RAW-MIPI-IMX462M Data Sheet
RAW-MIPI-IMX462M is a 2 Mega MONO industrial camera with MIPI interface.
RAW-MIPI-IMX462M
  • 1/2.8" 2M Pixel SONY STARVIS CMOS sensor
  • MIPI CSI-2 Interface
  • Mono-10/Mono-12 Data Format
  • 2lane/4lane mode
  • Video streaming mode
  • Master mode and Slave mode
  • ROI
  • Support Sensor Direct Access mode
RAW-MIPI-IMX462M
3 Technical Detail
Technical Details
Sensor Type CMOS
Shutter Mode Rolling Shutter
Sensor SONY IMX462LLR-C STARVIS
Color MONO
Image Size 1/2.8''
Unit Cell Size 2.9μm × 2.9μm
Resolution 1944(H) × 1096(V)
Max Frame Rate 4lane mode@10bit:1944 x 1096 @120fps
2lane mode@10/12bit:1944 x 1096 @60fps
Gain 0 dB to 29.4 dB: Analog Gain 29.4 dB (step pitch 0.3 dB)
29.7 dB to 71.4 dB: Analog Gain 29.4 dB + Digital Gain 0.3 to 42 dB (step pitch 0.3 dB)
Shutter Mode Manual Exposure,Manual Gain
ADC Resolution 10-bit / 12-bit A/D converter
Pixel Format Mono10,Mono12
ROI Support
Mirror Image Mirror and Flip
Working Mode Video streaming mode
Sync Mode Master mode, Slave mode
Strobe Mode Strobe Output
Electrical characteristics
Data Interface MIPI CSI-2
Data Rate / lane:891Mbps
lane num:2 lane / 4 lane
Digital IO Non-isolation IO:XVS XHS,3.3V Level
Power Supply 3.3V DC
Power Consumption 625mW@3.3V
Structure
Size Length * width * height = 29*29*7.5mm
Lens Mount C-MOUNT01 or M12 holder
Operating Conditions
Humidity Humidity 95% or less
Sensor Spectral Sensitivity
IMX462LLR-C
IMX462LLR-C
5 Interface & Pin list
RAW-MIPI-IMX462M
J3 : Camera MIPI CSI-2
Pin NO. NAME Remarks
1 VCC3V3 3.3V PWR IN
2 SDA 3.3V Level
3 SCL 3.3V Level
5 NC
6 SYS_RSTn System reset,Active Low
8 MIPI_L3_P
9 MIPI_L3_N
11 MIPI_L2_P
12 MIPI_L2_N
13 GND
14 MIPI_CK_P
15 MIPI_CK_N
16 GND
17 MIPI_L1_P
18 MIPI_L1_N
19 GND
20 MIPI_L0_P
21 MIPI_L0_N
22 GND
J2:GPIO
1 XVS IN / OUT,3.3V
3 XHS IN / OUT,3.3V
6 Board Dimension
Download 2D DXF file
7 PCBA 3D STP File
Download 3D STP file
