Mv mipi camera manual
| MV-MIPI-IMX287M | 720×544 @ 523fps RAW8
Global | |
1280×1024@177fps RAW10 |
Global | |
| MV-MIPI-GMAX4002M | 4lane@8bit mode:2048 x 1200 @213fps
Global | |
Rolling | |
Global | |
| RAW-MIPI-SC535M | 4lane@8bit mode:2448 x 2048 @83fps
Global |
2 Image Acquisition
2.1.1 Rolling shutter
2.1.2 Global shutter
2.2 Start/Stop Acquisition
Related commands :imgacq.
2.3 Video streaming mode
2.4 Normal trigger mode
2.4.1 Rolling shutter
This section applies to model: MV-MIPI-SC130M,RAW-MIPI-SC132M,RAW-MIPI-SC535M,RAW-MIPI-AR0234M.
For Smartsens's global shutter sensor, such as the SC130GS, a complete image frame requires an exposure time and a read out cycle to complete. The second frame can be exposed only after the read out cycle is completed.
For RAW series modules, Exposure Delay is not supported.
2.4.3 Sony's Global shutter
This section applies to model: MV-MIPI-IMX296M,MV-MIPI-IMX265M,MV-MIPI-IMX264M,MV-MIPI-IMX287M,MV-MIPI-GMAX4002M.
2.5 Pulse trigger mode
This section applies to model: MV-MIPI-IMX296M,MV-MIPI-IMX265M,MV-MIPI-IMX264M,MV-MIPI-IMX287M,MV-MIPI-SC130M,MV-MIPI-GMAX4002M,RAW-MIPI-SC535M.
This mode does not support parameters such as trigger delay, trigger interval, or trigger count, but it does support the trigger filter and the exposure delay parameter.
2.7 Switching of modes
2.8 Trigger source
Related commands :trgsrc.
2.8.1 Software trigger mode
Related commands :trgone.
2.8.2 Hardware trigger mode
2.9 Trigger statistics
3 Image Feature
3.1 Pixel Format
| Model | Pixel Format | Note |
| MV-MIPI-IMX178M | Mono8,Mono10,Mono12 | sensor's AD is 12bit-depth |
| MV-MIPI-SC130M | Mono8,Mono10 | sensor's AD is 10bit-depth |
| MV-MIPI-IMX296M | Mono8,Mono10 | sensor's AD is 10bit-depth |
| MV-MIPI-IMX287M | Mono8,Mono10,Mono12 | sensor's AD is 8,10,12bit-depth |
| MV-MIPI-IMX265M | Mono8,Mono10,Mono12 | sensor's AD is 12bit-depth |
| MV-MIPI-IMX264M | Mono8,Mono10,Mono12 | sensor's AD is 12bit-depth |
| MV-MIPI-GMAX4002M | Mono8,Mono10,Mono12 | sensor的AD is 10,12bit-depth |
| RAW-MIPI-SC132M | Mono8,Mono10 | sensor's AD is 10bit-depth |
| RAW-MIPI-IMX462M | Mono10,Mono12 | sensor's AD is 10,12bit-depth |
| RAW-MIPI-AR0234M | Mono8,Mono10 | sensor's AD is 10bit-depth |
| RAW-MIPI-SC535M | Mono8,Mono10,Mono12 | sensor's AD is 12bit-depth |
| model | size | max framerate | Note |
| MV-MIPI-IMX178M | 3088 × 2064 | 22.3 | Max size |
| 2592 x 1944 | 28.15 | ||
| 2560 x 2048 | 27 | ||
| 1920 x 1080 | 67 | ||
| MV-MIPI-SC130M | 1280 × 1024 | 214 | Max size,RAW8 |
| 1280 x 720 | 249 | RAW8 | |
| 640 x 480 | 367 | RAW8 | |
| MV-MIPI-IMX296M | 1456×1088 | 60.3 | Max size |
| 1280 x 720 | 90 | ||
| MV-MIPI-IMX287M | 720x544 | 523 | RAW8 |
| 437 | RAW10 | ||
| 320 | RAW12 | ||
| MV-MIPI-IMX265M | 2064×1544 | 55 | Max size |
| MV-MIPI-IMX264M | 2464×2056 | 35 | Max size |
| MV-MIPI-GMAX4002M | 2048 x 1200@4lane RAW8 | 213 | |
| 2048 x 1200@4lane RAW10 | 185 | ||
| 2048 x 1200@4lane RAW12 | 158 | ||
| 2048 x 1200@2lane RAW8 | 112 | ||
| 2048 x 1200@2lane RAW10 | 99 | ||
| 2048 x 1200@2lane RAW12 | 84 | ||
| RAW-MIPI-SC132M | 1080×1280 | 120 | Max size |
| RAW-MIPI-IMX462M | 1920x1088@4lane raw10 | 120 | |
| 1920x1088@2lane raw10/12 | 60 | ||
| 1920x1200@2lane | 60 | ||
| RAW-MIPI-SC535M | 2448 x 2048@4lane RAW8 | 100 | |
| 2448 x 2048@4lane RAW10 | 82 | ||
| 2448 x 2048@4lane RAW12 | 70 | ||
| 2448 x 2048@2lane RAW8 | 53 | ||
| 2448 x 2048@2lane RAW10 | 43 | ||
| 2448 x 2048@2lane RAW12 | 36 |
3.3 ROI area
| model | minimum ROI area | Note |
| MV-MIPI-IMX296M | 80x4 | |
| MV-MIPI-IMX287M | 264x4 | |
| MV-MIPI-IMX265M | 264x4 | |
| MV-MIPI-IMX264M | 264x4 | |
| MV-MIPI-GMAX4002M | 64x64 | |
| RAW-MIPI-SC132M | 64x64 | |
| RAW-MIPI-AR0234M | 64x64 | |
| RAW-MIPI-SC535M | 64x64 |
Related commands:roi.
3.4 Mirror and Flip
Related commands:imgdir.
3.5 Blacklevel
Related command: blacklevel.
3.6 Test Pattern
3.6.1 MV-MIPI-IMX178M
3.6.3 RAW-MIPI-AR0234M
3.6.3.2 Mode 2:color bar
Related command: testimg.
4 ISP
4.1 Exposure and Gain Control
4.1.1 AAROI
4.1.2 Exposure
4.1.2.1 Manual Exposure(ME)
Use a fixed exposure time.
4.1.2.2 Auto Exposure(AE)
4.1.3 Gain
| model | Range | Step |
| MV-MIPI-GMAX4002M | Analog Gain:0 dB to 11.6 dB
Digital Gain: 6 dB to 23.8 dB |
0.1dB |
| RAW-MIPI-SC535M | 0-69dB | 0.1dB |
4.1.3.1 Manual Gain(MG)
Use a fixed gain.
4.1.3.2 Auto Gain(AG)
4.1.4 Other notes
4.2 gamma
4.3 Lookup Table(LUT)
4.4 OSD Overlay
Certain camera modules perform an OSD overlay function after the ISP process.
- Mode 1:
Overlay a square cross at the center of the image with both width and height of 150 pixels, and a stroke width of 2 pixels. This is used for coordinate calibration.
Related command: osdmode
5 IO Control
5.1 Input IO Configuration
Related commands :trgedge.
5.1.1 Trigger Filter
5.1.2 Trigger Delay
MV and RAW series cameras have a trigger delay function. The trigger delay time can be set to [1,1000000]us. It is in effect for both hard and soft triggers.
Related commands :trgdelay.
5.2 Output IO Configuration
5.2.1 Strobe
The strobe signal of the RAW series cameras is directly output by the sensor, representing the accurate exposure time period.
5.2.2 UserOut
5.2.3 TriggerWait
This section applies to model: MV-MIPI-IMX296M,MV-MIPI-IMX265M,MV-MIPI-IMX264M,MV-MIPI-IMX287M,MV-MIPI-SC130M,MV-MIPI-GMAX4002M.
5.2.5 XVS
5.2.6 XHS
5.2.7 Pin Reverse
5.3 Read pin status
6 Special note for RAW series camera Trigger Delay
For RAW series cameras, the trigger signal needs to be forwarded to the sensor by the MCU, and this forwarding has a fixed delay of about 950ns.
7 Document History
- 2025-03-14
Add description about GMAX4002M.
- 2025-01-07
1. Remove the description of the SDA mode for the RAW series products.
2. Add a description of the external trigger mode for the RAW series based on the upgrade achievements.
- 2024-08-27
