RAW-MIPI-AR0234M Data Sheet
RAW-MIPI-AR0234M is a 2.3 million MONO industrial camera with MIPI interface.
RAW-MIPI-AR0234M
  • 1/2.6'' 2.3M Pixel ON Semicondutor CMOS Sensor
  • MIPI CSI-2 Interface
  • Mono 8、Mono 10 Data Format
  • Automatic exposure mode and Manual exposure mode
  • Video streaming mode,Trigger mode
  • Support trigger delay, trigger count function
  • Strobe synchronization
  • ROI
  • Support Sensor Direct Access mode
RAW-MIPI-AR0234M
3 Technical Detail
Technical Details
Sensor Type CMOS
Shutter Mode Global Shutter
Sensor AR0234CSSM00SUKA0−CP
Color MONO
Image Size 1/2.6''
Unit Cell Size 3μm × 3μm
Resolution 1920(H) × 1200(V)
Max Frame Rate 4lane mode:1920 x 1200 @120fps
2lane mode:1920 x 1200 @60fps
Gain Analog Gain:1.68x to 16x(3.47dB-24dB)
Digital Gain: 1x to16x (0dB-24dB)
Shutter Mode Auto Exposure,Auto Gain,Manual Exposure,Manual Gain
ADC Resolution 10 bit
Pixel Format Mono8,Mono10
ROI Support
Mirror Image Mirror and Flip
Working Mode Hardware Trigger,Software Trigger,Video streaming mode
Trigger Mode Trigger INPUT
Strobe Mode Strobe Output
Electrical characteristics
Data Interface MIPI CSI-2
Data Rate / lane:900Mbps@10bit,720Mbps@8bit
lane num:2 lane / 4 lane
Digital IO Non-isolation IO:1 Trigger in,1 Strobe output,3.3V Level
Power Supply 3.3V DC
Power Consumption 657mW@3.3V
Structure
Size Length * width * height = 29*29*7.5mm
Lens Mount C-MOUNT01 or M12 holder
Operating Conditions
Humidity Humidity 95% or less
Sensor Spectral Sensitivity
AR0234CS
AR0234CS QE
5 Interface & Pin list
RAW-MIPI-AR0234M
J9 : Camera MIPI CSI-2
1 VCC3V3 3.3V PWR IN
2 SDA 3.3V Level
3 SCL 3.3V Level
5 NC
6 SYS_RSTn System reset,3.3V Level
8 MIPI_L3_P
9 MIPI_L3_N
11 MIPI_L2_P
12 MIPI_L2_N
13 GND
14 MIPI_CK_P
15 MIPI_CK_N
16 GND
17 MIPI_L1_P
18 MIPI_L1_N
19 GND
20 MIPI_L0_P
21 MIPI_L0_N
22 GND
J2:功能IO
1 Trigger In Trigger Input,3.3V
3 Strobe Out Strobe Output,3.3V
6 Board Dimension
Download 2D DXF file
7 PCBA 3D STP File
Download 3D STP file
