FPD LINK III for Jetson
On Jetson Nano/NX platform, a set of FPD-LINK3-TX and FPD-LINK3-2RX boards are used to realize the remote transmission of 1-channel video. The I2C address of the camera after initialization configuration is the same as that of the original camera.On FPD-LINK3-2RX board, fpdlink channel is from port0(J3) to J9.
On Jetson TX2/AGX Xavier platform, a set of FPD-LINK3-TX and FPD-LINK3-2RX boards are used to realize the remote transmission of 2-channel video. On FPD-LINK3-2RX board, fpdlink channel is from port0(J3) and port1(J4) to J7. J7 is a MIPI interface of 4 lan, which supports two independent camera data transmission through virtual channel technology.
For application layer, it support all MIPI camera functions, including image, i2C communication, synchronous IO and trigger IO.
Therefore, when using CS-FPD-CAM, you must refer to the following article:
AGX XAVIER connnect with CS-FPD-CAMs
TX2 connect with CS-FPD-CAMs
PS:
  1. FPD-LINK3-2RX need a 12V DC power.
  2. FPD-LINK3-2RX needs power up no later than Xavier . Because Xavier detects peripherals during the startup phase.
  3. Be sure to screw the ADP adapter board to the bottom board.
The steps are basically the same as Upgrade Jetson Nano, Jetson TX2, AGX Xavier and Xavier NX. Note that dts, dtb, use the version with the fpdlink suffix. Driver source code and Image, are compatible with FPD-Link and MIPI interface cameras.
3.1 Are Image and DTB upgrade successful ?
3.1.1 For Image
ls /sys/bus/i2c/drivers/
There should have veyecam2m veye327 csx307 cssc132 i2c-ds90ub954 directory.
3.1.2 For DTB
- Nano A02
You should be able to find the camera model you used and ds90ub954.
4 I2C Address
fpdlink port:FPD-LINK3-2RX,J3 is port 0, J4 is port 1.
4.1 Nano A02
Camera Index I2C bus I2C Addr Location
Camera 0 6 0x3b FPD-LINK3-2RX port 0
4.2 Nano B01
Camera 0 7 0x3b FPD-LINK3-2RX port 0
Camera 1 8 0x3b FPD-LINK3-2RX port 0
Camera 0 9 0x3b FPD-LINK3-2RX port 0
Camera 1 10 0x3b FPD-LINK3-2RX port 0
4.4 AGX Xavier
Camera 0 30 0x3b ADP-N3 J1--FPD-LINK3-2RX port 0
Camera 1 30 0x3c ADP-N3 J1--FPD-LINK3-2RX port 1
Camera 2 31 0x3b ADP-N3 J2--FPD-LINK3-2RX port 0
Camera 3 31 0x3c ADP-N3 J2--FPD-LINK3-2RX port 1
Camera 4 32 0x3b ADP-N3 J3--FPD-LINK3-2RX port 0
Camera 5 32 0x3c ADP-N3 J3--FPD-LINK3-2RX port 1
Camera 6 33 0x3b ADP-N3 J4--FPD-LINK3-2RX port 0
Camera 7 33 0x3c ADP-N3 J4--FPD-LINK3-2RX port 1
4.5 TX2 Devkit
Camera 0 30 0x3b ADP-N2 J1--FPD-LINK3-2RX port 0
Camera 1 30 0x3c ADP-N2 J1--FPD-LINK3-2RX port 1
Camera 2 31 0x3b ADP-N2 J2--FPD-LINK3-2RX port 0
Camera 3 31 0x3c ADP-N2 J2--FPD-LINK3-2RX port 1
Camera 4 32 0x3b ADP-N2 J3--FPD-LINK3-2RX port 0
Camera 5 32 0x3c ADP-N2 J3--FPD-LINK3-2RX port 1
4.6 Applications and Test
The same as Applications and Test on Jetson of MIPI Camera.
$ ./fpdlink3_i2c_jetson.sh
Usage:  ./fpdlink3_i2c_jetson.sh [-f] function name -b bus -p port -p1 param1 -p2 param2 -p3 param3
5.1 fpdlink3_i2c.sh Usage
The probing and loading of FPD-Link devices are completed automatically when the system is powered on.
5.1.1 sync_init
Configure the camera on I2C bus [busnum], port [portnum] as the master of sync mode.
Connect J1 of FPD-LINK3-TX on port [portnum] to J6 of FPD-LINK3-2RX,direction is TX-->RX.
Configure the camera on I2C bus [busnum], port [portnum] as the slave of sync mode.
Connect J8 of FPD-LINK3-2RX on port [portnum] to J1 of FPD-LINK3-TX ,direction is RX-->TX.
5.1.2 trigger_init
./fpdlink3_i2c_jetson.sh -f trigger_init -b [busnum] -p [portnum]
Configure the camera on I2C bus [busnum], port [portnum] as the trigger mode.
Connect J6-0 of FPD-LINK3-2RX on port [portnum] to J1-0 of FPD-LINK3-TX ,direction is RX-->TX.
6 Typical application
6.1 CS-FPD-CAM Video usage, connnect to Jetson Nano B01/NX
CS-FPD-CAM connect to Jetson Nano/NX
6.2 CS-FPD-CAM Video usage, connnect to Jetson AGX Xavier
CS-FPD-CAM connect to Jetson AGX Xavier
6.3 CS-FPD-CAM-IMX307 sync mode,connnect to Jetson Nano B01/NX
CS-FPD-CAM-IMX307 sync mode's sync singal connection
SYNC signal connect J7-3 to J1-3,J7-2 to J1-2.
6.3.1 Step 1:
On the motherboard of the two cameras, execute:
The presence of a video0,video1, indicates that the camera has been correctly detected and the video can be connected.
6.3.2 Step 2:
After Step 1,
  • Configure cam0 as the master
./fpdlink3_i2c.sh -f sync_init -p 0 -p1 0 -b [i2c_bus_num]
./cs_mipi_i2c.sh -w -f streammode -p1 1 -p2 0 -b [i2c_bus_num] -d 0x3b
  • Configure cam1 as the slave
./fpdlink3_i2c.sh -f sync_init -p 0 -p1 1 -b [i2c_bus_num]
./cs_mipi_i2c.sh -w -f streammode -p1 1 -p2 1 -b [i2c_bus_num] -d 0x3b
6.3.3 Step 3:
The stream acquisition and I2C instruction control of the camera are exactly the same as those of the camera with the MIPI interface now.
6.4 CS-FPD-CAM-IMX307 sync mode,connnect to Jetson AGX Xavier
CS-FPD-IMX307 connect to Jetson AGX Xavier SYNC MODE
6.4.1 Step 1:
The presence of a video0-7, indicates that the camera has been correctly detected and the video can be connected.
6.4.2 Step 2:
After Step 1,
  • Configure cam1-cam7 as the slave
./fpdlink3_i2c_jetson.sh -f sync_init -p 1 -p1 1 -b 30
./cs_mipi_i2c.sh -w -f streammode -p1 1 -p2 1 -b 30 -d 0x3c
./fpdlink3_i2c_jetson.sh -f sync_init -p 0 -p1 1 -b 31
./cs_mipi_i2c.sh -w -f streammode -p1 1 -p2 1 -b 31 -d 0x3b
./fpdlink3_i2c_jetson.sh -f sync_init -p 1 -p1 1 -b 31
./cs_mipi_i2c.sh -w -f streammode -p1 1 -p2 1 -b 31 -d 0x3c
./fpdlink3_i2c_jetson.sh -f sync_init -p 0 -p1 1 -b 32
./cs_mipi_i2c.sh -w -f streammode -p1 1 -p2 1 -b 32 -d 0x3b
./fpdlink3_i2c_jetson.sh -f sync_init -p 1 -p1 1 -b 32
./cs_mipi_i2c.sh -w -f streammode -p1 1 -p2 1 -b 32 -d 0x3c
./fpdlink3_i2c_jetson.sh -f sync_init -p 0 -p1 1 -b 33
./cs_mipi_i2c.sh -w -f streammode -p1 1 -p2 1 -b 33 -d 0x3b
./fpdlink3_i2c_jetson.sh -f sync_init -p 1 -p1 1 -b 33
./cs_mipi_i2c.sh -w -f streammode -p1 1 -p2 1 -b 33 -d 0x3c
6.4.3 Step 3:
6.4.4 SYNC signal connection:
The synchronization signal is connected as shown in the figure above. J6 is connected with J8's 2, 4, 6 and 8pin.
For the schematic diagram of the SYNC signal, please refer to:
6.5 CS-FPD-CAM-SC132 Trigger mode,connnect to Jetson Nano B01/NX
CS-FPD-CAM-SC132 trigger mode's trigger signal
SYNC signal connect J7-1 to J1-1,J7-2 to J1-2.
6.5.1 Step 1:
On the motherboard of the camera, execute:
The presence of a video0, indicates that the camera has been correctly detected and the video can be connected.
6.5.2 Step 2:
./fpdlink3_i2c_jetson.sh -f trigger_init -p 0 -b [i2c_bus_num] -d 0x3b
./cs_mipi_i2c.sh -w -f streammode -p1 3 -b [i2c_bus_num] -d 0x3b
6.5.3 Step 3:
6.6 CS-FPD-CAM-SC132 Trigger mode,connnect to Jetson AGX Xavier
CS-FPD-SC132-Xavier- trigger mode's trigger signal
6.6.1 Step 1:
6.6.2 Step 2:
./fpdlink3_i2c_jetson.sh -f trigger_init -p 0 -b 30 -d 0x3b
./cs_mipi_i2c.sh -w -f streammode -p1 3 -b 30 -d 0x3b
./fpdlink3_i2c_jetson.sh -f trigger_init -p 1 -b 30 -d 0x3c
./cs_mipi_i2c.sh -w -f streammode -p1 3 -b 30 -d 0x3c
./fpdlink3_i2c_jetson.sh -f trigger_init -p 0 -b 31 -d 0x3b
./cs_mipi_i2c.sh -w -f streammode -p1 3 -b 31 -d 0x3b
./fpdlink3_i2c_jetson.sh -f trigger_init -p 1 -b 31 -d 0x3c
./cs_mipi_i2c.sh -w -f streammode -p1 3 -b 31 -d 0x3c
./fpdlink3_i2c_jetson.sh -f trigger_init -p 0 -b 32 -d 0x3b
./cs_mipi_i2c.sh -w -f streammode -p1 3 -b 32 -d 0x3b
./fpdlink3_i2c_jetson.sh -f trigger_init -p 1 -b 32 -d 0x3c
./cs_mipi_i2c.sh -w -f streammode -p1 3 -b 32 -d 0x3c
./fpdlink3_i2c_jetson.sh -f trigger_init -p 0 -b 33 -d 0x3b
./cs_mipi_i2c.sh -w -f streammode -p1 3 -b 33 -d 0x3b
./fpdlink3_i2c_jetson.sh -f trigger_init -p 1 -b 33 -d 0x3c
./cs_mipi_i2c.sh -w -f streammode -p1 3 -b 33 -d 0x3c
./fpdlink3_i2c_jetson.sh -f trigger_init -p 0 -b 34 -d 0x3b
./cs_mipi_i2c.sh -w -f streammode -p1 3 -b 34 -d 0x3b
./fpdlink3_i2c_jetson.sh -f trigger_init -p 1 -b 34 -d 0x3c
./cs_mipi_i2c.sh -w -f streammode -p1 3 -b 34 -d 0x3c
Configure all cameras as trigger mode.
6.6.3 Step 3:
