V4L2 mode for Raspberry Pi
CS series CS-MIPI-IMX307 Done
CS series CS-MIPI-SC132 Done
In addition, FPD-Link3 mode connection is now supported.
4 Driver Installation
4.1 Download the driver
4.2 Install the driver
  • For Raspberry Pi 5
sudo ./install_driver_rpi5.sh camera_module_name
  • For other Raspberry Pi
sudo ./install_driver.sh camera_module_name
camera_module_name:could be veye327,csimx307,cssc132,veyecam2m.
Note: veyecam2m is a new version driver that can replace veye327 and supports all modules of the VEYE series with 200W resolution.
4.3 Uninstall the driver
sudo ./uninstall_driver.sh camera_module_name
4.4 Camera in FPD-Link3 Mode
For a camera operating in FPD-Link3 transmission mode, it is necessary to ensure that the ds90ub954 driver is loaded and initialized before loading the camera driver and performing probe.
Take the VEYE-MIPI-IMX327S camera in FPD-Link3 mode as an example:
Install the drivers correctly:
sudo ./install_driver.sh ds90ub954
sudo ./install_driver.sh veyecam2m
5 Check and Test the Camera
Check the camera probe status
  • VEYE-MIPI-327
You can see:
veye327 camera probed
  • CS-MIPI-IMX307
dmesg | grep 307
You can see:
camera id is cs-mipi-imx307
  • CS-MIPI-SC132
dmesg | grep 132
You can see:
camera id is cs-mipi-sc132
5.1 List the video device
The device node exsit.
6 Raspberry Pi 5 Setting
  • ./find_entity.sh
Found veyecam2m @ i2c-6 entity on /dev/media0
  • media_setting_rpi5.sh
./media_setting_rpi5.sh
Note: This script must be executed after each startup to complete the configuration of the parameters before proceeding with further operations.
For instance:
7 Preview
On a raspberry pi 5, VLC for preview is now having color problems and not working.
7.1 Preview using VLC
Play camera using VLC on RPI
7.2 Preview using qv4l2
8 Gstreamer usage samples
8.1 install gstreamer
gst-launch-1.0 v4l2src io-mode=dmabuf device=/dev/video0 ! "video/x-raw,format=(string)UYVY, width=(int)1920, height=(int)1080,framerate=(fraction)30/1" ! v4l2convert capture-io-mode=dmabuf output-io-mode=dmabuf ! autovideosink sync=false -v
Or:
gst-launch-1.0 v4l2src device=/dev/video0 ! "video/x-raw,format=(string)UYVY, width=(int)1920, height=(int)1080,framerate=(fraction)30/1" ! videoconvert ! autovideosink  sync=false -v
gst-launch-1.0 v4l2src device=/dev/video0 ! "video/x-raw,format=(string)UYVY, width=(int)1920, height=(int)1080,framerate=(fraction)30/1"  ! videoconvert ! videoscale ! clockoverlay time-format="%D %H:%M:%S" ! video/x-raw, width=640, height=360 ! autovideosink sync=false -v
gst-launch-1.0 -e v4l2src io-mode=dmabuf device=/dev/video0 num-buffers=300 ! "video/x-raw,format=(string)UYVY, width=(int)1920, height=(int)1080,framerate=(fraction)30/1" ! v4l2h264enc capture-io-mode=dmabuf output-io-mode=dmabuf extra-controls="controls, h264_profile=4, video_bitrate=6200000" ! 'video/x-h264, profile=high, level=(string)4' ! h264parse ! mp4mux ! filesink location=video.mp4
8.12 TCP streaming
raspberrypi(sender)
gst-launch-1.0 -v v4l2src device=/dev/video0 num-buffers=-1 ! "video/x-raw,format=(string)UYVY, width=(int)1920, height=(int)1080,framerate=(fraction)30/1" ! v4l2h264enc extra-controls="controls, h264_profile=4, video_bitrate=4000000" ! 'video/x-h264, profile=high, level=(string)4' ! h264parse ! rtph264pay config-interval=1 pt=96 ! gdppay ! tcpserversink  host=x.x.x.x port=5000
Client
9 Stream to OpenCV
pip uninstall opencv-python
10 V4l2-ctl usage examples
10.1 install v4l2-utils
10.2 v4l2-ctl test
  • Snap one UYVY raw data picture (1080p mode)
  • Snap 10 UYVY raw data pictures (1080p mode)
11 yavta usage examples
11.1 download yavta
11.2 yavta test
13 Notes for CM4
13.1 Hardware Connection
13.2 Upgrade dt-blob.bin
Upgrade dual camera version dtbo file, Use csimx307 as an example.
Take veyecam2m as an example.
dtoverlay=veyecam2m
dtoverlay=veyecam2m,cam0
13.5 Device node description
The CM4 module uses two I2C channels to communicate with the two cameras, respectively.
CAM0 0 video0
13.6 Gstreamer usage samples
  • CAM0 preview(VEYE-MIPI-327,CS-MIPI-IMX307 @1080p mode)
  • CAM1 preview(VEYE-MIPI-327,CS-MIPI-IMX307 @1080p mode)
gst-launch-1.0 v4l2src io-mode=dmabuf device=/dev/video1 ! "video/x-raw,format=(string)UYVY, width=(int)1920, height=(int)1080,framerate=(fraction)30/1" ! v4l2convert capture-io-mode=dmabuf output-io-mode=dmabuf ! autovideosink sync=false -v
14 Source code compilation
15 Document History
  • 2024-01-01
  • 20230607
Add FPD-Link3 Driver and Its Description.
  • 20230304
  • 20220706
  • 20220505
  • 20220411
  • 20220302
  • 20220301
Support 64-bit piOS
  • 20220225
  • 20211125
Add VLC preview section.
