MV Camera on Radxa Boards
MV series MV-MIPI-SC130M Done
2.1 Connection of MV series camera and Radxa ZERO 3W
The ADP-MV1 and Zero 3W are connected to each other using a 15 to 22P FFC cable, taking care that the silver contacts are facing outwards.
Radxa Zero 3W connect to MV camera
Radxa Zero 3W connect to MV camera 2
Radxa Zero 3W connect to RAW-MIPI-SC132M
Radxa Zero 3W connect to RAW-MIPI-SC132M 2
2.2 Connection of other RAW series camera and Radxa ZERO 3W
Radxa Zero 3W connect to RAW series camera
Radxa Zero 3W connect to RAW series camera 2
includes:
  • driver source code
  • i2c toolkits
  • application demo
4 Upgrade Radxa Debain system
4.1 Overview
On the RK35xx board,
Download the latest rk356x_radxa_zero3w.tar.gz from https://github.com/veyeimaging/rk35xx_radxa/releases/ .
5 Check system status
For Radxa Zero 3W, the camera is connected to i2c-2.
You should see:
media-ctl -p -d /dev/media0
5.2.1 Link relationship
        pad0: Source
You can see that:
  • The complete name of this entity is: m00_b_mvcam 2-003b.
5.2.3 mbus-code list
RAW8 Y8_1X8 GREY
RAW10 Y10_1X10 'Y10 '
RAW12 Y12_1X12 'Y12 '
UYVY UYVY8_2X8 UYVY
6 Raw data format
The VICAP module of RK35xx supports two data saving formats, Compact and Noncompact RAW. You can modify the mode using the RKCIF_CMD_SET_CSI_MEMORY_MODE ioctl command of RKCIF. By default, the output is in Compact RAW format.
6.1 Noncompact RAW
6.2 Compact RAW
6.3 Line stride
8bit depth,line_stride=1536
6.4 Format convert tool
6.5 Raw data image player
7 Application examples
7.1 Configuring  global variables
  • Radxa Zero 3W
export I2C_BUS=2
  • MV-MIPI-IMX178M
  • MV-MIPI-SC130M
  • MV-MIPI-IMX296M
export WIDTH=1456
  • MV-MIPI-IMX287M
export WIDTH=704
export HEIGHT=544
export FPS=319
  • MV-MIPI-IMX265M
  • MV-MIPI-IMX264M
export HEIGHT=2056
export FPS=28
  • RAW-MIPI-SC132M
export WIDTH=1024
export HEIGHT=1280
export FPS=120
  • RAW-MIPI-IMX462M
export WIDTH=1920
  • RAW-MIPI-AR0234M
export WIDTH=1920
export HEIGHT=1200
7.2.1 Trigger Mode
7.2.2 Trigger Source
7.2.4 Set frame rate
7.4 Video Streaming mode
7.4.2 Frame rate statistics
Or:
7.4.3 Save image to file
  • raw8
  • raw10
  • raw12
7.4.4 Example of yavta
7.4.4.1 Install yavta
7.4.4.2 Save image to file
python ./v4l2dev_2_opencv_show_grey.py --width 1456 --height 1088 --fps 60 --i2c 2
7.5 Trigger mode
7.5.2 Software trigger mode
7.5.2.1 Set mode
7.5.2.2 Start acquisition
7.5.3 Hardware trigger mode
7.5.3.1 Set mode
7.5.3.2 Start acquisition
mv_mipi_i2c.sh user guide
9 Compile drivers and dtb from source code
  • RK356x
  • VEYE series
11 References
  • Radxa Zero 3W Manual
  • BSP toolkit
12 Document History
  • 2024-04-24
