VEYE CS Camera for Jetson TX2
Contents
- 1 Overview
- 2 Hardware Setup
- 3 Upgrade Jetson Nano, Jetson TX2, AGX Xavier and Xavier NX system
- 3.1 Overview
- 3.2 Burning the prebuilt Image to upgrade Jetson Nano and Xavier NX Devkit
- 3.3 BSP package introduction
- 3.4 DTB file name and Jeton Board
- 3.5 Upgrade Jetson Nano、TX2 and Xavier NX without HOST PC
- 3.6 Upgrade Jetson Board using Host PC
- 3.7 Are Image and DTB upgrade successful ?
- 3.8 Building from Source
- 4 Applications and Test
- 5 Realtimes RTSO-9001
- 6 References
This guide shows how to use VEYE and CS series camera modules on Jetson Nano,Jetson Nano 2GB,TX2,AGX Xavier and Xavier NX. Jetson SDK Version is
- Jetpack4.2.2,L4T r32.2.1
- Jetpack4.3,L4T r32.3.1
- Jetpack4.4,L4T r32.4.3
- Jetpack4.4.1,L4T r32.4.4
- Jetpack4.5,L4T r32.5
2.1 NVIDIA TX2 Developer Kit
2.2 NVIDIA TX2 AGX Xavier
2.3 NVIDIA Nano 和 Xavier NX Devkit
3.1 Overview
Using whole prebuilt image
- download :
- How to burn
refer to Official document
3.3.1 Path
3.3.2 bsp package includes:
- prebuild linux kernel:Image
- driver source code
- dts source code
- i2c toolkits
3.4.1 Nano A02
3.4.2 Nano B01
3.4.3 Nano 2GB
3.4.4 TX2 Devkit
3.4.5 AGX XAVIER
3.4.6 XAVIER NX Devkit
Note: TX2 Jetpack version >= 4.4.1 , support this upgrade mode.
It means L4t Verion is 32.4.3
On Jetson Nano or Xavier NX:
3.5.3 Upgrade Image
Effective after restart.
3.5.4 Upgrade dtb
FDT /boot/<DTB file name>
3.6.1 Setting Up the Host PC Environment And Burn the standard Image
- Cross-compiling Toolchain
- L4T source code and Rootfs
- Jetpack4.2.2
- Jetpack4.3
- Jetpack4.4
- Jetpack4.4.1
- Jetpack4.5
- Setting Up the Environment
- Nano@Jetpack4.2.2
- Nano@Jetpack4.3
- Nano@Jetpack4.4
- Nano@Jetpack4.4.1
- Nano 2GB@Jetpack4.4.1
- TX2@Jetpack4.2.2
- TX2@Jetpack4.3
- TX2@Jetpack4.4
- AGX XavierJetpack4.2.2
- AGX XavierJetpack4.3
- AGX XavierJetpack4.4
- AGX XavierJetpack4.4.1
- Xavier NX Jetpack4.4
- Xavier NX Jetpack4.4.1
- Common part
export LOCALVERSION=-tegra
- Xavier NX Devkit
3.6.3 Upgrade Image and DTB
- Installing the Kernel
- Nano and TX2
on the Host PC:
on the Host PC:
- Flashing dtb file
3.7.1 For Image
ls /sys/bus/i2c/drivers/
3.7.2 For DTB
4.1 Check system status
- For VEYE-MIPI-327
subdev veye327 X-003b bound
- For CS-MIPI-IMX307
dmesg | grep csx307
subdev csx307 X-003b bound
- For CS-MIPI-SC132
subdev cssc132 X-003b bound
videoX
- Preview FHD(HW accelerated)
- Preview 1280*1080@45 (CS-MIPI-SC132,HW accelerated)
gst-launch-1.0 v4l2src ! "video/x-raw,format=(string)UYVY, width=(int)1280, height=(int)1080, framerate=(fraction)45/1" ! nvvidconv ! "video/x-raw(memory:NVMM),format=(string)I420" ! nvoverlaysink sync=false
- Preview 640*480p@130 (CS-MIPI-IMX307,HW accelerated)
- Capturing FHD still image
- i2c bus description:
For Nano A02, the corresponding i2c address is 6.
For Nano B01, the corresponding i2c address is 7 and 8.
subdev csimx307 X-003b bound
- VEYE-MIPI-327
5.1 Hardware Setup
5.2 Software bsp
6 References
