_P Lane 0 Positive
11 GND
12 MIPI_L1_N Lane 1 Negative
13 MIPI_L1_P Lane 1 Positive
14 GND
15 MIPI_CK_N CLK Negative
16 MIPI_CK_P CLK Positive
17 GND
18 MIPI_L2_N Reserved 预留
19 MIPI_L2_P Reserved 预留
20 GND
21 MIPI_L3_N Reserved 预留
22 MIPI_L3_P Reserved 预留
23 GND
24 SCL_MV I2C SCL, 3.3V Level
25 SDA_MV I2C SDA, 3.3V Level
26 GPIO3 Reserved 预留
27 USER IO2 Multi-function Port 2,3.3V level;可配置输出2,3.3V电平标准
28 USER IO1 Multi-function Port 1,3.3V level;可配置输出1,3.3V电平标准
29 TRIGGER_I Hardware Trigger in,3.3V level;硬件触发输入,3.3V电平标准
30 GND
J5: Up Contact, Connect to RAW-MIPI-XXX Industry Camera J3
J5: 上接触,连接RAW-MIPI-XXX系列相机 J1
1 VCC3V3
2 SDA 3.3V Level
3 SCL 3.3V Level
4 NC
5 ENABLE 3.3V Level
6 GND
7 MIPI_CK_P
8 MIPI_CK_N
9 GND
10 MIPI_L1_P
11 MIPI_L1_N
12 GND
13 MIPI_L0_P
14 MIPI_L0_N
15 GND
4 Schematic 原理图
Download schematic file
5 Board Dimension 尺寸图
Download 2D DXF file
6 PCBA 3D STP File(3D STP文件)
Download 3D STP file
