CS-FPD-CAM for Raspberry Pi
On the Raspberry PI platform, a set of FPD-LINK3-TX and FPD-LINK3-2RX boards are used to realize the remote transmission of 1-channel video. The I2C address of the camera after initialization configuration is the same as that of the original camera.
For application layer, a completely transparent FPD-Link channel is implemented, including image, i2C communication, synchronous IO and trigger IO.
Therefore, when using CS-FPD-CAM, you must refer to the following articles:
RaspberryPi4 connect with CS-FPD-CAM
RaspberryPi CM3 connect with 2 FPD-LINK-CAMs
PS:FPD-LINK3-2RX need a 12V DC power.
Completely consistent with : RaspberryPi System Setup and Configuration.
4 Sofware Toolkits Install
Completely consistent with : Sofware Toolkits Install.
In addition, we provide a FPD-Link III script for configuring the FPD-Link board.
On Raspberry PI, you need to configure I2C pins, please refer to: raspberry pie pin configuration part2, and then do the following.
5.1 fpdlink3_i2c.sh Usage
$ ./fpdlink3_i2c.sh
Usage:  ./fpdlink3_i2c.sh [-f] function name -b bus -p port -p1 param1 -p2 param2 -p3 param3
fpdlink port:FPD-LINK3-2RX board,J3 is fpllink port 0, J4 is fpdlink port 1.
5.2 fpdlink3_i2c.sh usage details
5.2.1 rpi_init
init the FPD-Link channel of port0/1,must run this command before you can connect video and i2C.
5.2.2 sync_init
Configure port 0 as the master of sync mode.
Connect J1 signal of FPD-LINK3-TX on port 0 to J6 of FPD-LINK3-2RX,direction is TX-->RX.
Configure port 1 as the slave of sync mode.
Connect J8 signal of FPD-LINK3-2RX to J1 of FPD-LINK3-TX on port 1 ,direction is RX-->TX.
5.2.3 trigger_init
Configure port 0 as the trigger mode.
Connect J6 signal of FPD-LINK3-2RX to J1 of FPD-LINK3-TX on port 0 ,direction is RX-->TX.
Configure port 1 as the trigger mode.
6 Typical application
6.1 CS-FPD-CAM Video usage
6.1.1 Step 1:
On Raspberry PI:
Init the FPD-Link channel of port0.
6.1.2 Step 2:
After Step 1, the stream acquisition and I2C instruction control of the camera are exactly the same as those of the camera with the MIPI interface.
6.2 CS-FPD-CAM-IMX307 sync mode
CS-FPD-CAM-IMX307 sync mode's sync singal connection
6.2.1 Step 1:
On the motherboard of the two cameras, execute:
6.2.2 Step 2:
After Step 1, the I2C to control camera is ready.
  • Configure cam0 as the master
./fpdlink3_i2c.sh -f sync_init -p 0 -p1 0 -b [i2c_bus_num]
./cs_mipi_i2c.sh -w -f streammode -p1 1 -p2 0 -b [i2c_bus_num]
  • Configure cam1 as the slave
./fpdlink3_i2c.sh -f sync_init -p 0 -p1 1 -b [i2c_bus_num]
./cs_mipi_i2c.sh -w -f streammode -p1 1 -p2 1 -b [i2c_bus_num]
6.2.3 Step 3:
The stream acquisition and I2C instruction control of the camera are exactly the same as those of the camera with the MIPI interface now.
6.3 CS-FPD-CAM-SC132 Trigger mode
CS-FPD-CAM-SC132 trigger mode's trigger signal
6.3.1 Step 1:
On Raspberry PI:
6.3.2 Step 2:
6.3.3 Step 3:
