CS-MIPI-SC132 Data Sheet
CS-MIPI-SC132 / CS-MIPI-SC132-V2 is a cost-effective CSI-2 (MIPI) interface camera module that uses the SC132GS global shutter MONO CMOS sensor whice is SmartSens Technology‘s SmartGS™ series. CS-MIPI-SC132 / CS-MIPI-SC132-V2 supports trigger mode and video stream mode.
- 1/4 inch 1.3m pixel SmartGS® CMOS sensor
- Only mono mode is supported
- Global shutter
- Built-in ISP image processing
- CSI-2 data interface
- Uncompressed UYVY data format, YUV422-8bit data type
- Standard lens interface
- Brightness and contrast can be adjusted
- Support video stream mode
- Support trigger mode
- Firmware upgrade via USB flash drive
- Support Raspberry PI Platform, NVIDIA JETSON Platform
3 Technical Detail
| Technical Details
| SENSOR
| Sensor
SmartSens SmartGS® SC132GS
| Pixels
1.3M pixels
| Resolution
1080H*1280V
| Image Size
1/4"
| Unit Cell Size
2.7um *2.7um
| Output Format
RAW MONO
| Shutter Type
Global shutter
| ISP
| Frame Rate
1280*1080@max45fps,1280*720@max60fps, 640*480@max120fps
1080*1280@max45fps, 720*1280@max60fps, 480*640@max120fps
| Exposure
Auto or Manual
| Gain
Auto or Manual
| Shutter
( 0 - 1 / Frame Rate ) second
| Image Setting
Brightness, Contrast, Gamma, Flip, Mirror
| Image Synchronization mode
| Free-Run
The sensor runs under an autonomous clock system
| Soft Trigger
The image is triggered by the DRA(Direct Register Access)
| Hardware Trigger
The image is triggered by an external trigger signal,Support multi-camera synchronization
| Lens
| Lens
MTV12 / MTV16 / CS
| Lens Mount
M12*P0.5 / M16*P0.5 / CS
| Mounting Hole
2 screw holes with diameter of 2.2mm,20mm Center-to-Center Spacing
| Interface
| Connector
15PIN FPC, Compatible with Raspberry PI,JETSON NANO
| Communication Interface
IIC, 3.3VDC
| Video Data Interface
CSI-2 : 2 Data Lane,MIPI CSI-2 DC Specifications
| MIPI CLK frequence
297MHz
| MIPI Data bandwidth
594Mbps / lane * 2
| Data Type
YUV422-8bit
| General
| Operating Conditions
(Bare PCB)
| Power Supply
5VDC / 3.3VDC optional,3.3V default
| Power Consumption
CS-MIPI-SC132:Rate Power 1.16W
/ CS-MIPI-SC132-V2:Rate Power 1.23W,Transient Power 1.32W
| Dimension
38mm*38mm*12mm(not include lens and lens mount)
4 Optical Quantum Efficiency
| Sensor
Quantum Efficiency
| SC132GS
5 Interface & Pin list
CS-MIPI-SC132-BOTTOM LAYER
CS-MIPI-SC132-V2-TOP LAYER
CS-MIPI-SC132-V2-BOTTOM LAYER
| J1 : Firmware Update
| Pin NO.
NAME
Remarks
| 1
VBUS(5V)
Connect the USB upgrade cable & USB disk
| 2
D-
| 3
D+
| 4
GND
| J7 : GPIO
| Pin NO.
NAME
Remarks
| 1
Trigger In
Compatible with 2.5-3.3V level
| 2
GND
| 3
Strobe Out
2.5V level
| J14 : UART
| Pin NO.
NAME
Remarks
| 1
UART_TX
| 2
GND
| 3
UART_RX
| J8 : CSI-2 Interface
| Pin NO.
NAME
Remarks
| 1
GND
| 2
MIPI_L0_N
| 3
MIPI_L0_P
| 4
GND
| 5
MIPI_L1_N
| 6
MIPI_L1_P
| 7
GND
| 8
MIPI_CK_N
| 9
MIPI_CK_P
| 10
GND
| 11
NC
| 12
NC
| 13
SCL
3.3V Level
| 14
SDA
3.3V Level
| 15
VCC3V3
Use by default,How to use 5V power supply
6 Board Dimension
CS-MIPI-SC132 CAD FILE / unit:mm
CS-MIPI-SC132-V2 CAD FILE / unit:mm
Download CS-MIPI-SC132 dxf file here
Download CS-MIPI-SC132-V2 dxf file here
7 PCBA 3D STP File
Download CS-MIPI-SC132 3D STP file
Download CS-MIPI-SC132-V2 3D STP file
8 Assembly Direction
