CS-MIPI-IMX307 for Jetson Nano
How to use CS-MIPI-X camera module on NVIDIA Jetson Nano
This guide shows how to connect CS-MIPI-X to Jetson Nano.Jetson SDK Version is:
  • Jetpack4.2.2,L4T r32.2.1
  • Jetpack4.3,L4Tr32.3.1
  • Jetpack4.4,L4T,r32.4.3
CS-MIPI-IMX307 is STARVIS camera module with ISP functions build in. It output UYVY data using MIPI-CSI2,1080p@30fps mode, 720p_crop@60fps mode and VGA@130fps.
CS-MIPI-SC132 is global shutter camera module with ISP functions build in. It output UYVY data using MIPI-CSI2,support mulity video format and trigger mode.
We provide V4L2 interface for video streaming apps , and Video Control Toolkits (which is Shell Script) to control the camera module directly.
The new version of Jetson Nano (B01) is supported.
Jetson Nano's CSI2 interface is compatible with CS-MIPI-X. It support 5V power or 3.3V power mode. power switching.
  • The default power supply mode of CS-MIPI-SC132 is 3.3V via FFC cable, and there is no need to plug in red and black power cable.
Connect CS-MIPI-IMX307 to Jetson Nano
Jetson Nano power wire
CS-MIPI-IMX307 wire
CS-MIPI-307 dual cameras connect to Jetson Nano B01
3 Upgrade Jetson Nano system
3.1 Overview
In particular, for Jetson nano, we provide a burning image of the TF card.
4 Burning the prebuilt Image to upgrade Jetson nano system
You can use the image prebuild by us to upgrade jetson nano system, which will support our camera.
Using whole prebuilt image
  • download :
  • How to burn
refer to Official document
5 Using source code to upgrade Jetson nano system
5.1 Reference documents
Development Docs:https://docs.nvidia.com/jetson/archives/
5.2 Setting Up the Environment
  • Host PC which runs Ubuntu 18.04/16.04(64-bit).
  • A kernel image , device tree blob (DTB) file and module drivers for the CS-MIPI-IMX307 camera. The release package contains a kernel binary (Image),DTB files and module drivers, which you can download and rebuild from source.
  • development kit.
5.3 Host PC environment prepare
  • Cross-compiling Toolchain
  • L4T source code and Rootfs
  • Setting Up the Environment
-Jetpack4.2.2
-Jetpack4.3
-Jetpack4.4
export TOP_DIR=<absolute path to top dir;in my case is /home/xumm/nvidia/nvidia_sdk//JetPack_4.4_Linux_JETSON_NANO_DEVKIT/>
- Common Part
export LOCALVERSION=-tegra
export NANO_DTS_PATH=$L4T_DIR/sources/hardware/nvidia/platform/t210/porg/kernel-dts
  • Build default image, prepare L4T environment
  • Download source code for Jetson Nano
5.4 Using prebuild Image and DTB
5.4.1 Installing the Kernel and DTS
- Jetpack4.2.2
sudo cp $RELEASE_PACK_DIR/Nano/JetPack_4.2.2_Linux_GA_P3448/dts\ dtb/CS-MIPI-IMX307/tegra210-p3448-0000-p3449-0000-a02.dtb $L4T_DIR/kernel/dtb/ -f
sudo cp $RELEASE_PACK_DIR/Nano/JetPack_4.2.2_Linux_GA_P3448/dts\ dtb/CS-MIPI-IMX307/tegra210-p3448-0000-p3449-0000-b00.dtb $L4T_DIR/kernel/dtb/ -f
- Jetpack4.3
tar -xzvf Image_l4t_r32.3.1_veyecam.tar.gz
  • CS-MIPI-IMX307
sudo cp $RELEASE_PACK_DIR/Nano/JetPack_4.3_Linux_P3448/dts\ dtb/CS-MIPI-IMX307/tegra210-p3448-0000-p3449-0000-a02.dtb $L4T_DIR/kernel/dtb/ -f
sudo cp $RELEASE_PACK_DIR/Nano/JetPack_4.3_Linux_P3448/dts\ dtb/CS-MIPI-IMX307/tegra210-p3448-0000-p3449-0000-b00.dtb $L4T_DIR/kernel/dtb/ -f
  • CS-MIPI-SC132
sudo cp $RELEASE_PACK_DIR/Nano/JetPack_4.3_Linux_P3448/dts\ dtb/CS-MIPI-SC132/tegra210-p3448-0000-p3449-0000-a02.dtb $L4T_DIR/kernel/dtb/ -f
sudo cp $RELEASE_PACK_DIR/Nano/JetPack_4.3_Linux_P3448/dts\ dtb/CS-MIPI-SC132/tegra210-p3448-0000-p3449-0000-b00.dtb $L4T_DIR/kernel/dtb/ -f
- Jetpack4.4
tar -xzvf Image_l4t_r32.4.3_veyecam.tar.gz
  • For CS-MIPI-IMX307
sudo cp $RELEASE_PACK_DIR/Nano/JetPack_4.4_Linux_JETSON_NANO_DEVKIT/dts\ dtb/CS-MIPI-IMX307/tegra210-p3448-0000-p3449-0000-a02.dtb $L4T_DIR/kernel/dtb/ -f
sudo cp $RELEASE_PACK_DIR/Nano/JetPack_4.4_Linux_JETSON_NANO_DEVKIT/dts\ dtb/CS-MIPI-IMX307/tegra210-p3448-0000-p3449-0000-b00.dtb $L4T_DIR/kernel/dtb/ -f
  • For CS-MIPI-SC132
sudo cp $RELEASE_PACK_DIR/Nano/JetPack_4.4_Linux_JETSON_NANO_DEVKIT/dts\ dtb/CS-MIPI-SC132/tegra210-p3448-0000-p3449-0000-a02.dtb $L4T_DIR/kernel/dtb/ -f
sudo cp $RELEASE_PACK_DIR/Nano/JetPack_4.4_Linux_JETSON_NANO_DEVKIT/dts\ dtb/CS-MIPI-SC132/tegra210-p3448-0000-p3449-0000-b00.dtb $L4T_DIR/kernel/dtb/ -f
5.5 Flashing the Jetson Nano Development Kit
    a. Power OFF the board.
    b. Connect the jumper pin to the pin 3 and pin 4 of the J40 button header.
lsusb
your host PC.
5.6 Building from Source
5.6.1 Build kernel
  • patch code
- r32.2.1
- r32.3.1
- r32.4.3
  • build
Install Image for Flashing:
5.6.2 Build DTS
  • patch code
- Jetpack4.2.2
- Jetpack4.3
  • CS-MIPI-IMX307
cp $RELEASE_PACK_DIR/Nano/JetPack_4.3_Linux_P3448/dts\ dtb/CS-MIPI-IMX307/tegra210-porg-plugin-manager.dtsi -r $NANO_DTS_PATH/porg/kernel-dts/porg-plugin-manager
  • CS-MIPI-SC132
cp $RELEASE_PACK_DIR/Nano/JetPack_4.3_Linux_P3448/dts\ dtb/CS-MIPI-SC132/tegra210-porg-plugin-manager.dtsi -r $NANO_DTS_PATH/porg/kernel-dts/porg-plugin-manager
- Jetpack4.4
cp $RELEASE_PACK_DIR/Nano/JetPack_4.4_Linux_JETSON_NANO_DEVKIT/dts\ dtb/common/t210/* -r $NANO_DTS_PATH/
  • CS-MIPI-IMX307
cp $RELEASE_PACK_DIR/Nano/JetPack_4.4_Linux_JETSON_NANO_DEVKIT/dts\ dtb/CS-MIPI-IMX307/tegra210-porg-plugin-manager.dtsi -r $NANO_DTS_PATH/porg/kernel-dts/porg-plugin-manager
  • CS-MIPI-SC132
cp $RELEASE_PACK_DIR/Nano/JetPack_4.4_Linux_JETSON_NANO_DEVKIT/dts\ dtb/CS-MIPI-SC132/tegra210-porg-plugin-manager.dtsi -r $NANO_DTS_PATH/porg/kernel-dts/porg-plugin-manager
  • build
5.7 Upgrading Kernel Image and Supplements
5.8 Upgrading DTB File by Flashing from Host PC
Burning process reference 4.3, burning commands is as below:
Power off after flashing finished.
6 Applications and Test
6.1 Check system status
The steps to verify the setup before testing Gstreamer pipelines are as follows:
1. Run the following commands to check the Gstreamer-1.0 version.
$ gst-inspect-1.0 --version
gst-inspect-1.0 version 1.14.4
GStreamer 1.14.4
Note: Make sure that CS-MIPI-X is connected and the required driversare loaded.
During booting, the module drivers for CS-MIPI-X will be loaded automatically in the Jetson Nano™ development kit.
2. Run the following command to confirm whether the camera is initialized.
dmesg | grep csx307
subdev csimx307 X-003b bound
  • For CS-MIPI-SC132
subdev cssc132 X-003b bound
video0(1)
6.2 Video Stream Toolkits Manual
6.2.1 Gstreamer Usage
  • Preview FHD(HW accelerated)
  • Preview 720p@60fps HD(HW accelerated)
  • Preview 1280*1080@45 (CS-MIPI-SC132,HW accelerated)
gst-launch-1.0 v4l2src ! "video/x-raw,format=(string)UYVY, width=(int)1280, height=(int)1080, framerate=(fraction)45/1" ! nvvidconv ! "video/x-raw(memory:NVMM),format=(string)I420" ! nvoverlaysink sync=false
  • Preview 640*480@130fps(HW accelerated)
  • Preview 2 cameras 1080p HD(HW accelerated)
  • Capturing FHD still image
  • Capturing 720p still image
gst-launch-1.0 v4l2src num-buffers=1 ! "video/x-raw,format=(string)UYVY, width=(int)1280, height=(int)720" ! jpegenc ! filesink location=jpgname.jpg
6.3 Video Control Toolkits Manual
Jetson Nano A02 use i2c-6 as camera control bus,Jetson Nano B01 use i2c-7 and i2c-8 as camera control bus.
Using -b option to identify which bus to use.
Video Control Toolkits Manual : CS-MIPI-X i2c
7 Others
This article and the source code are still in the process of improving. If you have any suggestions for improvement, you are welcome to email xumm#csoneplus.com.
